analiza bledow
witam prosilbym o sprawdzenie logow :decayed:
wiem ze auto nietrzyma temperatury i jest to do zrobienia ale probowalismy robic logi na temperaturze ok 90 stopni:decayed:
pacjent A4 B5 1.9TDI AJM automat
osoba wykonujaca logi Stanley :doh::decayed:
oto i one
bledy:
VAG-COMVersion: Release 311.2-N
ChassisType: 8D - Audi A4 B5
Scan:01,02,03,08,15,17,25,35,45,55,56
Address01 -------------------------------------------------------
Controller: 038 906 019 AN
Component: 1,9l R4 EDC 0000AG 1301
Coding: 00001
Shop #: WSC 63351
3 FaultsFound:
17664 -Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17965 -Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17978 -Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness:N/A
Address02 -------------------------------------------------------
Controller: 8D0 927 156 CB
Component: AG5 01V 1.9l-PD RdW 3737
Coding: 00003
Shop #: WSC 63351
No faultcode found.
Address03 -------------------------------------------------------
Controller: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 04257
Shop #: WSC 06435
No faultcode found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D58
Coding: 00043
Shop #: WSC 63351
No faultcode found.
Address15 -------------------------------------------------------
Controller: 8D0 959 655 J
Component: Airbag Front+Seite 2001
Coding: 00106
Shop #: WSC 63351
1 FaultFound:
65535 -Internal Control Module Memory Error
00-00 - -
Address17 -------------------------------------------------------
Controller: 8D0 920 900 M
Component: KOMBI+WEGFAHRS. M73 D55
Coding: 00040
Shop #: WSC 67059
XXXXXXXXXXXXXXXXX AUZ5Z0D4147002
No faultcode found.
Address25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No FaultsFound
or DTCs not supported by controller
or a communication error ocurred
Address35 -------------------------------------------------------
Controller: 8D0 862 257 C
Component: ZV-Pumpe D16
Coding: 02049
Shop #: WSC 63351
2 FaultsFound:
01367 -Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 -Interior Lights
28-00 - Short to B+
Address56 -------------------------------------------------------
Controller: 4B0 035 152 B
Component: Radio 0001
Coding: 00201
Shop #: WSC 63351
No faultcode found.
End -------------------------------------------------------
a teraz logi:
VAGLOG - wklej logi z VCDS/VAG-COM
jesli ktos to ogarnia to prosilbym o jakies info :wink:
czujnik wody ma zwarcie, do wymiany ale tylko ori
zapyziałe łopatki w turbo, do czyszczenia
kat do wywalenia
chyba ok 60 stopni :doh:
