[ALL] PROBLEM Z PRZEKROCZENIEM PRĘDKOŚCI 50 KM /H
Witam wszystkich
Mam problem z Audi A4 kombi 1999 r. 2.5 TDI
Auto ma problemy z odpalaniem i jak już odpali to nie można przekroczyć 50km/h
Zamieszam diagnozę i z góy bardzo dziękuje za pomoc:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 907 401 C 2
Component: 2.5l/4VT EDC 0000SG D61
Coding: 01012
Shop #: WSC 02325
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00000
Shop #: WSC 65535
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 P
Component: A6-Klimavollautomat D62
Coding: 00063
Shop #: WSC 02325
1 Fault Found:
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground 792 Włącznik ciśnienia w klimatyzacji - F129, Przełącznik ciśnienia klimatyzatora - F29
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 919 860 N
Component: C5-KOMBIINSTR. VDO D15
Coding: 01060
Shop #: WSC 50245
IMMO-IDENTNR: AUZ7Z0X0931860
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 D
Component: Zentralverriegelung D32
Coding: 04673
Shop #: WSC 50245
2 Faults Found:
01366 - Opened Due to Crash Signal 1366 Otwarcie po sygnale zderzenia
35-00 - -
00958 - Key 4
09-10 - Adaptation Limit Surpassed - Intermittent Stopien koncowy termostatu
Address 56 -------------------------------------------------------
Controller: 4B0 035 152
Component: Radio 0001
Coding: 00201
Shop #: WSC 02325
1 Fault Found: 852 Głośnik przedni
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
End -------------------------------------------------------
jesli auto ciezko pali to moze to byc wina pompy vp44 jesli juz zapali nie szarpie silnikiem pracuje rowno?? dasz rade wcisnac pedal zeby sie motor rozkrecil ponad 3000obr?
sprawdziles czy nie masz powietrza w ukladzie paliwowym czy w wezyku nie ma powietrza jesli wsztyko sprawne to moze to byc pompa paliwowa
widze ze sterownik pompy nie pokazuje bledu ale moze byc tloczek w pompie zatarty (poczatek wtrysku) a wtedy pompa do regeneracji koszt jakies 1000zeta jesli nie padl sterownik jak padl sterownik to jakies 1500zl lub na alegro po regeneracji kupisz tez cos kolo 1500
zvaguj silnik konkretnie tak jak jest na głownej stronie z logami
wymieniałeś kiedyś filtr paliwa w tym aucie ? jeśli nie to już pewnie h...j strzelił pompę VP 44.
