Montaż i działanie Audi Drive Select A4 B8 2007-2012
Mam ten sam problem
Chciałbym uruchomić ADS bez kabla przez green menu - auto polift z Q7Z
znalazłem opis
For MMI Cars Only.
It's not known how to enable the menu via VCDS yet so instructions are provided for enabling through the hidden menu. If you have not enabled the hidden menu yet go here
To get into the hidden menu in the MMI hold down the Car and Menu button for approx 6 seconds and the menu should appear on the screen.
If you can't enter the menu after a few attempts re-do the MMI Hidden Menu coding EVEN if the coding is correct. Change it to 0 and save then change it to 1 again. I've had to do this from time to time for no apparent reason.
Once the menu comes up scroll to Car and select it by pushing down on the scroll wheel.
Then Select cardevcelist
Scroll down the list until you see Charisma and select it.
Hit the back button until you are at the Car menu screen. Then Select canbusassignment:
Scroll down to Charisma and set the bus to [CAN Komfort] 1/9
Return back to the Car main menu and select carmenuoperation:
Scroll to Charisma and select it with the scroll wheel.
It will be set to 0 you will change it to 1 or 5 then push the scroll wheel to set it.
1 allows access while your not moving 5 allows access at all times.
We now need to rest the MMI. So go back to the starting menu and follow the procedure below to reset the MMI.
Now reset the MMI. This is done by pushing down the Setup – Scroll Wheel and top right menu buttons at the same time.
Once the MMI has reset, click on the car button and go to “Audi drive select.." menu.
Provided all the coding was done correctly you should now have the following screen in your MMI.
Nie da się bez kodowania, bo MMI nie jest w stanie grzebać w innych sterownikach co jest wymagane.
Edytowane przez komoornik
No niby czytam, ze mozna w polifcie ale nie znalazłem potwierdzenia bo nie widziałem w wątku osoby która by robiła przez zielone menu
NO to jakie jest w końcu kodowanie przez VCDS? i najważniejsze co zmieni,oprócz pracy układu kierowniczego?
Oprócz kodowania w 5F ( w green menu) podstawa to kodowanie w MCE 09 oraz sterownik 44 * elektryczny uklad kierowniczy
Jest sens w polifcie (2013) kodować ADS jeśli mam manualną skrzynię i zawieszenie 1BA (standardowe)?
Chodzi mi o praktyczne opinie osób, którzy mają taką wersję i dodali sobie ADS w VCDS.
Wyczytałem, że skoro mam elektryczny układ kierowniczy to w danych trybach będzie czuć na kierownicy. A poza tym coś w dynamice?
Zastanawiam się po prostu czy się bawić w kodowanie.
Edytowane przez rafaell68
Oczywiście ze odczujesz przy silniku i wspomaganiu 44
A to kodowanie to jakiś wysiłek?
Robić.
Mam pytanie, ponieważ nie znalazłem w temacie: Czy jak uruchamiam ADS tylko dla silnik i servotronic (bez przycisków na konsoli) czy w adaptacjach muszę zmienić wartość na "4" we wszystkich kanałach tzn:63,64,65,66, czy tylko we dwóch wybranych?
Te wartości to tylko domyślne ustawienie dla poszczególnych kluczy.
rozumiem, ale który odpowiada z konkretną funkcję. jak np nie mam regulowanego zawieszenia to nie muszę tego ustawiać.
To nie ma nic do rzeczy. Jak ustawisz 1 to po odpaleniu auta bedziesz miał komfort, jak 3, to dynamic. Tylko tyle. Kodowanie poszczególnych komponentów to inna sprawa.
O.K, wszystko działa. Dzięki.
Pomocy, potrzebuję schematu do podłączenia wiązki do przycisku ADS w a4 b8 avant 2008, radio concert.
Przycisk na konsoli centralnej
Panowie u mnie po zakodowaniu ADS mam tylko silnik i uklad kierowniczy do regulacji. Niestety nie mam opcji zmiany trybu pracy skrzyni(tiptronic)
a czy przypadkiem zmiana trybu pracy skrzyni nie dotyczy tylko s-tronic'a?
Nie wiem wlasnie. Tez tak przypuszczalem ale w opisie z 1 szej strony jest tylko napisane, ze kodujemy w przypadku automata. Nie ma rozroznienia na tiptronic, stronic czy multitronic.
Nie. Ja mam Multitronic i charakterystyka skrzyni też się zmienia. Co prawda polega to tylko na tym, że w trybie Dynamic skrzynia przełącza się na tryb sportowy, ale działa ;)
