[INNE] Analiza błędów audi A6 C6 2.0 TDI
witam
czy moze mi ktos pomoc w analizie ponizszych bledow ewentualnie podpowiedziec w rozwiazaniu
glownym bledem jest kontrolka od hamlca recznego, rano po odpaleniu auta wyskakuje blad ale po przejechaniu powiedzmy 10 km i ponownym odpaleniu auta blad znika, czasem blad sie pojawia czasem nie
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 BF HW: 028 101 185 0
Component: R4 2,0L EDC G000SG 9553
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00409 210 68986
VCID: 68D4BAFE6429CD5C
1 Fault Found
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 134.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Bin. Bits: 00000100
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02325 785 00200
VCID: 2C5C06EEB051217C
1 Fault Found
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 16
Reset counter: 86
Mileage: 217880 km
Time Indication: 0
Date: 2011.06.15
Time: 06:29:33
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x03A2
Hex Value: 0x0008
Hex Value: 0xB08E
Hex Value: 0x00FF
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H15 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Shop #: WSC 02335 785 00200
VCID: 2854FAFEA4A90D5C
Part No: 4F2 910 113
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
1 Fault Found
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 121760 km
Time Indication: 0
Date: 2007.08.28
Time: 19:51:00
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000111
Shop #: WSC 02334 785 00200
VCID: DDBA1B2A3B6B18F4
1 Fault Found
01316 - ABS Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 16
Reset counter: 86
Mileage: 217880 km
Time Indication: 0
Date: 2011.06.15
Time: 06:29:31
Freeze Frame:
Voltage: 10.77 V
Count: 231
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000060138
Shop #: WSC 00409 210 61188
VCID: 234EEDD2DD8FEE04
Part No: 4F0 915 105 C
Component: von VA0 2506130338
Coding: 344630393135313035432056413032353036313330333338
Shop #: WSC 00000 384 00290
4 Faults Found
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 25
Mileage: 178015 km
Time Indication: 0
Date: 2008.10.11
Time: 16:21:48
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Mileage: 178015 km
Time Indication: 0
Date: 2008.10.11
Time: 16:21:58
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 15
Mileage: 178015 km
Time Indication: 0
Date: 2008.10.11
Time: 16:22:08
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Mileage: 178015 km
Time Indication: 0
Date: 2008.10.11
Time: 16:22:18
Sprawdziłbym na początek lewy tylny czujnik prędkości ABS i jego okablowanie
ok dam znac koledze i jak tylko to zrobi odezwe sie czy cios znalazl
dzieki wielkie
potem bedziemy szukac dalej
