ale nie muszisz sie przejmowac
Twoje auto nie przyjmuje kodowania
:polew: :polew: :polew: :polew:
:laghing2: :laghing2: :laghing2: :laghing2:
:wink4: jeszcze przyjmuje :wink4:
  • Odpowiedzi 12,9 tys.
  • Wyświetleń 1,7 mln.
tutaj masz info
Login
Note #1: After Login has been carried out you need to recode the control module.
Note #2: Special Login 07499 is used for 6-Cylinder Diesel Engine with 1LG Brakes and Multitronic.
Note #3: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker.
0?xxx: Chassis
9 = Audi A4
0x?xx: Brakes
2 = Brembo 17" (PR-1LJ)
3 = FN3 16" (PR-1LT/1LF)
4 = HP2 16" (PR-1LX)
4 = FNR 16" (PR-1LA/1LG)
5 = FN3 15" (PR-1LB/1LE)
6 = C54 (PR-1LZ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
7 = 4/5 Cyl. Gasoline
9 = 6/8 Cyl. Gasoline
0xxx?: Transmission
5 = Manual
7 = Automatic (5HP19, 5HP24, AG4, AG5)
9 = Multitronic (01J, CVT)
Coding
Note #1: Coding is accepted after a specific login has been carried out.
Note #2: After successful coding the steering angle sensor basic setting needs to be carried out.
Note #3: Special Coding 04499 is used for BFB Engine with 1LT Brakes and Multitronic.
Note #4: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker.
Note #5: In some cases, you will need to enter a non-zero WorkShop Code, such as 12345.
0?xxx: Chassis
4 = Audi A4
0x?xx: Brakes
1 = C54 (PR-1LZ)
2 = FN3 15" (PR-1LB/1LE)
3 = HP2 16" (PR-1LX)
3 = FNR 16" (PR-1LA/1LG)
4 = FN3 16" (PR-1LT/1LF)
5 = Brembo 17" (PR-1LJ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
0xxx?: Transmission
5 = Manual
Panowie mam małe pytanko,
czy po przekładce z 288mm na 320mm trzeba również zmieniać kodowanie tempomatu :mysli:
kojarzę, że coś tam chyba było o hamulcach ale może dla tempomatu ta zmiana nie robi różnicy :?: :?: :?:
nic nie zmieniasz
Jakie 16" felgi wejdą na te moje heble 320/288? od b7 2.0tfsi
zależy jaki masz te 16", Ja mam uc**jałe biedrony to wchodzą
Przecież o to pytam :polew: Chcę kupić fele na zimę i nie wiem jakie kupić
To biedrony wchodzą :wink4:
no taaaakkkkk....
ale kto bogatemu zabroni...[br]Dopisany: 16 Lipiec 2011, 21:11_________________________________________________mały up-grejdzik :wink4: :wink4: :wink4:
tłoczki wykonane w 100% ze stali nierdzewnej
za kilka dni zagoszczą w zaciskach 312mm jednego z Kolegów z forum :> :> :> :>
Super opcja, jaki koszt standardowych 57?
no taaaakkkkk....
to zalezy dla kogo.... :wink4: :wink4: :wink4: :wink4:
zdradzę Ci Kolego że sam koszt wytworzenia kompletu razem z materiałem to 100zł ;( ;( ;( ;( ;(
jestes zainteresowany zakupem ? info na PW
Młody_drog, w tym poscie sa foty felg które "przyjmują" 320mm tarcze
wystarczy poszukac :wink4: :wink4: :wink4:
uups :embarrassed:
Ale tutaj jest 145 stron, wszystkie mam przejrzeć? :mysli:
Cena jest ok, będę zawracał gitarę przy najbliższej okazji.
Przy naszych realiach mało osób będzie zadawało sobie sprawę ze skuteczności tego moda.
Pod te felgi na 100% wchodzi:
Pierwsza ma ET45 pozostałe ET42
Aha ja mam zaciski z A6 3,0TDi a one są troszke szersze od tych co są w A4 B7 i S4 B6,B7
jak to nie ma :>
wchodza tez na 16" z B7 ale nie moge znalesc foty :mysli: :mysli: :mysli:
wchodzą też na takie ET42
No i są chyba pierwsze w PL tarcze Zimmermann'a Sport dla Audi S4 B6 345x30 mm :>
jakie koszta ?
Na tyl 330/22 mm tez masz perforowane ?
