michasssxDD Opublikowano 23 Sierpnia 2019 Opublikowano 23 Sierpnia 2019 (edytowane) Witam, ktoś mi zerknie na błędy? Jutro jadę sprawdzić turbo bo coś chyba kiepsko z nim... To logi VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 AA Component: 1.8L R4/5VT 0004 Coding: 0011501 Shop #: WSC 63351 4 Znalezione: 16683 - Boost Pressure Regulation: Control Range Not Reached P0299 - 002 - Lower Limit Exceeded 16891 - Idle Control System RPM Higher than Expected. P0507 - 001 - Upper Limit Exceeded - Intermittent 17956 - Boost Pressure Regulation Valve (N75): Open Circuit P1548 - 004 - No Signal/Communication - Intermittent 17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low P1103 - 008 - Implausible Signal - Intermittent Readiness: 0010 1001 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04475 Shop #: WSC 00460 1 B³¹d Zapis.: 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 8E0 820 043 H Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 3 Znalezione: 01809 - Actuating Motor for Temperature Flap: Left (V158) 41-10 - Blocked or No Voltage - Intermittent 01841 - Potentiometer/Actuator for Temperature Flap: Left (G220) 30-10 - Open or Short to B+ - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0203 Coding: 00001 Shop #: WSC 63351 Nie ma b³êdów . Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00012 Shop #: WSC 63351 1 B³¹d Zapis.: 01333 - Door Control Module: Rear Left (J388) 49-10 - No Communications - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 900 L Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00100 Shop #: WSC 00186 WAUZZZ8E83A225490 AUZ6Z0B0312309 2 Znalezione: 00562 - Sensor for Oil Level/Temperature (G266) 27-00 - Implausible Signal 01304 - Radio 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AS Component: Komfortgerát T01 1210 Coding: 06976 Shop #: WSC 63351 7 Znalezione: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent 01559 - Drivers Door 59-10 - Can't Unlock - Intermittent 01560 - Passenger Door 61-00 - Won't De-Safe 00933 - Electric Window Motor: Passenger Side (V148) 62-10 - No or Incorrect Adjustment - Intermittent 01332 - Door Control Module: Passenger Side (J387) 80-10 - Single-Wire Operation - Intermittent 01333 - Door Control Module: Rear Left (J388) 80-00 - Single-Wire Operation 01561 - Left Rear Door 61-00 - Won't De-Safe End ------------------------------------------------------- Edytowane 24 Sierpnia 2019 przez michasssxDD
przem8 Opublikowano 23 Sierpnia 2019 Opublikowano 23 Sierpnia 2019 (edytowane) Logi to się robi w blokach pomiarowych i musisz zrobić 2+33, 3+20, 115+118. Więcej w dziale diagnostyka. Ty wrzuciłeś błędy, których tłumaczenie i opis znajdziesz w necie, wszystko na Ross-Tech Wiki WIKI.ROSS-TECH.COM Masz problem z doładowaniem, sondą, n75, zajrzyj do zaworka jednokierunkowego odmy. Do zrobienia logi te co wspomniałem. Edytowane 23 Sierpnia 2019 przez przem8 1
