Moja NIUNIA- 1.8t 150+ lublin
A4 1.8t Quattro, przebyte 252tyś. km. kolor LZ5L.
Wyposażenie-QL-
skrzynia biegów -CTF
numer napędu osiowego- 5S
typ handlowy -8D50H5
kolor dachu- Q5
data produkcji 23.03.1996r
model -Audi A4 av.qu. 1,8 A4Q
numer silnika- AEB
1E1-Activated carbon canister
4UE-Air bag for driver and front seat passenger
7AA-Electronic wehicle immobilization device
1C1-Antifreeze up to -25degree Celsius tolerance up to -30 degree C
T8B-4-cylinder gasoline engine 1.8l unit 058.D
J1P-Battery 220A (44Ah)
K8D-Station Wagon Variant/Avant
1LB-Disc Brakes, front
1AH-Elektronic Differential lock (EDL)
2K1-Reinforced bumpers
8KA-W/o catalytic converter warning light
8R1-Center high-mounted stop light
3C3-Lap belt with retractor for the center rear seat
B0A-Component parts set withgout country-specific design requirement
6FB-Body-colored extenor mirror housings
4M6-Cup holder
2A5-Delivery equipment (transit coating) with thin seat cover
4F1-Central Locking system
1X1-Four wheel drive
8Z2-Engine cooling system with heavy-duty fan and radiator
M9L-4-cyl. gasoline engine 1.8L/110kW 20V turbo, MVEG2 base engine is T8B/T8C
A8S-Standard equipment
0TD-Frotn and rear floor mats
6W5-Front license plate carrier
Q1D-Sports front seats
1Z0-Initial standard fuel filling
6R2-Leather gearshift boot
6Q2-Leather gearshift knob/handle
C03-Operating permit, alteration
8GD-Alternator 90A
FA0-Control of standard production
8TC-Rear fog light for driving on the right
3NZ-Rear seat bench unsplit, backrest split folding
6V1-Rear trim panel (ECE)
5RD-Right exterior mirror, aspherical (india)
4TB-Vanity mirror right
3S2-Black roof rails
0LK-Special plates/stickers/safety certificates for italy
3L3-Manual height adjustment for front seats
1BE-Sports suspension/shock absorption
3X1-Load-through provision with ski bag
1G3-Alloy spaer wheel with original equipment tires
8RE-4 speakers (passive)
E0A-No special ediotion
0SK-Labels/plates in Italian
8CC-Speedometer sensor whitout seal
L0L-Left-hand drive vehicle
2PV-Leather trimmed sports steering wheel
9W0-W/o car phone preparation/instalation
H6U-Tires 205/55 R16 91W
G0G-5 speed manual transmission for four-wheel drive vehicle
0G1-Gearshift lever
B99- Rype approval EC
2Z1-Type sign at rear and "Quattro" nameplates respectively
8BB-Halogen headlight for driving on the right
8Q1-Headlight-range adjustment
9X6-Heated door lock cylinder left with micro switch
9T1-Heated washer nozzles, front
9AK-Climatronic with impact pressure control free of cfc
1EX-Special identification plate for EC for M1 passenger vehicle
2G1-Insert for the filling up of unleaded fuel
5MS-Decorative burr walnut inserts
1VG-Installation parts four-cylinder engine
U1A-Instrument insert with km/h speedometer, clock, tachometer and trip odometer
0W1-Label for central electric German-speaking countries
3BK-Left exterior mirror: electrically adjustable/heated, electrically foldable, flat
4SB-Vanity mirror left
1PC-Wheel bolts with anti-theft protection (unlockable)
7P4-Manually adjustable lumbar suport in front seats
4ZE-Black moldings
0VG-Information kit in Italian
5K1-Paint preservative (wax)
8NB-Parking light indicator light
8AV-Radio
