[B5 ADR] to co vag pokazał mi na spocie swidnickim
witam wklejam to co vag mi dzis wykazał na spocie dzięki Seb-K, prosze o odpowiedź bo zupełnie sie na tym nie znam , a więc wklejam:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 558 B
Component: 1,8L R4/5V MOTR HS D02
Coding: 04001
Shop #: WSC 00000
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04140
Shop #: WSC 06335
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 860 G
Component: B5-KOMBIINSTR. VDO D07
Coding: 00142
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0V0156158
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe D03
Coding: 00000
Shop #: WSC 65535
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
End -------------------------------------------------------
Jeżeli dały się skasować, to ogólnie nie ma się czym przejmować - mogą byc b.stare.
18010 - Power Supply Terminal 30: Voltage too Low - może być spowodowany np. odpięciem aku
01367 - Central Locking Pump Run Time Exceeded (Likely Leak) - występuje w większości a4
Reszta - prawdopodobnie spowodowane są nie ori alarmem - może jakieś zwarcie :mysli:
ja bym skasował wszystkie i patrzył które wrócą bo jak wiemy ecu zapisuje błedy z poprzedniego wieku :rolleyes:
