[ALL B5] Kody wyposażenia - prośba o przetłumaczenie
strone wczesniej wkleilem linki z kodami-przejrzyj,a co do wklejki,to na jednym linku jest wzor,chyba od jakiegos paska,pewnie bedzie lepiej jak,ktos aklei ci fotke z konkretnego rocznika :wink4:
Szanowni koledzy, bardzo proszę o przetłumaczenie moich kodów. Z góry dziekuję:)
E0A - no special edition
4UE - airbag f. driver a. front seat passenger
6XC - outer rear view mirrors: powered
5SL - outer left rear view mirror: non-spherical
5RQ - outer right rear view mirror: convex
1KD - disc brakes, rear
JOR - battery 380 A (80 Ah)
1LB - disc brakes, front
4LA - without controls
1AC - anti-lock brake system (ABS)
1BA - standard suspension/shock absorption
3FA - without roof insert (standard roof)
5MY - decorative aluminum inserts "stars graphite"
7X0 - without park distance control
4R2 - power windows front, mechanical window regulators rear
FOY - vehicle with optional features
0L2 - electric throttle actuation
8GL - alternator 120A
0G1 - gearshift lever
0YF - weight category rear axle weight range 6
0JF - weight category front axle weight range 6
T1R - components for base engine, unit 028.R
3NZ - rear seat bench unsplit, backrest split folding
8JG - headlight with gas discharge lamp for driving on the right
V1A –
X0A - national sales program Germany
2PG - steering Wheel
8Q2 - automatic headlight-range adjustment static
9Q0 - without multi-function indicator/ on-board computer
8Z5 - engine cooling system, type 1
M6N - 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
7Q0 - without navigation device
C8N - alloy wheels 6J x 15 style not designated; 4B0 601 025 L offset 45
7K0 - without tire pressure warning light
4X3 - side airbag front with curtain airbag
2K1 - reinforced bumpers
6R1 - leatherette gearshift BOOT
3L1 - manual height adjustment for left front seat
3Y0 - without roll-up sun screen
4K4 - radio remote controlled central locking operated from inside and separate trunk release
5D1 - carrier frequency 433.92 MHz
1SA - without additional engine guard
Q1A - standard front seats
4GH - windshield tinted with windshield sunshield
V1A –
wiekszosc tych kodow jak nie wsystkie sa juz w tym temacie przetlumaczone :disgust:
Te mi zostały i nie jestem pewien co do nich. możecie pomóc? chodzi mi o dokladne tłumaczenie.
1MU = Leather trimmed sports steering wheel for air bag system with Tiptronic
4KC = Side and rear windows in heat-insulatingglass
6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated
9Q4 = Multi-function display/on-board computerwith check control - FIS
0YL = Weight range 11 installation control only, no requirement forecast
MR1 = 6-cyl. diesel engine 2.5 L/132 kW 24V TDI with fuel distributor injection pumpbase engine is T1K/T5T
1N1 = Power steering
Jak gdzieś je przeoczyłem to sory. z góry dzięki
szybki boczne i tylna atermiczne
lusterka zewn. elektrycznie składane, elektrycznie ustawiane i podgrzewane
Wspomaganie
PS. Widzę że sporo osób ma z tym problemy ;)
4KC Зеленое теплозащитное остекление
http://www.vwgolf-club.ru/forum/viewtopic.php?p=71766&highlight=&sid=0c5857a8597c205e9f579fbecebc1f72
http://audi-club.ru/forum/showthread.php?t=57568&page=12
Co do Fis i Grzanych foteli to moje auto rowniez to ma a w kodach o tym cisza jak rowniez o pompowanych ledzwiach.
A teraz troszke inne pytanie:
8RY = speakers with BOSE sound czy to oznacza ze powinno byc naglosnienie BOSE? mam 8 glosnikow i wzmacniacz lecz na oslonach glosnikow nie ma BOSE i glosniki tez jakos slabo wygladaja. chyba ktos podmienil:\
Moze ma ktos fotki jak powinien wygladac sprzet odpowiadajacy temu kodowi? Auto z 95 roku.
