Bardzo proszę o analizę błędów
dzis jesze raz przeskanowalem auto i tak pokazalo:
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 A
Component: VSG B6 CABRIO 6792
Shop #: WSC 00672 785 00200
VCID: 346318E32EAB
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermitten
z tego co wynika to brak kontaktu z czujnikiem J527 gdzie on sie znajduje???
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 K
Component: Komfortgerát T3B 5040
Coding: 06799
Shop #: WSC 00672
VCID: 3C7330C306FB
Part No: 8H2959802D
Component: Tõrsteuer.FS BRM 0205
Part No: 8H2959801B
Component: Tõrsteuer.BF BRM 3020
Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 03111
Shop #: WSC 00672
VCID: 418D41376119
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
01303 - Telephone Transceiver (R36)
49-10 - No Communications - Intermittent
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Control Module Part Number: 8E0 919 283 D HW: 8E0 919 283 D
Component and/or Version: Parkhilfe 4-Kan H06 0010
Software Coding: 0001024
Work Shop Code: WSC 00672 785 00200
VCID: 316D11F7D1B9
2 Faults Found:
01549 - Supply Voltage for Parking-Aid Sensor
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 7
Reset counter: 91
Time Indication: 0
OBJAWY SA TAKIE ZE JAK WLONCZAM WSTECZNY BIEG DLUGO PISZCZE I POTEM CISZA I WOGOLE NIE DZIALA
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8E0 910 115 Q HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0030
Software Coding: 011C000302070020
Work Shop Code: WSC 00694 210 83224
VCID: 2F69178FC78D
2 Faults Found:
001602 - Sensor Reference Voltage A: Circuit: Low
P0642 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 142390 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Temperature: 68.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.192 V
012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 142390 km
Time Indication: 0
Czujnik cofania tylny lewy-od środka nie działa. A poza tym to nie są logi tylko błedy.
dziex:) tyle to wiedzialem ale jest taka mozliwosc ze jeden przestal dzialac i calosc nie dziala???
tak własnie jest jak jeden nie trybi to i reszta nie chodzi
dziex:) ma ktos pomysl na inne bledy?? SZCZEGOLNIE TE OD SILNIKA :):)
