[B6 AKE] Nie ściemnia się lusterko wsteczne, "light detection sensor" (?)
SebMis mnie zvażył i wyszlo to:
02104 - Light Detection Sensor (G399)
30-00 - Open or Short to B+
02105 - Supply Voltage for Light Detection Sensor
57-10 - Electric Circuit Failure - Intermittent
Ktos wie co to jest? Na FISie widze kontrolke (nad spalaniem itp) w postaci a'la halogen w koleczku.
No czujnik światła pewnie :) Masz przełącznik świateł z funkcją "auto"? Jeśli nie to przełożymy na chwilę mój na następnym spocie i zobaczymy czy błąd zniknie.
Customer concern about automatic headlight instrument cluster warning light illuminating
for 1 second accompanied with a short beep. Condition only occurs when headlight switch
is in AUTO position.
DTC “P2104/29 - G399 short to ground sporadic” is usually stored in vehicle electrical
system control module -J519-
Service
Check for above DTC as follows:
– Connect VAS 5051/5052 diagnostic tool.
– From Start-up screen, select “Vehicle Self-Diagnosis”.
– Select vehicle system “09 - electronic central electrics”.
– Select diagnosis function “02 - Interrogate fault memory”.
If DTC “P2104/29 -G399- short to ground sporadic” is stored in memory:
– Replace interior rear view mirror (Part No. 8E0 857 511B*). See Repair Manual,
Group 68, Interior Equipment, Interior rear
view mirror, removing (automatic day/night
mirror, interior rear view mirror with
compass).
Add color code: 4PK - Soul Black (A4, A4 Cabrio);
E59 - Light Platinum (A4); F77 - Light Aqua (A4);
1RS - Twist (A4);
– Erase DTC using “05 - Erase fault memory”.
– Proceed to “Check Operation of Automatic Headlights” (See Page 3).
If DTC “P2104/29 - G399 short to ground sporadic” is not stored in memory:
– Remove interior rear view mirror.
– Check supplier Part No. -arrow-.
If supplier Part No. is 905-0617, 905-0702,
905-0704 or 905-0706.
– Replace interior rear view mirror.
If supplier Part No. is 905-1028, 905-1029,
905-1030 or 905-1031:
– Further diagnosis of automatic headlight system is necessary. DO NOT complete this Technical Bulletin.
Także była na to akcja organizowana, szkoda że Niemiec nie wymienił w Twoim aucie :decayed:
TSB 94-05-01
  • 2 lata później...
Odswiezam temat.
Mamy milion wiecej klubowiczow niz 2 lata temu, a problemu nie dzialajacego lusterka wstecznego [fotochrom nie dziala] do tej pory nie rozwiazalem.
Podmienialem nawet na nowe lusterko i pupa blada.
Ktos mial taki problem?
Jak wlaczam AUTO na przelaczniku swiatel, to mam error na fisie w postaci ikonki [zrobie fote pozniej].
Na VAGu bledow brak :confused4:
