MarianekZg 2 Opublikowano 26 Lipca 2011 Udostępnij Opublikowano 26 Lipca 2011 ale nie muszisz sie przejmowac Twoje auto nie przyjmuje kodowania :polew: :polew: :laghing2: :laghing2: :laghing2: :laghing2: jeszcze przyjmuje Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Dev 1477 Opublikowano 26 Lipca 2011 Udostępnij Opublikowano 26 Lipca 2011 tutaj masz info Login Note #1: After Login has been carried out you need to recode the control module. Note #2: Special Login 07499 is used for 6-Cylinder Diesel Engine with 1LG Brakes and Multitronic. Note #3: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker. 0?xxx: Chassis 9 = Audi A4 0x?xx: Brakes 2 = Brembo 17" (PR-1LJ) 3 = FN3 16" (PR-1LT/1LF) 4 = HP2 16" (PR-1LX) 4 = FNR 16" (PR-1LA/1LG) 5 = FN3 15" (PR-1LB/1LE) 6 = C54 (PR-1LZ) 0xx?x: Engine 5 = 4/6 Cyl. Diesel 7 = 4/5 Cyl. Gasoline 9 = 6/8 Cyl. Gasoline 0xxx?: Transmission 5 = Manual 7 = Automatic (5HP19, 5HP24, AG4, AG5) 9 = Multitronic (01J, CVT) Coding Note #1: Coding is accepted after a specific login has been carried out. Note #2: After successful coding the steering angle sensor basic setting needs to be carried out. Note #3: Special Coding 04499 is used for BFB Engine with 1LT Brakes and Multitronic. Note #4: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker. Note #5: In some cases, you will need to enter a non-zero WorkShop Code, such as 12345. 0?xxx: Chassis 4 = Audi A4 0x?xx: Brakes 1 = C54 (PR-1LZ) 2 = FN3 15" (PR-1LB/1LE) 3 = HP2 16" (PR-1LX) 3 = FNR 16" (PR-1LA/1LG) 4 = FN3 16" (PR-1LT/1LF) 5 = Brembo 17" (PR-1LJ) 0xx?x: Engine 5 = 4/6 Cyl. Diesel 7 = 4/5 Cyl. Gasoline 9 = 6/8 Cyl. Gasoline 0xxx?: Transmission 5 = Manual 7 = Automatic (5HP19, 5HP24, AG4, AG5) 9 = Multitronic (01J, CVT) Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
siemian 126 Opublikowano 26 Lipca 2011 Udostępnij Opublikowano 26 Lipca 2011 Panowie mam małe pytanko, czy po przekładce z 288mm na 320mm trzeba również zmieniać kodowanie tempomatu kojarzę, że coś tam chyba było o hamulcach ale może dla tempomatu ta zmiana nie robi różnicy :?: :?: :?: nic nie zmieniasz Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Młody_drog 21 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 Jakie 16" felgi wejdą na te moje heble 320/288? od b7 2.0tfsi Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kileeer 0 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 Jakie 16" felgi wejdą na te moje heble 320/288? od b7 2.0tfsi zależy jaki masz te 16", Ja mam uc**jałe biedrony to wchodzą Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Młody_drog 21 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 Jakie 16" felgi wejdą na te moje heble 320/288? od b7 2.0tfsi zależy jaki masz te 16", Ja mam uc**jałe biedrony to wchodzą Przecież o to pytam Chcę kupić fele na zimę i nie wiem jakie kupić Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kileeer 0 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 Jakie 16" felgi wejdą na te moje heble 320/288? od b7 2.0tfsi zależy jaki masz te 16", Ja mam uc**jałe biedrony to wchodzą Przecież o to pytam Chcę kupić fele na zimę i nie wiem jakie kupić To biedrony wchodzą Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
spetsnaz 2 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 no taaaakkkkk.... ale kto bogatemu zabroni...[br]Dopisany: 16 Lipiec 2011, 21:11_________________________________________________mały up-grejdzik :wink4: tłoczki wykonane w 100% ze stali nierdzewnej za kilka dni zagoszczą w zaciskach 312mm jednego z Kolegów z forum :> :> :> :> Super opcja, jaki koszt standardowych 57? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Młody_drog 21 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 http://cars.donedeal.ie/for-sale/carextras/2369504 Takie wejdą mi? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kileeer 0 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 http://cars.donedeal.ie/for-sale/carextras/2369504 Takie wejdą mi? tak, ja mam z et43 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Dev 1477 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 no taaaakkkkk.... ale kto bogatemu zabroni...[br]Dopisany: 16 Lipiec 2011, 21:11_________________________________________________mały up-grejdzik :wink4: tłoczki wykonane w 100% ze stali nierdzewnej za kilka dni zagoszczą w zaciskach 312mm jednego z Kolegów z forum :> :> :> :> Super opcja, jaki koszt standardowych 57? to zalezy dla kogo.... :wink4: :wink4: zdradzę Ci Kolego że sam koszt wytworzenia kompletu razem z materiałem to 100zł ;( ;( ;( ;( ;( jestes zainteresowany zakupem ? info na PW Młody_drog, w tym poscie sa foty felg które "przyjmują" 320mm tarcze wystarczy poszukac :wink4: Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Młody_drog 21 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 uups Ale tutaj jest 145 stron, wszystkie mam przejrzeć? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
spetsnaz 2 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 zdradzę Ci Kolego że sam koszt wytworzenia kompletu razem z materiałem to 100zł ;( ;( ;( ;( ;( jestes zainteresowany zakupem ? info na PW Cena jest ok, będę zawracał gitarę przy najbliższej okazji. Przy naszych realiach mało osób będzie zadawało sobie sprawę ze skuteczności tego moda. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kileeer 0 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 tutaj masz jakie wchodzą, kolega Jarol napisał http://www.a4-klub.pl/smf/index.php?topic=29591.825 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Młody_drog 21 Opublikowano 27 Lipca 2011 Udostępnij Opublikowano 27 Lipca 2011 tutaj masz jakie wchodzą, kolega Jarol napisał http://www.a4-klub.pl/smf/index.php?topic=29591.825 hmm na tej stronie nie ma wypowiedzi Jarol'a Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kileeer 0 Opublikowano 28 Lipca 2011 Udostępnij Opublikowano 28 Lipca 2011 Pod te felgi na 100% wchodzi: Pierwsza ma ET45 pozostałe ET42 Aha ja mam zaciski z A6 3,0TDi a one są troszke szersze od tych co są w A4 B7 i S4 B6,B7 jak to nie ma :> Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Dev 1477 Opublikowano 28 Lipca 2011 Udostępnij Opublikowano 28 Lipca 2011 wchodza tez na 16" z B7 ale nie moge znalesc foty :mysli: Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kkam 50 Opublikowano 28 Lipca 2011 Udostępnij Opublikowano 28 Lipca 2011 wchodzą też na takie ET42 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
SID 0 Opublikowano 28 Lipca 2011 Udostępnij Opublikowano 28 Lipca 2011 No i są chyba pierwsze w PL tarcze Zimmermann'a Sport dla Audi S4 B6 345x30 mm :> Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Dev 1477 Opublikowano 28 Lipca 2011 Udostępnij Opublikowano 28 Lipca 2011 jakie koszta ? Na tyl 330/22 mm tez masz perforowane ? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