8S4-Two reading lights front, two rear
0DY-Instalation differentiation for build status of vehicle class B5 (AUDI) unit components
F0Y-Vehicle with optional features
C1L-Alloy Wheels 5,5Jx15
4R3-Power windows with comfort operation
4GH-Windshield in heat-insualting glass with sunshield
Plany
czerwone obszycia kierownicy plus nowa skórka-zrobione
czerwony mieszek i gałka własnego pomysłu-zrobione
czerwone przeszycia na siedzeniach i obszycie czerwoną nitką
wstawiony zegar ładowania turbo-zrobione
nowe hamulce w oryginale-klocki textar-tarcze gerling w ori rozmiarze-zrobione
zawieszka z S4-zrobione-do wymiany łączniki stab i wahacze dolne-wiosna mam nadzieje wymienię całość
zmieniona tapicerka-wstawione kubełki materiałowe czarne i boczki drzwiowe z S4 z carbonową listwą
Lampy z przodu ori S4 z kierunkami, ksenon, aktualnie szukam zdarzaka chcę przed lift ze spryskami
Felgi mam pięcioramienna gwiazdka jak na foto-planuję zmienić kolor pewnie grafit i czerwone kopytka, Szukam felg ori Audi ROTOR 18", były na forum ale sprzedane Ech...
wstawić ori radio CD Concert II,
wymiana panela klimy, nie świeci część i nie podświetla guziczków, poza tym działa
osłony silnika i skrzyni-zrobione
podłączenie światełek dziennych-ewentualnie wyrzucenie ich w ogóle-jeszcze myślę nad tematem,
czarna podsufitka i słupki z RS, dymione wewnętrzne lampki i reszta z tej wersji,
nowe siłowniki klapy bagażnika szt. 2-zrobione
folia carbon na dach, lusterka i grill, może jeszcze progi i ramki szyb z zewnątrz,
wydech 3" stal, rurka jest będzie wiosna będzie wydech,
stożek (już leży),
większe turbo- np. k04
zamontowana instalacja gaz Stag 4eco, reduktor ACR 01 wtryskiwacze zielone HANA,
Nowy sterownik po wirusie- zakupiony czeka na montaż ok.180 kucyków powinno być.
marzenie - siedzenia z RS4 -
---------- Post dopisany at 20:00 ---------- Poprzedni post napisany at 11:09 ----------
obiecane fotki na razie skromnie
światełka
mieszek new
kierowniczka
mieszek i gałeczka na miejscu
tapicerka siedzonek
Dzisiaj nieco brudne autko ale daje radę zrobiłem kilka fotek
[/color]znaczek na błotniku wyszedł o tak sobie
podświetlenie działa polutowane oczyszczone i świeci wszystkie elementy oryginał
mały dodatek a cieszy audi a4 cabrio
ciepełko autku w zimie i chłodno latem taki mały miejski garażyk ale zawsze nie leje się na głowę
Kolego więcej zdjęć by się przydało i jakieś plany co do A4 masz?
Bezawaryjności:wink:
zdjęcia zapodawaj w pierwszym poście by nie robić misz maszu :D by mieć porządek.
także zimno i brak miejsca w garażu ogrzewanym czas stanął narazie w miejscu
---------- Post dopisany 06-01-2014 at 21:11 ---------- Poprzedni post napisany 05-01-2014 at 21:11 ----------
Mimo utrudnień dzisiaj zrobione podświetlenie tablicy z tyłu i wymienione żaróweczki w trzecim świetle stop. Wszystko działa i w oryginale tak jak było.
---------- Post dopisany 07-01-2014 at 18:00 ---------- Poprzedni post napisany 06-01-2014 at 21:11 ----------
Ktoś się nie bał i zaje...ał znaczki z moich bocznych błotników z nazwą audi? ciekawe po cóż one komu potrzebne, chyba na złom na aluminium he he... Jutro podczepię coś w zamian i porobię foteczki zobaczymy jak wyjdzie wiec do jutra...
