maxus24 Opublikowano 4 Maja 2012 Opublikowano 4 Maja 2012 witam znalazlo mi pare bledow czy ktos moze napisac co oznaczaja ? jeden to cos z czujnikiem plynu chlodzacego tylko ktory? z gory dziekuje i pozdrawiam VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 909 557 H Component: 2.0L R4/5VS 0002 Coding: 0011501 Shop #: WSC 63351 3 Faults Found: 17545 - Fuel Trim: Bank 1 (Add): System too Rich P1137 - 002 - Lower Limit Exceeded - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 002 - Lower Limit Exceeded - Intermittent 16502 - Engine Coolant Temp. Sensor (G62): Signal too High P0118 - 002 - Lower Limit Exceeded Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04275 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 L Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul RDW 0416 Coding: 01101 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00011 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 900 L Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00000 Shop #: WSC 21023 WAUZZZ8E33A319860 AUZ6Z0B0463257 No fault code found. Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BD Component: Komfortgerát TBF 1411 Coding: 06730 Shop #: WSC 63351 6 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01573 - Alarm triggered by Door Contact Switch: Left Rear 35-00 - - 01366 - Opened Due to Crash Signal 36-10 - Open Circuit - Intermittent 00955 - Key 1 35-10 - - - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 195 C Component: symphony II NP2 0151 Coding: 01001 Shop #: WSC 63481 No fault code found. Address 76 ------------------------------------------------------- Controller: 8Z0 919 283 A Component: Parkingsyst. A4 RDW D09 Coding: 00104 Shop #: WSC 63351 No fault code found. End -------------------------------------------------------
fahur Opublikowano 4 Maja 2012 Opublikowano 4 Maja 2012 Czy masz w tej chwili jakiś problem z chłodzeniem? Jeżeli nie, to skasuj błędy, przejedź z 500km i wklej tutaj, to co Ci wyskoczy - wtedy będzie można coś więcej powiedzieć.
maxus24 Opublikowano 4 Maja 2012 Autor Opublikowano 4 Maja 2012 Czy masz w tej chwili jakiś problem z chłodzeniem?Jeżeli nie, to skasuj błędy, przejedź z 500km i wklej tutaj, to co Ci wyskoczy - wtedy będzie można coś więcej powiedzieć. ---------- Post dopisany at 12:00 ---------- Poprzedni post napisany at 12:00 ---------- tak problem jest taki ze odrazu po uruchomieniu samochodu wlacza sie wentylator od chlodnicy i silnik niechce sie rozgrzac do 90 stopni znaczy sie rozgrzewa sie ale bardzo pozno okolo 10 kilometrow przejechalem i dopiero bylo 90 stopni i przedtem check engine swiecilo ale zgasnelo na drugi dzien
opfikon Opublikowano 4 Maja 2012 Opublikowano 4 Maja 2012 Odnosnie 17545 - Fuel Trim: Bank 1 (Add): System too Rich Sprawdz jakie masz koretky mieszanki, blok pomiarowy 032. Pamietaj, ze po skasowaniu beledow beda tam zera.
maxus24 Opublikowano 4 Maja 2012 Autor Opublikowano 4 Maja 2012 a wie ktos czy ten czujnik (16502 - Engine Coolant Temp. Sensor (G62): Signal too High) to niejest przypadkiem ten za silnikiem przy podszybiu ? taki zielony czujnik zblokowany na zawleczke /spinke ?
fahur Opublikowano 4 Maja 2012 Opublikowano 4 Maja 2012 a wie ktos czy ten czujnik (16502 - Engine Coolant Temp. Sensor (G62): Signal too High) to niejest przypadkiem ten za silnikiem przy podszybiu ? taki zielony czujnik zblokowany na zawleczke /spinke ? Po prawej stronie, jak stoisz przed samochodem, na dolnej rurze wody wychodzącej z chłodnicy.
