[B6 AVB] Analiza logow - VAG COM
Witam
Zrobilem AUto-SCAN Test i wyskoczylo mi troszke bledow, czy moze ktos mi cos wiecej napisac o tych bledach?
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 038 906 019 FN
Component: 1,9l R4 EDC G000SG 1476
Coding: 00002
Shop #: WSC 63351
WAUZZZ8EX2A079382 AUZ6Z0A0195171
3 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
17996 - Engine Mount Solenoid Valves (N144/N145): Short to Open Circuit
P1588 - 35-10 - - - Intermittent
17678 - Pump-Jet Valve: Cylinder 4 (N243): Regulation Range Exceeded
P1270 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04155
Shop #: WSC 06435
2 Faults Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
Address 08: Auto HVAC
Controller: 8E0 820 043
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect.
Controller: 8E0 907 279 B
Component: int. Lastmodul RDW 1512
Coding: 00001
Shop #: WSC 63351
No fault code found.
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17: Instruments
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 00100
Shop #: WSC 22641
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 46: Central Conv.
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06720
Shop #: WSC 63351
1 Fault Found:
01331 - Door Control Module: Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
End --------------------------------------------------------------------------------------------------
Czy coś niedomaga w normalnej eksploatacji? Jeśli nie to skasuj je i sprawdź za jakiś czas co powróciło. To uzbierało się przez jakiś czas i nie musi oznaczać permanentnej awarii.
sporo masz tego... czy jest jakiś konkretny powód tych błędów? np: podłaczenie zasilania odwrotnie? czy po prostu sobie same wystąpiły?
Witam
Jakies 3 miesiace temu nie bylo wogole bledow. W tym czasie jednynie turbozprezarka byla wymieniona (po wymianie bylo wszystko ok, moc taka sama jak przed wymiana)
Skasowalem wszystkie bledy wczoraj. Zrobilem ponownie dzisiaj test i wyglada tak samo jak wczoraj. (te same bledy)
Problemy sa, nawet kilka:
Od jakiegos miesiaca brakuje samochodowi mocy ( normalnie to 220 km/h moglem wycisnac, teraz to z ciezkim bolem 180 km/h
Nie działa klimatyzacja ( nie dmucha zminym powietrzem)
Zapala się sama kontorlka od ESP i nie mozna jej wylaczyc w czasie jazdy (najczesciej tak powyzej 120 km /h)
Czesto jak zamykam okna z pilota to po sekundzie same sie otwieraja (sporadycznie)
pozdrawiam
3 Faults Found:
brak komunikacji z kontrolerem ABS - jeśli nic nie pomoże (czyszczenie styków po jednej i drugiej stronie) poszukaj na allegro... koleś naprawia sterowniki
jakiś czujnik kontrolny silnika... niestety za wiele nie wiem
P1270 - 35-00 - -
Readiness: N/A
cóż... jak znajomy miał to na trzech cylindrach to po użyciu płynu do czyszczenia wtrysków na dwóch zniknęło... ogólnie to tu jest chyba powód spadku mocy
00-00 - -
no tu już wiadomo że ABS/ESP ma problemy... pewnie kilka błędów dotyczy jednej usterki - niestety chyba sterownika
Zablokowala sie klapka od obiegu zamkniętego lub padł silniczek. Dopóki nie wymienisz to nie wykasujesz.
jak wyżej... ABS
tu może pomóc obejrzenie wiązki w drzwiach kierowcy... albo rozebranie drzwi