Wymieniony olej w tylnym dyferku MObil 75w90 i śmigamy dalej,
te znaczki to lancuchowo ida ktos ci podj.. i ten komu podj... podj... nastepnemu :grin:
czaję i tak miałem zamiar je usunąć ale nie w tym miesiącu he he.... Na razie zastąpiłem je czym miałem czyli znaczkiem @ zobaczycie jutro jak strzele fotki wyszło na razie wystarczająco do wiosny pojeżdżą a potem się ori wstawi. Dodałem pełny opis wyposażenia jak ktoś ciekaw zapraszam mogę pomóc w jego ustaleniu po nr VIN, mam kolege w warsztacie i ma odpowiedni program ja się na tym nie znam za bardzo więc skorzystałem
---------- Post dopisany 08-01-2014 at 14:25 ---------- Poprzedni post napisany 07-01-2014 at 18:56 ----------
---------- Post dopisany at 14:54 ---------- Poprzedni post napisany at 14:25 ----------
witam ponownie i jeszcze mam takie oto felgi z latem 215/45 R17 Good Year na razie srebrne ale będzie ciemny grafit + czerwone zaciski:)
Z tymi znaczkami to trochę wiocha:facepalm:
czy dobrze pacze ?
wytłoczenia w galce zmiany biegow potraktowales czerwonym ??????????:shock3:
tak czeronym tak sobie umyśliłem, a znaczki może i faktycznie wiocha ale na razie będą z braku laku
---------- Post dopisany 11-01-2014 at 19:20 ---------- Poprzedni post napisany 10-01-2014 at 20:47 ----------
Witam jako że nieco rysuję sobie czasem różne rzeczy postanowiłem sobie narysować RS4 w takiej fajnej wersji i wskoczyła ona na mój avatar. a oto jej normalny rozmiar
---------- Post dopisany at 19:21 ---------- Poprzedni post napisany at 19:20 ----------
Przepraszam, że jest boczkiem zawsze można pobrać - zapisać fotkę i przekręcić. Pozdro.
---------- Post dopisany at 19:28 ---------- Poprzedni post napisany at 19:21 ----------
A i najważniejsza sprawa właśnie zakupiłem sterownik do swojego wozu z wgranym wirusem na nieco ponad 180km, nie wiem ile ma Nm ale ciśnienie ładowania turbo oscyluje na poziomie nieco powyżej 0,8bara a nie jak w moim seryjnym przypadku 0,5-0,6bara. Wkładam w poniedziałek i dam znać jak zbiera się bryczka. Na pewno doleci mi drugi parownik bo mam obecnie ACR 01 czarny, wtryski pociągną bo mam hana zielone i sterownik Stag 4eco, ale wystarczy ciśnienie na parowniku nie wyrobi znając życie więc dorzucić mam plan drugi. Sterownik leży i czeka na montaż. Zdecydowanie poprawić się powinno odejście z piwnicy no ale się zobaczy.
---------- Post dopisany 12-01-2014 at 16:48 ---------- Poprzedni post napisany 11-01-2014 at 19:28 ----------
Dzisiaj autko umyłem i wieczorkiem dojdą nowe wlepki klubowe zdjęcia : ot taka mała sesyjka wieczorna po kąpieli
---------- Post dopisany 13-01-2014 at 23:36 ---------- Poprzedni post napisany 12-01-2014 at 16:48 ----------
Dzisiaj doszło wygłuszenie, zabawne ale koszt w ASO kołeczków tudzież spinek montażowych przewyższył koszty jego zakupu he he... już siedzi na aucie jutro wrzucę fotki...
---------- Post dopisany 14-01-2014 at 00:07 ---------- Poprzedni post napisany 13-01-2014 at 23:36 ----------
A tu pochwalę się czym kiedyś śmigałem...
zwał się mik mik córka tak go nazywała, miał ori hella przód, bez znaczków gwint MTS Technik, wydech z nierdzewki, motor 1.8 monowtrysk, miło go wspominam.
