Lukasz_mk2 Opublikowano 4 Stycznia 2012 Opublikowano 4 Stycznia 2012 Bardzo proszę o pomoc w rozwiązaniu moich dwóch problemów. Problem nr 1: VAG-COM Version: Release 311.2-N Control Module Part Number: 8E0 035 152 Component and/or Version: chorus II GRO 0008 Software Coding: 00200 Work Shop Code: WSC 00000 1 Fault Found: 01042 - Control Module: Not Coded 35-00 - - Na forum znalazłem takie rozwiązanie : Standard/Bose and other configuration modesYou can program the Concert II radio to use either the standard or the Bose equalization setting, as well as a few other basic configurations. This requires the use of a VAG-1551, VAG-1552 or equivalent scan tool (See VAG-COM or ProDiag). Knowledge of the usage of such a scan tool is assumed. Connect scan tool to the car's OBD-II diagnotic port. Turn on ignition and radio, select Radio Controller in scan tool. The radio shows "DIAG" in the display. Select "Recode Module". You may enter a 5-digit code according to the table below. For example, "00007" is a standard setting while "00017" is a Bose setting, both with CD changer and secondary display. Turn off radio and ignition, disconnect scan tool. Turn on radio to hear the effects. In Bose mode, the radio display will show "BOSE" briefly after turn-on. Digit Description 1. Country ID (0 = standard) 2. Sound Coordination (0 = standard) 3. Number of passive speakers 0 = No passive speakers (Bose) 1 = Front left (Bose with hands-free phone) 2 = Fronts passive, rears active 5 = Fronts passive, rears non-active 4. Sound System 0 = standard 1 = Bose 5. Radio Configuration 1 = No CD changer 3 = With CD changer 5 = With secondary display 7 = With CD changer and secondary display tyle, że ja u siebie mam chorusa (tak jak to widać na vag'u) oraz wzmacniacz zwykły (nie bose), zestaw telefoniczny callman'a i cd changer. Czy moje kodowanie będzie wyglądać mniej więcej tak: 00203 i co to jest secondary display??(mam kolorowego FIS'a - czy to jest to??). Czy moje obecne kodowanie to: "Software Coding: 00200" sczytane z vag'a?? Jeśli nie to jak je sczytać?? Problem nr 2. Mam obecnie zestaw callmann'a do noki 6310 bez BT, jest on sprawny (korzystam na co dzień). Planuje założyć BT. Po przeczytaniu tematu na temat zakładania BT wyczytałem, że należy zakodować kanał 77-telephone vag'iem, więc na próbę chciałem się z nim połączyć, lecz niestety "nie ma odpowiedzi ze sterownika". Czy nie mając BT nie ma możliwości połączenia się z kanałem 77, czy mój kabel nie daje rady??
wrclaguna Opublikowano 4 Stycznia 2012 Opublikowano 4 Stycznia 2012 {Radiowe systemy (II generacji) } Control Module Coding (Chorus II / Koncert II / II Symfonia) STG 56 (Radio-/Navigation) wybierz Coding -> Function 07 ? Xxxxx Opcje specjalne +1 - Radio satelitarne zainstalowane +2 - Digital Radio zainstalowane +4 - Wyświetlacz prędkości możliwe UWAGA: Aby aktywować prędkościomierz, musi włączyć radio jednocześnie przycisk MENU jest wciśnięty. Aby wyłączyć radio FM na off przycisk on / off. x xxxx: opcje opt-out +1 - Diagnostyka dla przednich głośników off +2 - GALA-off +4 - Odbieranie długa fala off xx xxx: właściwości akustyczne 0 - liniową charakterystykę dźwięku (chorus tylko) 1 - dźwięk funkcji dla 3-drzwi A3 2 - dźwięk funkcji dla 5-drzwi A3 3 - Type 1 charakterystyki dźwięku 4 - Typ 2 cechy dźwięku 5 - dźwięk cechy Typ 3 xxx xx: Fader / BOSE / wzmacniacza +1 - Wskaźnik Fader z +2 - Wyświetlacz Bosego- +4 - Wzmacniacz z wywołuje shutdown xxxx x: Opcje I Sprzęt +1 - Nawigacja dostępna +2 - Telefon dostępny +4 - System kontroli głosem dostępny xxxxx: Sprzęt Opcje II +1 - Różnorodność Antena dostępna +2 - Zmieniarka CD dostępna +4 - Multisystem w kierownicy dostępna Jak nie masz bluetooth to nie połączysz sie ze sterownikiem 77
superdziki Opublikowano 4 Stycznia 2012 Opublikowano 4 Stycznia 2012 Na stronie Ross-techu jest inaczej jeśli chodzi o "właściwości akustyczne" x?xxx: Tone Characteristics (MY 2002 >) 0 = Tone Characteristics for all other Models and all Radio Chorus 1 = Tone Characteristics for A4 (8E) 2 = Tone Characteristics for A6 (4B) & Audi A2 (MY 2005 >) 3 = Tone Characteristics for A4 Cabriolet (8H) 4 = Tone Characteristics for TT (8N) 5 = Tone Characteristics for A3 (8L) Ja mam Symphony i kodowanie 01021 ty jak masz jeszcze zmieniarke to 00023
Lukasz_mk2 Opublikowano 4 Stycznia 2012 Autor Opublikowano 4 Stycznia 2012 czyli jak mam nawigacje BNS, telefon (bez BT) wzmacniacz (nie bose), cd changer, zegarek satelitarny, chciał bym też mieć sygnał Gala (jak rozumiem to chodzi o to, że wraz ze zmianą szybkości radio będzie grało ciszej/głośniej) to jak będzie wyglądać to kodowanie bo coś nie mogę tego rozszyfrować?? I co to znaczy "Wyświetlacz prędkości możliwe"?? I mam rozumieć, że kodowanie przeprowadzam w taki sposób: Wchodzę w 56 Radio (w vag-com 3.11 Navigation jest pod numerem 37) wybieram Coding -> Function 07 i wpisuje właściwy kod??
superdziki Opublikowano 4 Stycznia 2012 Opublikowano 4 Stycznia 2012 Wchodzę w 56 Radio (w vag-com 3.11 Navigation jest pod numerem 37) wybieram Coding -> Function 07 i wpisuje właściwy kod?? kodujesz radio 56 a nie nawigacje, ale tak to przebiega.
wrclaguna Opublikowano 5 Stycznia 2012 Opublikowano 5 Stycznia 2012 To wreszcie co masz Chorusa czy BNS Tu masz instrukcje jakby co jak kodowac itd. http://www.vcds.eu/downloads/Instrukcja%20obslugi%20oprogramowania%20VCDS.pdf
Lukasz_mk2 Opublikowano 5 Stycznia 2012 Autor Opublikowano 5 Stycznia 2012 radio mam chorusa, a BNS to moja nawigacja (mała kolorowa między zegarami)
