[B5 ADP] Moje pierwsze logi
witam ponownie mam nadzieje ze te logi sa teraz ok prosze o zerkniecie i ocena dziekuje i pozdrawiam
Group A: '003 Group B: Not Running Group C: Not Running
Engine Air Throttle Ignition
TIME Speed Mass Flow Angle Timing TIME TIME
MARKER STAMP /min V ーC ーC STAMP STAMP
0.39 840 13.600 99.0 19.5
0.78 840 13.668 99.0 19.5
1.20 840 13.736 99.0 19.5
1.57 840 13.736 99.0 19.5
1.89 840 13.600 97.5 19.5
2.20 880 13.668 97.5 19.5
2.51 880 13.736 99.0 19.5
2.85 840 13.736 99.0 19.5
3.16 880 13.668 99.0 19.5
3.49 840 13.600 99.0 19.5
3.76 840 13.668 99.0 19.5
4.06 840 13.736 99.0 19.5
4.32 840 13.736 99.0 19.5
4.59 840 13.736 99.0 19.5
4.86 840 13.600 99.0 19.5
5.13 840 13.668 99.0 19.5
5.39 840 13.668 99.0 19.5
5.64 840 13.736 99.0 19.5
5.91 840 13.668 99.0 19.5
6.18 840 13.668 99.0 19.5
6.44 840 13.668 99.0 19.5
6.70 840 13.736 99.0 19.5
6.95 840 13.736 99.0 19.5
7.23 840 13.736 99.0 19.5
7.50 840 13.668 99.0 19.5
7.77 840 13.668 99.0 19.5
8.05 840 13.668 99.0 19.5
8.32 840 13.736 99.0 19.5
8.60 840 13.736 99.0 19.5
8.92 840 13.600 99.0 19.5
9.33 840 13.532 99.0 19.5
9.74 840 13.668 99.0 19.5
10.18 840 13.736 99.0 19.5
10.60 840 13.736 99.0 19.5
11.01 840 13.668 99.0 19.5
11.42 840 13.668 99.0 19.5
11.86 840 13.736 99.0 19.5
12.30 840 13.668 99.0 19.5
12.75 840 13.736 99.0 19.5
13.20 840 13.736 99.0 19.5
13.66 840 13.736 99.0 19.5
14.11 840 13.736 99.0 19.5
14.51 1640 13.736 99.0 19.5
14.92 2320 13.532 99.0 19.5
15.23 3000 13.600 99.0 19.5
15.55 3040 13.600 99.0 19.5
15.87 2600 13.600 99.0 19.5
16.16 3120 13.668 99.0 19.5
16.43 4080 13.600 99.0 19.5
16.72 3920 13.600 97.5 19.5
16.97 3520 13.600 99.0 19.5
17.22 3120 13.600 99.0 19.5
17.49 2760 13.600 99.0 19.5
17.78 2400 13.668 99.0 19.5
18.05 2040 13.600 99.0 19.5
18.32 1720 13.668 99.0 19.5
18.58 1440 13.668 99.0 19.5
18.83 1200 13.736 99.0 19.5
19.10 1000 13.668 99.0 19.5
19.36 880 13.736 99.0 19.5
19.63 800 13.736 99.0 19.5
19.90 800 13.668 99.0 19.5
20.16 840 13.668 99.0 19.5
20.46 800 13.668 99.0 19.5
20.75 800 13.668 99.0 19.5
Monday 30 June 2008 21:13:24
8D0 907 557 B 1.6L R4/2V MOTR HS D08
Group A: '007 Group B: Not Running Group C: Not Running
Lambda Voltage Duty Cycle (no units)
TIME TIME TIME
MARKER STAMP % V % STAMP STAMP
0.02 -2.3 0.800 3.1 1.02
0.23 -0.8 0.125 3.1 1.02
0.49 0.0 0.105 3.5 1.02
0.74 -2.3 0.780 3.5 1.02
1.01 -3.1 0.830 3.5 1.02
1.27 -3.9 0.760 3.5 1.02
1.52 -0.8 0.080 3.5 1.02
1.79 0.0 0.090 3.5 1.02
2.06 0.8 0.115 3.5 1.02
2.33 -0.8 0.745 3.5 1.02
2.60 -1.6 0.815 3.5 1.02
2.87 -3.1 0.595 3.5 1.02
3.14 0.8 0.095 3.5 1.02
3.42 1.6 0.705 3.9 1.02
3.72 -2.3 0.815 3.9 1.02
4.05 -3.1 0.755 3.9 1.02
