[B5 1Z] autoscan bledow
Prosze o analizę logów
Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 AF
Component: 1,9l R4 EDC G000SG 2825
Coding: 00002
Shop #: WSC 06325
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 M
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 900 H
Component: B5-KOMBIINSTR. VDO D11
Coding: 00140
Shop #: WSC 63251
???????????????? AUZ7Z0X1318531
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 13131
Shop #: WSC 06325
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
1 Fault Found:
01378 - Ultra Sonic Sensor for Alarm System: Right (G171)
27-10 - Implausible Signal - Intermittent
End -------------------------------------------------------
Zgłoś do moderatora Zapisane
Gosiu, to nie sa logi, tylko autoscan bledów. Nic sie nie dzieje. Lekkie zawirowania w centralnym (tak jakby pompka nieszczelna) i alarmem sa w co 2 A4[br]Dopisany: 27 Lipiec 2007, 19:00 _________________________________________________trzeba je skasowac i sprawdzic czy cos sie pojawi.
Podpowiesz mi jak to się robi?
poczekaj następny raz na mnie to zrobimy pełną diagnostykę :)
musisz być bardziej cierpliwy(-a)
Piotrze (gosia)
Adam skasował Ci błedy tylko nie wiem czy powtorzył vagowanie
gosia to facet?? :blink:
Gosia ma na Imie Piotrek i to Piotrek był na spocie a nie gosia mam nadzieje ze nastepnym razem pojawia sie w komplecie :tongue4:
nic powaznego sie nie dzieje ... poprosimy o logi co by zbadac motorownie ...
