michasssxDD Opublikowano 24 Lipca 2019 Opublikowano 24 Lipca 2019 (edytowane) Ktoś zerknie na kody błędów i je rozszyfruje? Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 AA Component: 1.8L R4/5VT 0004 Coding: 0011501 Shop #: WSC 63351 5 Znalezione: 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small P1290 - 002 - Lower Limit Exceeded - Intermittent 16683 - Boost Pressure Regulation: Control Range Not Reached P0299 - 002 - Lower Limit Exceeded 17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High P1114 - 008 - Implausible Signal - Intermittent 16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow P0133 - 002 - Lower Limit Exceeded - Intermittent 16524 - Oxygen (Lambda) Sensor B1 S2: No Activity P0140 - 004 - No Signal/Communication - Intermittent Readiness: 0000 1001 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04475 Shop #: WSC 00460 Nie ma błędów . Address 08 ------------------------------------------------------- Controller: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 2 Znalezione: 01841 - Potentiometer/Actuator for Temperature Flap: Left (G220) 30-10 - Open or Short to B+ - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0203 Coding: 00001 Shop #: WSC 63351 Nie ma błędów . Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00012 Shop #: WSC 63351 Nie ma błędów . Address 17 ------------------------------------------------------- Controller: 8E0 920 900 L Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00100 Shop #: WSC 00186 WAUZZZ8E83A225490 AUZ6Z0B0312309 2 Znalezione: 00562 - Sensor for Oil Level/Temperature (G266) 27-10 - Implausible Signal - Intermittent 01304 - Radio 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AS Component: Komfortgerát T01 1210 Coding: 06976 Shop #: WSC 63351 5 Znalezione: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent 01560 - Passenger Door 61-10 - Won't De-Safe - Intermittent 00933 - Electric Window Motor: Passenger Side (V148) 62-10 - No or Incorrect Adjustment - Intermittent 01332 - Door Control Module: Passenger Side (J387) 80-10 - Single-Wire Operation - Intermittent 01333 - Door Control Module: Rear Left (J388) 80-00 - Single-Wire Operation Edytowane 24 Lipca 2019 przez michasssxDD
przem8 Opublikowano 24 Lipca 2019 Opublikowano 24 Lipca 2019 (edytowane) 4 minuty temu, michasssxDD napisał: 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small P1290 - 002 - Lower Limit Exceeded - Intermittent 16683 - Boost Pressure Regulation: Control Range Not Reached P0299 - 002 - Lower Limit Exceeded 17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High P1114 - 008 - Implausible Signal - Intermittent 16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow P0133 - 002 - Lower Limit Exceeded - Intermittent 16524 - Oxygen (Lambda) Sensor B1 S2: No Activity P0140 - 004 - No Signal/Communication - Intermittent Wszystkie wracają po skasowaniu? Turbo nie osiąga doładowania, czujnik przy chłodnicy do wymiany. Kat był wywalany albo coś z sondą robione? Trzzeba zrobić standardowy komplet logów, wszystko w dziale diagnostyka co i jak. Reszty nie komentuje, bo i tak wszystko opisane, a wyszukiwarka w googlach działa bez problemu ? Edytowane 24 Lipca 2019 przez przem8 1
