rafau Opublikowano 28 Lipca 2014 Opublikowano 28 Lipca 2014 Siemanko, nastąpiła zmiana A6 C5 2.7 Biturbo BES 10.2004 Pozbyłem się A4 B5 1.9 110 i kupiłem coś takiego ze szwajcarii Wyposażenie: E4J = S-line 0GG = emissions concept EU 4 4UE = airbag for driver and front seat passenger 6XD = outer rear view mirrors: powered, heated 5SL = outer left rear view mirror: non-spherical 5RU = outer right rear view mirror: convex (large viewing field) 1KD = disc brakes, rear J0L = battery 340 A (70 Ah) 1LA = disc brakes, front 1BV = sports suspension/shock absorption 3FA = without roof insert (standard roof) 5TG = decorative aluminum inserts, dulling 7X1 = ultrasonic park distance control F0A = no special purpose vehicle, standard equipment 8GL = alternator 120A 0G7 = Tiptronic 0YR = weight category rear axle weight range 15 0JL = weight category front axle weight range 11 T7Z = components for, base engine, unit 078.8 3NZ = rear seat bench unsplit, backrest split folding 8ED = bi-functional headlight with gas discharge lamp, for driving on the right U1U = instrument insert with km/h speedo, clock tachometer, trip odometer, additional instruments with special color trim X4B = national sales program Switzerland 1N1 = power steering 1ML = leather trimmed sports steering wheel 3HA = without leather parts scope 8Q3 = automatic headlight-range adjustment dynamic (self-adjusting while driving) 9Q2 = multi-function indicator/on-board computer with check control 8Z5 = engine cooling system, type 1 MK5 = 6-cylinder gasoline engine 2.7 L/184 kW 30V, base engine is T7Z 7Q0 = without navigation device CL6 = alloy wheels 7 1/2J x 17 nine-spoke style, offset 43 7K0 = without tire pressure warning light 4X3 = side airbag front with curtain airbag VJ2 = reinforced bumpers 6R0 = selector lever cover 3PF = electric height adjustment for both front seats VW1 = side windows tinted green, from B-pillarto rear window gray tinted safety glass 3Y0 = without roll-up sun screen 4K4 = radio remote controlled central locking operated from inside and separate trunk release 5D1 = carrier frequency 433.92 MHz 1SA = without additional engine guard Q1D = sports front seats 4GP = windshield tinted with sun band and viewing window for vehicle identification number Fotki: Pozdrawiam! A6 c5 2.7 biturbo(2) - YouTube
majkel20 Opublikowano 28 Lipca 2014 Opublikowano 28 Lipca 2014 nie wiem czy takie zegary były ori czy nie, ale wygląda to okropnie....
rafau Opublikowano 28 Lipca 2014 Autor Opublikowano 28 Lipca 2014 majkel20 napisał(a): nie wiem czy takie zegary były ori czy nie, ale wygląda to okropnie.... S Line Sports Package for the Audi A6 | AudiWorld element pakietu s-line. ja już się przyzwyczaiłem
peter22 Opublikowano 28 Lipca 2014 Opublikowano 28 Lipca 2014 no słabo widać cyfry na tym liczniku , w nocy jak się podświetli to pewnie lepiej to wygląda .
rafau Opublikowano 28 Lipca 2014 Autor Opublikowano 28 Lipca 2014 jak nie zapomnę, to cyknę dziś w nocy fotkę jak będę jechał do pracy ---------- Post dopisany at 20:26 ---------- Poprzedni post napisany at 18:57 ---------- A6 c5 2.7 biturbo(2) - YouTube
rafau Opublikowano 28 Lipca 2014 Autor Opublikowano 28 Lipca 2014 peter22 napisał(a): Dźwięk silnika za***isty I dźwięk kończącego się gazu haha
Czary Opublikowano 29 Lipca 2014 Opublikowano 29 Lipca 2014 emmm myślałem że tipy w S4 b5 i z silnikami takimi jak 2.7 majo 6 begów. lypa
rafau Opublikowano 29 Lipca 2014 Autor Opublikowano 29 Lipca 2014 Nie wiem jak w s4. Jeżeli w a6 c5 masz 6 biegowy automat to jest to multitronic i należy się tego wystrzegać Wysłane z mojego GT-I9300 przy użyciu Tapatalka
Marynarz____ Opublikowano 29 Lipca 2014 Opublikowano 29 Lipca 2014 fajne autko, a czemu poducha Ci miga??
rafau Opublikowano 29 Lipca 2014 Autor Opublikowano 29 Lipca 2014 Poducha przez wtyczkę pod fotelem. Zajmę się tym na dniach Wysłane z mojego GT-I9300 przy użyciu Tapatalka ---------- Post dopisany at 13:04 ---------- Poprzedni post napisany at 07:32 ---------- FOTKI GAZ + LICZNIK NOCĄ
WhyMe? Opublikowano 29 Lipca 2014 Opublikowano 29 Lipca 2014 Reggi napisał(a): Mefju..pacz takie listwy sobie spraw O jakich mówisz?
Sqizzy Opublikowano 30 Lipca 2014 Opublikowano 30 Lipca 2014 Dokładnie coś takiego chciałbym teraz mieć, może tylko żeby miał manual. świetne auto
Reggi Opublikowano 30 Lipca 2014 Opublikowano 30 Lipca 2014 Muhahahaha... poszukaj takiej w dobrym stanie..a później poszukaj w dobrym stanie i manuala.