I jak to jest wkoncu z tymi kodami? Bo jak juz wyzej pisalem mam bogatsze wyposazenie niz wynika z wlepki.
Witam.
Panowie pewnie uznacie pytanie za debilne, ale gdzie są zapisane te kody? Tylko te z naklejki w komorze zapasu? Wydaje mi się że tam to trochę ich mało jest jak tak patrzę na te wasze spisy. :mysli:
proszę o odpowiedź i pozdrawiam,
Tomek :notworthy:
tak w komorze zapasu i na pierwszej stronie ksiazki serwisowej. Z tym ze jak pisalem wyzej tez mam wiecej wyposazenia niz na tej naklejce :mysli:
pisaliśmy nie raz (zdaje się nawet w tym temacie), że na naklejce (obojętnie gdzie jest) nie ma wszystkich kodów.
Pełen wykaz mozliwy przy rozkodowaniu VINu.
Ja mam prośbę o przetłumaczenie tych 3 kodów : TD0 lub TDO (nie mogę rozróżnić czy to zero czy litera o :/ ) , X4J i CH3 , gdyż tych kodów nawet poprzez szukaj nie mogłem odnaleźć :)
TD0 = 4-cylinder diesel engine 1.9 L unit 03G.5 silnik diesel 4 cylindrowy 1.9 L jednostka 03G.5
X4J = National sales program Poland wersja przeznaczona na Polskę
CH3 = Steel wheels 7J x 16 Koła stalowe 7J x 16
[br]Dopisany: 12 Lipiec 2008, 15:53 _________________________________________________Nie wiecie gdzie można zdekodowac VINa, aby dostać pełną listę wyposażenia? Oczywiście oprócz ASO :cool1:
Powyższe linki nie chcą zadziałać :kwasny:
domelq wielkie dzięki :notworthy::) tylko, że ja mam fele aluminiowe, ale może tak się zwą, ale mniejsza z tym :)
I podłączam się również do pytania :)
To dziwne.... :chytry:
Fele aluminiowe to by było: Cast alloy wheels
Na bank w kodzie masz stalowe.
Jak masz od nowości auto to mogło być tak, że: zamówienie poszło na stalówki a na salonie założyli Ci alu. Jesli masz nie odnowości autko to może już ktoś zmienił :wink4:
alu mam od nowości od momentu wyjazdu z salonu, i są to felgi :audi::mysli: ale co tam, ważne że są :> i całkiem ładnie wyglądają (7 ramienne), a wiesz już może jak odkodować ten vin, żeby sprawdzić resztę??
Nie.
Znalazłem jakieś linki do strony, gdzie to było moźliwe, ale serwis już nie działa. Pewnie ktoś go wstrzymał komu było nie na rękę, żeby on działał. Ale jak coś znajde to dam na pewno znać.
Bardzo ciekawe, nie znalazłem jednak kilku kodów:
TB3
7A0
J1D
C7A
8BB
0GG
5MU
4X3
0YK
6TS
4R5
0JJ
D3X
4GF
a są na mojej naklejce. Może ktoś pomóc?
Pozdrawiam :)
TB3
7A0
J1D
C7A
8BB
0GG
5MU
4X3
0YK
6TS
4R5
0JJ
D3X
4GF
Pozdrawiam :)
TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B
7A0 = Without CD changer/CD player
J1D = Battery 380 A (72 Ah)
C7A = Cast alloy wheels 7J x 16
8BB = Halogen headlight for driving on the right
0GG = Emissions concept EU 4
5MU = Decorative aluminum inserts
4X3 = Side air bag front with curtain air bag
0YK = Weight range 10 installation control only, no requirement forecast
6TS = Right exterior mirror: aspherical, large viewing field
4R5 = Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
0JJ = Weight category front axle weight range 9
D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0
4GF = Windshield in heat-insulating glass
Dzięki. Skąd bierzecie te kody? :good:
A ja zgłupiałem do granic możliwości że mi zaraz pompa stanie.
Mam kodziki różne ale czy mogę mieć dwa silniki az maskę podniosłem i tylko 1 i bagażnik otworzyłem brak zapasowego, o co tu chodzi:
M9L i M5S