Później było Audi A6 C5 2.4V6 Quattro automat, biały skórzany środek, granatowe,
takie skromne mało ją widać ale coś tam znalazłem.
---------- Post dopisany at 22:50 ---------- Poprzedni post napisany at 00:07 ----------
dzisiaj zamontowano zawirusowany sterownik ładowanie wzrosło do 0,8bar a i dół zrobił się wyraźnie mocniejszy.... także pozytywnie. mam nadzieje, że wiosna się zhamuje ten wózek gdzieś na spocie.
Bardzo ładny rysuneczek :decayed:
Dzieki rysowane na szybko węgiel plus pastele. Jak Ci Twoje 2.6 się sprawuje?
---------- Post dopisany at 11:38 ---------- Poprzedni post napisany at 11:36 ----------
A w ogóle to mam pytanie co myślicie na temat czerwonych felg i znaczków bo środek czarny z czerwonymi obszyciami ma być jak wam się wydaje. Może ma ktoś zdjęcia jakiejś furki w takim zestawieniu. Dzięki za odpowiedzi
---------- Post dopisany 19-01-2014 at 14:43 ---------- Poprzedni post napisany 15-01-2014 at 11:38 ----------
ponawiam zapytanie co sądzicie o czerwonych felgach do mego wozidła czy raczej ciemny grafit i czerwone hample...
Grafit +czerwone zaciski
Hyper silver + czerwone zaciski.
No to ciekawe właśnie myślę o ściągnięciu wszystkich chromów z niej a zostały już tylko grill i znaczki więc i felgi pewnie pójdą w ciemny i czerwone zaciski zobaczymy. W lutym grill idzie do oklejania wybrałem zamiast carbonu popularny coraz bardziej ostatnio czarny połysk, znaczki folią też pociągnę z tyłu pewnie tylko kółeczka zostaną reszta zniknie. Ciemno będzie he
---------- Post dopisany 20-01-2014 at 21:56 ---------- Poprzedni post napisany 19-01-2014 at 23:58 ----------
postaram się niebawem zdemontować znaczki, jednak zastanawiam się czy w zimie to jest dobry pomysł żeby połowa klapy razem nie odstała. Może z modami zaczekam do wiosny. Jutro zdemontuję jakoś grill i porozbieram na części żeby koledze było łatwiej okleić i zobaczymy jak to wyjdzie. Ciekawe czy da się ściągnąć samą to chromową ramkę żeby czarne pozostało czy są tam jakieś mocowania czy da radę ją oderwać i zzostanie ładne czarne plastikowe robił to ktoś może
---------- Post dopisany 22-01-2014 at 23:00 ---------- Poprzedni post napisany 20-01-2014 at 21:56 ----------
witam jutro wrzuce foto ale dzisiaj podczas jazdy dmuchnęło benzyną z nawiewów i sieę okazało, że pękł przewód więc improwizowałem na mroze i zastąpiłem ori zacisk zwykłą opaską i na razie działa.
---------- Post dopisany 11-02-2014 at 08:42 ---------- Poprzedni post napisany 22-01-2014 at 23:00 ----------
Witam po długiej przerwie oto mały upgrade jaki sobie wykonałem w niedzielne popołudnie ale znaczek jednak wróci w srebro bo za ciemno wyszło
---------- Post dopisany at 08:44 ---------- Poprzedni post napisany at 08:42 ----------
Jak myślicie zostawić na czarno czy działać na chroma jak było obwódkę bym zostawił a znaczek folie zdjąć i chyba będzie ok co sądzicie
szukać polifta w dobrej kasie bo i tak kiedyś zmienisz :wink:
znaczek srebro bo tak to wygląda jak nie wiem co. :grin:
Witam po długiej przerwie. Więc tak ostatnio ściągnąłem okleinkę ze znaczka z przodu, wygląda lepiej także dzięki darek995 poza tym w sobotę 22.03.2014r zamontowałem nowe zawieszenie MasterSport włącznie z drążkami kierowniczymi LMO. Fotorelacja z zakładania poniżej. Dołożłem pilocik do centralki zamka pneumatycznego bo miałem tylko kluczyk. Działa świetnie. Odszczurzyłem nieco felgi na sezonik i wyszło fajnie bo wystarczyło je dobrze umyc i zostało mi jeszcze położyć na nie wosk. Do wymiany pozostała mi łapa tylnego dyfra i podpora wału w tym nowy wał wrzucam już wszystko razem. Malowanie lamp na czarno z przodu żółte długie w odblasku taki mam plan.