4.41 -0.8 0.100 3.9 1.02
4.82 0.8 0.200 3.9 1.02
5.22 -2.3 0.785 3.9 1.02
5.64 0.0 0.080 3.9 1.02
6.09 1.6 0.095 4.3 1.02
6.52 -0.8 0.795 4.3 1.02
6.96 -2.3 0.790 4.3 1.02
7.39 0.8 0.085 4.3 1.02
7.83 1.6 0.655 4.3 1.02
8.28 -2.3 0.795 4.3 1.02
8.71 0.8 0.100 4.3 1.02
9.16 -2.3 0.855 85.9 1.02
9.54 -3.1 0.120 3.5 1.01
9.89 0.8 0.805 42.6 1.00
10.21 1.6 0.030 4.7 1.00
10.50 -3.1 0.845 33.2 1.00
10.79 1.6 0.050 3.5 1.00
11.11 0.0 0.020 0.0 1.00
11.42 0.0 0.005 0.0 1.00
11.71 0.0 0.000 0.0 1.00
11.98 0.0 0.000 0.0 1.00
12.25 0.0 0.000 0.0 1.00
12.52 0.0 0.000 0.0 1.00
[br]Dopisany: 01 Lipiec 2008, 15:53 _________________________________________________Proszę, niech ktoś na to zerknie :)
Siemka :hi:
A reszta ? :confused4:
Jeszcze chyba?001-002-005-008-010
Chyba??????????? :wink4:
Pozdrawiam :audi:
PS. wysłałem ci ściąge :confused4: :confused4:
witam widze ze nie ma zainteresowanch sprawdzeniem moich lkogow??co jest prosze :wallbash:
zakres pracy sondy (grupa 007):
Lambda % = -10% ... 10%
Voltage = -0,1 ... +1,1V
Jak widać Twoja sonda jest bardzo słabiutka, nadaje się do wymiany.
Jesli wychodzi poza 0,7V to jest mieszanka za bogata, jeśli jest poniżej 0,3 to mieszanka jest uboga.
U ciebie wyskakuje poza regulację.
Dobrze piszę mateo ?
Poza tym, niecierpliwisz się, poganiasz innych...
znalazłem taki wątek :
http://www.a4-klub.pl/smf/empty-t9021.0.html;highlight=007
(ale są też inne)
ponownie sonda jest nuwka boscha za prawie 350 zl
jaki numer miała stara, a jaki numer ma nowa ? Gdzie kupiłeś ?
witam stara byla zamienikiem a nowa jest kupiona w auto landzie w olsztynie !!bosch z kablem do mojego silnika nr 058 003 478
:hi:
No chyb że się myle :mysli:
Popraw pre
PS. no i znowu okaże się że wywalone pieniążki w k...ę
A u kogo brałeś w "AL" jak można wiedzieć?
Sonda jest ok, tak samo jak ładowanie :tongue4: Coś się dzieje z autem czy szukasz dziury w całym?[br]Dopisany: 03 Lipiec 2008, 21:03 _________________________________________________
Voltage = 0,1 ... +1,1V
Sonda musi oscylować to objaw poprawnej pracy. Sonda uboga, korektor procentowy (%) rośnie (idzie na plus), sonda bogata, korektor maleje (idzie na minus). Wyjątkiem jest "cut-off" kiedy hamujemy silnikiem, wtedy przy zamkniętych wtryskach sonda stanie na ubogiej i tryb "wzbogacenia" kiedy idziemy pełną mocą, wówczas sterownik przestaje regulować mieszankę od sondy podając taką ilość paliwa żeby cały czas było bogato.
Przemek, sprawna sonda nie stanie na wartości mieszanki idealnej, to jest poprostu fizycznie niemożliwe!
witam uff kamien z serca .dzieje sie to ze auto pali jak smok 11 lit na 70 kil ??to troche sporowo mieniony filtr paliwa powietrz nowe swiece.
