[B6 AKE] Logi do oceny - muł i czarny dym.
Auto ma muła i sadzi na czarno:
BŁĘDY:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 907 401 B
Component: 2.5L V6 TDI 0000SG 0002
Coding: 02015
Shop #: WSC 63351
00001059 130 106HC150_1.R76335142086
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad D620
Coding: 04455
Shop #: WSC 44440
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 A
Component: A4 Klimaautomat 0708
Coding: 00000
Shop #: WSC 63351
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 44440
1 Fault Found:
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0102
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 GX
Component: KOMBI+WEGFAHRS. RB4 D15
Coding: 01000
Shop #: WSC 07777
00464 AUZ6Z0Y0000239
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 36 -------------------------------------------------------
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0E01
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 C
Component: BNS 4.1 H05 BNO 0002
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AH
Component: Komfortgerát T9F 0619
Coding: 06752
Shop #: WSC 07777
8 Faults Found:
01559 - Drivers Door
60-10 - Won't Safe - Intermittent
00936 - Electric Window Switch in Front Passenger Door (E107).
27-10 - Implausible Signal - Intermittent
01802 - Door Warning Lamp: Pass Side (W36)
57-10 - Electric Circuit Failure - Intermittent
00944 - Heated Exterior Mirror: Passenger Side (Z5)
00934 - Electric Window Motor: Rear Left (V26)
62-10 - No or Incorrect Adjustment - Intermittent
01561 - Left Rear Door
00937 - Switch for Electric Window: Rear Left (E52)
01803 - Door Warning Lamp: Rear Left (W37)
Address 56 -------------------------------------------------------
Controller: 8E0 035 152
Component: chorus II GRO D002
Coding: 00032
Shop #: WSC 63351
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
End -------------------------------------------------------
LOGI:
STATYCZNE - GRUPY NORMALNE:
000:
001:
003:
004:
007:
008:
013:
014:
018:
GRUPY BASIC SETTINGS:
000:
003:
004:
DYNAMICZNE:
000:
001:
003:
004:
008:
010:
011:
013:
014:
018:
Zrób jeszcze logi BS. Ciekawie to wygląda, bo przeplywka pokazuje jakieś masakryczne wartości. Chyba się wysrała :mysli: Albo nie bylo nogi w podlodze po logowaniu :naughty:
Czy podczas logowania tej fury... wylaczone byly wszystkie odbiorni elek. klima etc.. ?
Zamiesc screenshota z okienka VAG w momemcie kiedy w 004 Basic Settings nastawnik ustawi sie w polozeniu "LATE".
Przeplywomierz to jakby nie od tego silnika ?
Bezkosztowo - sprawdzić szczelność dolotu
Znaleźć dziurę :decayed: i znowu zrobić logi
kat zaplonu w bs 004 zly na byc 2po OT(gorne polozenie tloka) a jest 4,6 i to przed OT czyli w trakcie przemieszczania sie tloka do gory dostaje paliwo nie dobrze i to konkretnie niedobrze ustaw poprawnie i jak koledzy napisali sprawdz przeplywke
:good: dziura 4 cm w dolocie.
Ale dziura to nie jedyny problem tego auta.
Zlikwidujcie nieszczelność i ponownie zróbcie logi :)