---------- Post dopisany at 17:43 ---------- Poprzedni post napisany at 17:35 ----------
ponadto wymieniłem zbiorniczek spryskiwacza z tyłu po peknięty był i teraz działa. Zamierzam pokryć dach czarna folią jeszcze a i dopasowano osłonę pod silnik i skrzynię, klima nabita, zostało odpływy posprawdzać jeszcze czy drożne bo nie wiem, Nabyłem też za niebagatelną kwotę 150zł oryginalny bagażnik dachowy do swojej laleczki z kluczem i w idealnym stanie. Wymienione też zostały świece na BERU Z188 Platin.
---------- Post dopisany 06-04-2014 at 00:35 ---------- Poprzedni post napisany 25-03-2014 at 17:43 ----------
dzisiaj na szybko wpadł nowy wał napędowy, uszczelniacze dyfra poduszka tylna i przenia dyfra, wyprostowano łapę mocowania bo ktoś zaczepił i wygiął podwozie ale dało rade. Teraz w końcu w aucie ciszaaaaa i jest zaje...fajnie. aktualnie poszukuję gwintu jakiegoś do mojej niuni. Jak ktoś cos słyszał proszę o info.
---------- Post dopisany 23-05-2014 at 09:16 ---------- Poprzedni post napisany 06-04-2014 at 00:35 ----------
witam dawno mnie nie było ale dzisiaj dodaję nowe foteczki z zakupionych felg 18" z oponkami 225/40 początkowo były takie ale zmieniłem na ROTA
---------- Post dopisany at 09:18 ---------- Poprzedni post napisany at 09:16 ----------
---------- Post dopisany at 09:21 ---------- Poprzedni post napisany at 09:18 ----------
mam do was prośbę może jakieś pomysły odnośnie koloru tych felg czy są ok, czy może np śrubki pociągnąc w inny kolorek czy środek czy coś czy może po prostu zostawić jak są. Mi sie w sumie nawet podobają.
no znaczek w końcu lepszy :)
co do podpory to jaką kupiłeś ? coś z allegro? i czemu wymieniałaś jaki był objaw ?:wink:
Felgi bym zostawił jak są bo moje zdanie jest takie by bawić się z kolorem felg jest sens gdy auto jest zrezane "grubo" a teraz to może zapodaj znaczek audi w dekielki i będzie ok.
A jakie mają et? bo wydaje mi się że trochę się chowają i można by dystans dać :decayed:
podorę dyfra czy wału bo w dyfer ktos zaje... al kiedys i tak zostawił była zgięta łapa więc wszystko wymieniłem od razu trafiło się bo kumpel rozwalił swoje b5 więc było jak znalazł a niedawno zmieniał więc podeszło wszystko od niego objaw to stukanie z lekkim przesuwaniem dyfra na poduszce. A felgi czy ja wiem może tył delikatnie poszerzę tez nad tym myslałem ale narazie tak zostanie może a dekielki fakt mogą być chociaż te też są fajne bo niewiele widziałem takich felg
---------- Post dopisany at 00:04 ---------- Poprzedni post napisany at 00:02 ----------
et mam 35 inne nie wejdzie w serii w quattro