Jutro rano ma do mnie przyjechać ADP na diagnostykę to wrzucę na które grupy zwrócić uwagę (bo nie pamiętam), napewno 008 statycznie.
ok bedzie fajnie.mam z 08 ale krutki.
Thursday 3 July 2008 15:53:10
Group A: '008 Group B:
Time Lambda Lambda
TIME TIME
MARKER STAMP ms % % STAMP
0.01 2.92 0.0 0.8 TankVent ON
0.27 2.92 0.0 0.8 TankVent ON
0.55 3.01 0.0 0.8 TankVent ON
0.84 2.84 0.0 0.8 TankVent ON
1.10 2.75 0.0 0.8 TankVent ON
1.37 2.84 0.0 0.8 TankVent ON
1.63 2.92 0.0 0.8 TankVent ON
1.91 2.92 0.0 0.8 TankVent ON
2.17 2.84 0.0 0.8 TankVent ON
2.42 2.84 0.0 0.8 TankVent ON
2.67 2.75 0.0 0.8 TankVent ON
2.93 2.92 0.0 0.8 TankVent ON
3.19 2.92 0.0 0.8 TankVent ON
3.45 2.84 0.0 0.8 TankVent ON
3.71 2.75 0.0 0.8 TankVent ON
3.98 2.92 0.0 0.8 TankVent ON
4.25 2.92 0.0 0.8 TankVent ON
4.55 2.92 0.0 0.8 TankVent ON
4.84 2.84 0.0 0.8 TankVent ON
5.12 2.75 0.0 0.8 TankVent ON
5.41 2.84 0.0 0.8 TankVent ON
5.73 2.84 0.0 0.8 TankVent ON
6.17 2.92 0.0 0.8 TankVent ON
6.60 2.84 0.0 0.8 TankVent ON
7.01 2.84 0.0 0.8 TankVent ON
7.43 2.92 0.0 0.8 TankVent ON
7.87 2.75 0.0 0.8 TankVent ON
8.31 2.84 0.0 0.8 TankVent ON
8.73 2.92 0.0 0.8 TankVent ON
9.18 2.75 0.0 0.8 TankVent ON
9.62 2.92 0.0 0.8 TankVent ON
10.08 2.92 0.0 0.8 TankVent ON
10.49 2.84 0.0 0.8 TankVent ON
10.82 2.84 0.0 0.8 TankVent ON
11.15 2.92 0.0 0.8 TankVent ON
no, coś czułem że mogłem pokręcić, dlatego wolałem wywołać Ciebie do tablicy :)
No, że oscylować to ok, ale nie sądziłem że aż tak mocno.
Allleee, teraz sobie przypominam, że u mnie w AGNie to było nawet 0,8V - dobrze pamiętam Mateusz ?
No to żem pokręcił wtedy całkowicie :)
:good:[br]Dopisany: 03 Lipiec 2008, 21:51 _________________________________________________
Nie dojechał kartofel jeden :angry:
Dorzuć 004 statycznie oraz 002 statycznie i dynamicznie dla oceny przepływomierza. Swoją drogą zastanawiam się od wczoraj, jak dokonałeś pomiaru skoro podajesz spalanie na 70 km?
witam/ tankowanie pod korek przejechane 70km dotankowanie i wyszlo tyle,to zrobie je dzis ok 21,30 jak mi sie uda i wkleje je ,pozdrawiam
:shocked:
rany, ja myślałem że to była literówka i miało być 700km....
Wyjeździł chociaż cały bak i dopiero wtedy zacznij się martwić :)
no tak ale jak go kupilem zalalem 21 lit i przejechal 150 kil do rezerwy po miescie :)
:doh1: mało wiarygodny sposób. Spalanie należy mierzyć jako srednią z całego zbiornika, bo według Twojego pomiaru wychodzi prawie 16l/100km. Jest wręcz nieprawdopodobne żeby przy takim spalaniu auto poprawnie chodziło.
niestety ale tak jest w dzien jak go kupilem dziwnie sie zachowywal np przy gaszeni silnika dostawal jakby samo zaplonu i chodzil jeszcze chwilke naprawde pali jak smok tylko wlewam pb i wlewam