maxus24 Opublikowano 7 Maja 2012 Autor Opublikowano 7 Maja 2012 a wie ktos czy ten czujnik (16502 - Engine Coolant Temp. Sensor (G62): Signal too High) to niejest przypadkiem ten za silnikiem przy podszybiu ? taki zielony czujnik zblokowany na zawleczke /spinke ? Po prawej stronie, jak stoisz przed samochodem, na dolnej rurze wody wychodzącej z chłodnicy. a jai ten czujnik ma numer zebym go mogl kupic ?---------- Post dopisany at 12:53 ---------- Poprzedni post napisany at 12:53 ---------- a wie ktos czy ten czujnik (16502 - Engine Coolant Temp. Sensor (G62): Signal too High) to niejest przypadkiem ten za silnikiem przy podszybiu ? taki zielony czujnik zblokowany na zawleczke /spinke ? Po prawej stronie, jak stoisz przed samochodem, na dolnej rurze wody wychodzącej z chłodnicy. a jaki ten czujnik ma numer zebym go mogl kupic ?---------- Post dopisany 07-05-2012 at 09:17 ---------- Poprzedni post napisany 05-05-2012 at 12:53 ---------- Odnosnie 17545 - Fuel Trim: Bank 1 (Add): System too RichSprawdz jakie masz koretky mieszanki, blok pomiarowy 032. Pamietaj, ze po skasowaniu beledow beda tam zera. a czy te korekty moga miec cos wspolnego z tym ze mam instalacje LPG ?---------- Post dopisany at 09:17 ---------- Poprzedni post napisany at 09:17 ---------- Odnosnie 17545 - Fuel Trim: Bank 1 (Add): System too RichSprawdz jakie masz koretky mieszanki, blok pomiarowy 032. Pamietaj, ze po skasowaniu beledow beda tam zera. a czy te korekty moga miec cos wspolnego z tym ze mam instalacje LPG ?
opfikon Opublikowano 7 Maja 2012 Opublikowano 7 Maja 2012 Na LPG beda zapwnie inne niz na Pb. Najlepiej skasuj blad, pojezdzij na Pb i sprawdz.
maxus24 Opublikowano 11 Maja 2012 Autor Opublikowano 11 Maja 2012 kurde wymienilem ten czujnik na dolnym wezu od chlodnicy i wentylator ten po prawej od kierowcy dalej sie kreci , malo powiedziane ze kreci on wyje jak wsciekly nawet na zimnym silniku rano zaraz po odpaleniu samochodu , wie ktos co to moze byc ?
mloody_s-line Opublikowano 11 Maja 2012 Opublikowano 11 Maja 2012 u mnie np ten wentylator jak patrzę z przodu na auto to wciąż się kręci. Czy auto zimne czy nie zawsze się kręci. I niby tak jest dobrze. Natomiast ten z lewej włącza się jak załączysz klime albo auto się Zagrzeje. Ale to potrzeba czasu. Jak kupiłem auto to chciałem go Zagrząc i nici. Chodził ok godz i wentylator się nie załączyl. Ale na krótko podłączyłem to działa. ---------- Post dopisany at 23:07 ---------- Poprzedni post napisany at 23:01 ---------- a jeżeli kręci i wyje to wisko jest zepsute pewnie. Idzie to sprawdzić samemu jeżeli będzie dobre to jak przytrzymasz śmigi i drugi odpali to nie będzie się kręcił. A jak jest zepsuty to Ciężko ci będzie go zatrzymać. Uważaj na ręce. Jak coś źle napisałem to Proszę mnie poprawić. ---------- Post dopisany at 23:07 ---------- Poprzedni post napisany at 23:07 ---------- a jeżeli kręci i wyje to wisko jest zepsute pewnie. Idzie to sprawdzić samemu jeżeli będzie dobre to jak przytrzymasz śmigi i drugi odpali to nie będzie się kręcił. A jak jest zepsuty to Ciężko ci będzie go zatrzymać. Uważaj na ręce. Jak coś źle napisałem to Proszę mnie poprawić.
maxus24 Opublikowano 12 Maja 2012 Autor Opublikowano 12 Maja 2012 hmm a czy jesli by bylo zepsute wisko to czy by sie wylaczalo bo to sie wylacza po jakims czasie ,czy moze caly czas by krecilo ? no i dlaczego jest ten blad od czujnika ? mam pytanie na jakim blocku w silniku 2,0 ALT mozna sprawdzic vagiem temp bo w engine i 07 niemam nic ? jakie blocki przeskanowac w 2,0 ALT ?
