[ALL B5] Czujnik Oleju
Panowie potrzebuje waszej pomocy.
Otóż zapala mi sie czesto na pełnym FIS zółta kontrolka o MIN OLEJU w silniku, ale oleju jest dosyc i nigdzie go nie ubywa.
-> Potrzebuje sie dowiedziec na jakiej zasadzie komunikuje sie z licznikiem czujnik oleju w misce olejowej.
-> Oraz jakie piny konkretnie w liczniku sa od tego czujnika bo mamy tam 3 piny . Zeby sprawdzic instalacje
A tu rozpiska pinów z liczniku po 2000r
connector for basic functions, 32-pin, blue
1 -Terminal 15
2 -Wear of brake pads
3 -Speedometer output 1
4 -not used
5 -Fuel gauge sender
6 -Fuel gauge warning OBD 2
7 -Terminal 31 (sensor earth)
8 -Coolant temperature
9 -Terminal 31 (load earth)
10 -Oil pressure 2 (high)
11 -Engine-speed signal
12 -Air conditioner shutoff
13 -Electronic throttle/ pre-glow control
14 -Self-levelling suspension
15 -Terminal 58d
16 -Trailer turn signal
17 -Main beam
18 -Left turn signal
19 -not used
20 -Terminal 58s
21 -Door contact, driver's side
22 -Low coolant level
23 -Terminal 30
24 -Terminal 31 (load earth)
25 -Consumption signal
26 -Right parking light
27 -Left parking light
28 -Speedometer input
29 -Brake
30 -S-contact
31 -Speedometer output 2
32 -ESP/TCS
connector for additional functions, 32-pin, green
1 -Door contact (all doors)
2 -Transponder 1
3 -not used
4 -not used
5 -W wire
6 -Tailgate
7 -Right turn signal
8 -External buzzer
9 -External gong
10 -Airbag
11 -Service life output
12 -Terminal 61
13 -Parking brake
14 -CHECK
15 -Oil level / temperature
16 -not used
17 -Transponder 2
18 -CAN high speed (drive) (high +)
19 -CAN high speed (drive) (low -)
20 -CAN high speed (drive) (screen)
21 -ABS
22 -CAN low speed (Convenience) (high +)
23 -CAN low speed (Convenience) (low -)
24 -CAN low speed (Convenience) (screen)
25 -Bonnet
26 -not used
27 -Belt buckle
28 -K wire
29 -Ambient temperature input
30 -not used
31 -Selection range
32 -not used
connector for multifunction display, 32-pin, grey
1 -Switch menu guide (menu)
2 -Switch menu guide (out A)
3 -Switch menu guide (out B)
4 -Switch menu guide (Enter)
5 -CAN high speed Display (high +)
6 -CAN high speed Display (low -)
7 -CAN high speed Display (screen)
8 -Door contact, passenger side
9 -Door contact, rear right
10 -Door contact, rear left
11 -Enable
12 -Clock
13 -Data
14 -Brake light
15 -Washer fluid level
16 -Tail lights/dipped beams
17 -On-board computer, left
18 -On-board computer, right
19 -On-board computer reset
20 -not used
21 -not used
22 -not used
23 -Key branch 1 Navigation system
24 -Key branch 2 Navigation system
25 -Key branch Telematics
26 -not used
27 -not used
28 -not used
29 -not used
30 -not used
31 -not used
32 -not used
Do licznika idzie tylko jeden przewód. Masz go w zielonej wtyczce, pin nr 15.
Czujnik ma trzy piny, ponieważ jeden to +12V, drugi to masa a trzeci to "dane" do licznika.
Jeżeli wywala błąd z napisem "min" a oleju masz OK, to przyczyna najprawdopodobniej leży w samym czujniku. Najprawdopodobniej jest uszkodzony.
Ja też mam ten sam problem. Albo uwalony jest czujnik albo połączenie przewodowe. Ktoś tam kiedyś pisał żeby psiknąć jakimś kontaktorem tam przy kostce. Jak sie zrobi cieplej to zobaczę.
Taką opcje to ja juz obstawiałem, ale zanim go wymienie chciałem wszystko sprawdzic abym był pewien , że to napewno On jest winien.
Dodam że niedziała mi też temperatura oleju na dodatkowym wskaźniku.
Chce wszystko posprawdzac.
A orientujesz sie na jakiej zasadzie komunikuje sie sensor ???? Bo z niego ida informacje o temp i poziomie oleju.
A tobie pokazuje temp oleju na dodatkowym wskaźniku ???
niestety nie, pokazuje tylko wtedy gdy zgasze auto i odpale ponownie, wtedy temp. rośnie do danej wartości i po około 5 sek znów spada na 60*C
a u ciebie wskazuje temp.?? [br]Dopisany: 02 Styczeń 2011, 20:27_________________________________________________a dobra doczytałem, u ciebie też nie działa :)
No i dokładnie tak samo jest u mnie. Jak autko zagrzane to po przekreceniu stacyjki na chwile pokazuje TEMP OLEJU a potem spada do zera :)
A MIN zapala ci sie jakos przy okreslonej sytuacji ???
nie, MIN zapala się tak po prostu,
po otworzeniu maski, komunikat ginie, a potem znów za jakieś 100km zapala się ponownie
Hmmm. No to widze że mamy identyko problem.
Tak z ciekawosci jaki posiadasz licznik ????
Czy ktos wie na jakiej zasadzie jest ta komunikacja bo ida niby 2 sygnały po jednym kablu ????
mam AJM, tak jak Ty
sygnał jest w postaci PWM
tu masz troszkę więcej o tym czujniku: http://forum.octaviaclub.pl/viewtopic.php?t=21027
O dużo juz sie naszukałem ale tego nie znalazłem jeszcze :) Dzieks, a może jeszcze jakieś fajne info na temat tego czujnika ???
Ale mi nie chodziło jaki masz silnik ale jaki masz licznik VDO/JAGER i jego numerek ???
Więcej info nie mam
a sorry, licznik mam VDO a numerka to nie kojarzę
A Ty ten licznik wyrezałeś czy miałeś ori FIS??
Więcej info nie mam
Rezanko, a u ciebie ORI ???
też rezany, wcześniej miałeś 1/2 FIS? też Ci krzyczało o niskim stanie?
No miałem 1/2 FIS, i to na dodatek Jagera który zima był nie do wytrzymania, chociaż później zrobiłem silniczki od wskazówek i było w miare.
Ale u mnie na 1/2 Fis nie wylatywało niski stan oleju, jak dopiero wymieniłem na VDO to mi zaczęło sie to pokazywac i to nawet nie odrazu bo dopiero po jakimś czasie.
A u ciebie ??? Wykżaczało sie na 1/2
U mnie było tak, że na 1/2 też krzyczało, ale nie wiem czy od czujnika czy od niskiego stanu oliwy, bo było to przed wymianą oleju i na bagnecie był praktycznie stan min.
tak więc ciężko określić
Odkąd wymieniłem na pełny FIS, cały czas się to zapala.
Tak sobie myślę, że jak u ciebie jest taka sama sytuacja może trzeba coś vagiem przekodować :mysli:
No może i tak ale co ???
A powiedz mi jeszcze zmianiałes wsad w liczniku czy poprostu kupiłes europejski licznik od diesla ???
kupiłem normalnie europejski licznik, nic nie kombinowałem
A powiedz mi masz dostep do kabla aby odczytac błedy ???
Jak tak to masz jakies w liczniku ????
Mam vaga, ale błędów nie mam żadnych
  • 1 rok później...
Panowie udało się rozwiązać ten problem ?
