kopia zapisu vag sporo bledow prosze o porade
Witam zrobilem skan po instalacji rns-e ale z seata exeo do tego modulu bluetooth plus mikrofon i tempomat ale ten niedziala zmienilem kodowanie w opcjach kierownicy z tego co wiem musze jeszcze zmienic w kodowaniu silnika ale jest maly problem nie moge dostac sie do login 11 jest jakby niewidoczny co teraz?
a co do bledow to jest kopia skanu :
unday,19,May,2013,19:49:55:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WUAZZZ8EX6A801946 Mileage: 125800km/78168miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 N HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0070
Revision: --H13--- Serial number:
Coding: 01040003180F0020
Shop #: WSC 00836 210 86410
VCID: 2C5D1A698F10169
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004526
Shop #: WSC 06325 000 00000
VCID: 2E591061B90C649
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 27
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x018D
Hex Value: 0x0001
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x07C0
Hex Value: 0x5302
Hex Value: 0x0003
Hex Value: 0x02A7
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDDA691C90D69
2 Faults Found:
53-10 - Supply Voltage Too Low - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00001
Shop #: WSC 06325
VCID: 3D7B272D376A8F1
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G02EYB
Coding: 0034622
VCID: 3B7F29357A7E811
1 Fault Found:
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 1048575 km
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04041
Shop #: WSC 06325
VCID: 41835BDD4B92EB1
6 Faults Found:
01044 - Control Module Incorrectly Coded
35-10 - - - Intermittent
00886 - Turn Signal Switch (E2)
04-10 - Mechanical Malfunction - Intermittent
00895 - Cruise Control Switch (E45)
37-10 - Faulty - Intermittent
01304 - Radio
49-10 - No Communications - Intermittent
01301 - Control Module for Voice Recognition (J507)
01303 - Telephone Transceiver (R36)
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 F HW: 8E0 920 951 F
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0007441
Shop #: WSC 00641 210 00243
VCID: 2D5B176DB70A1F1
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 3R0 035 192 HW: 3R0 035 192
Component: RNS-E PU EU H05 0220
Revision: 0000011S Serial number: SEZBZ7K6901501
Coding: 0318755
Shop #: WSC 00000 000 00000
VCID: E9D3237DC362431
5 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 73
Time Indication: 0
Date: 2013.05.19
Time: 17:53:32
Freeze Frame:
Voltage: 10.60 V
Mileage: 655350 km
Count: 1002
Clock: 00:06
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2005.02.14
Time: 20:55:06
Freeze Frame:
Mileage: 655350 km
Count: 1402
Clock: 21:03
02024 - Perform Adaptation
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 1
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2005.02.14
Time: 21:02:20
Freeze Frame:
Mileage: 655350 km
Count: 1402
Clock: 21:02
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 18
Time Indication: 0
Date: 2010.10.01
Time: 10:52:16
Freeze Frame:
Mileage: 655350 km
Count: 1905
Clock: 17:49
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBDF5975999E511
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4035
Coding: 06895
Shop #: WSC 06325
VCID: 79F3F33D63C2731
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
5 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00955 - Key 1
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0318755
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 73
Time Indication: 0
Date: 2013.05.19
Time: 17:53:32
Freeze Frame:
Voltage: 10.60 V
Mileage: 655350 km
Count: 1002
Clock: 00:06
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2005.02.14
Time: 20:55:06
Freeze Frame:
Mileage: 655350 km
Count: 1402
Clock: 21:03
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 1
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2005.02.14
Time: 21:02:20
Freeze Frame:
Mileage: 655350 km
Count: 1402
Clock: 21:02
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 18
Time Indication: 0
Date: 2010.10.01
Time: 10:52:16
Freeze Frame:
Mileage: 655350 km
Count: 1905
Clock: 17:49
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005271153
Coding: 0011822
Shop #: WSC 06335 000 00000
VCID: 448D52C90480FE9
End ---------------------------------------------------------------------
Trochę tego masz a próbowałeś skasowac błędy - część z tego co widzę jest po wymianie radia - tez miałem takie jak zmieniałem i odłanczałem radio. Po skasowaniu było ok i błędy nie wracały. Co do pozostałych błędów to może doświadczeni koledzy mogą sięwypowiedzieć. Ewentualnie tu możesz poczytać :
Category:Fault Codes - Ross-Tech Wiki
W czwrtek skasuje bledy I zobacze czy cos zostanie a co z login 11 jak dostac sie do niego?
skasuj bledy .. i naladuj akumulator ..objwy za malego napiecia w aucie..najprawdopodobniej akumulator detka ale sie poprostu rozladowal bo malo jedzisz....zacznij od tego
A co z login11 aby zmienic kodowanie silnika pod tempomat?
---------- Post dopisany 02-06-2013 at 15:05 ---------- Poprzedni post napisany 23-05-2013 at 18:33 ----------
Nikt sie nie orjentuje ? :kwasny: . Moze jeszcze jedno czy musze dopinac ekstra kabel (pin) bo juz zlupialem Wiem ze to zalezne od wersji gdzie mam sprawdzic czy mam ten pin ?
---------- Post dopisany 05-06-2013 at 00:55 ---------- Poprzedni post napisany 02-06-2013 at 15:05 ----------
Taki maly dodatek pokasowalem bledy ale nadal mam blad od nawigacji I radia chociaz to Chyba to samo jakies porady ?
A co do login 11 w opcjach engine to tak pi razy drzwi Wiem o co halo w prawym dolnym rogu w opcjach silnika jest security ,trzeba podac 7 cyfrowy pin aby uzyskac dostep I tu jest teraz problem :kwasny:
Gdzies wyczytalem ze ten pin dodany jest do tej plastikowej kopi kluczyka , posiadam may taki plastikowa przywieszke Keira sie otwiera jest tam kod ale nie same cyfry wiec od panda to nie to , ten pennies jest cos do kodowania kluczyka imobilajzer alarm czy cos takiego ,a dla ciekawostki po blednym wpisaniu blokuje sie silnik na 10 min wiec nawet nie bede nic wpisywac .
Wiec pytanie teraz jak zalatwic pin?
Nie ogarniam ile problemu aby zalozyc tempomat :/ audi sie zabezpiecza aby robic samemu :kwasny:
Nie zmieniasz kodowania ,tylko aktywujesz tempomat
wchodzimy w ENGINE
[select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
Enter 16167 deactivate
[Do It!]
i powinno działać
Dzieki za odp. Ale to Wiem prOblem ze ja niemoge sie dostac do login jest jak by nie widoczny ,aby to odblokowac w security musze podac 7 cyfrowy pin ktorego niemam
  • 6 miesięcy temu...
Kolego poradziłeś sobie z tym bo ja mam to samo ??
  • 1 rok później...
nareszcie ogarnolem trzeba wejsc nie przez engine 01
tylko w17 instrument pozniej jesli pamietam 07 coding i tam trzeba aktywowac tempomat
