ganjaq Opublikowano 17 Października 2014 Opublikowano 17 Października 2014 Ja w temacie, zrobiłem auto scan i : VAG-COM Version: Release 311.2-NChassis Type: 8E - Audi A4 B6Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76Address 01 ------------------------------------------------------- Controller: 8E0 909 518 AL Component: 1.8L R4/5VT 0003 Coding: 0011501 Shop #: WSC 66565No fault code found.Readiness: 0000 0000Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04475 Shop #: WSC 064352 Faults Found:01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent00532 - Supply Voltage B+ 07-10 - Signal to Low - IntermittentAddress 08 ------------------------------------------------------- Controller: 8E0 820 043 AB Component: A4 Klimaautomat 1324 Coding: 00000 Shop #: WSC 632513 Faults Found:01273 - Fresh Air Blower (V2) 53-10 - Supply Voltage Too Low - Intermittent00819 - High Pressure Sensor (G65) 07-10 - Signal to Low - Intermittent00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - IntermittentAddress 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0606 Coding: 00001 Shop #: WSC 63251No fault code found.Skipping Address 15-AirbagsAddress 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 00002 Shop #: WSC 632514 Faults Found:01331 - Door Control Module: Driver Side (J386) 49-00 - No Communications01332 - Door Control Module: Passenger Side (J387) 49-00 - No Communications01333 - Door Control Module: Rear Left (J388) 49-00 - No Communications01334 - Door Control Module: Rear Right (J398) 49-00 - No CommunicationsAddress 17 ------------------------------------------------------- Controller: 8E0 920 900 N Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00001 Shop #: WSC 00006 WAUZZZ8E84A280412 AUZ6Z0D01335296 Faults Found:01176 - Key 07-10 - Signal to Low - Intermittent00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent01331 - Door Control Module: Driver Side (J386) 49-00 - No Communications01332 - Door Control Module: Passenger Side (J387) 49-00 - No Communications01334 - Door Control Module: Rear Right (J398) 49-00 - No Communications01333 - Door Control Module: Rear Left (J388) 49-00 - No CommunicationsAddress 46 ------------------------------------------------------- Controller: 8E0 959 433 AS Component: Komfortgerát T01 1210 Coding: 06976 Shop #: WSC 632517 Faults Found:01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent01331 - Door Control Module: Driver Side (J386) 49-00 - No Communications01332 - Door Control Module: Passenger Side (J387) 49-00 - No Communications01333 - Door Control Module: Rear Left (J388) 49-00 - No Communications01334 - Door Control Module: Rear Right (J398) 49-00 - No Communications00892 - Switch for Trunk Closing Cylinder (F248) 27-10 - Implausible Signal - Intermittent00955 - Key 1 35-10 - - - IntermittentAddress 56 ------------------------------------------------------- Controller: 8E0 035 186 L Component: concert II GRO 0001 Coding: 01001 Shop #: WSC 632513 Faults Found:01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent00668 - Supply Voltage Terminal 30 07-10 - Signal to Low - Intermittent00852 - Loudspeaker(s): Front 36-00 - Open CircuitEnd -------------------------------------------------------
Dev Opublikowano 17 Października 2014 Opublikowano 17 Października 2014 Pokasuj i pojezdzij. jak cos wraca to trzeba ubrudzic łapy.
ganjaq Opublikowano 17 Października 2014 Autor Opublikowano 17 Października 2014 (edytowane) Pokasuj i pojezdzij. jak cos wraca to trzeba ubrudzic łapy. Na dzień dobry nie działają: -szyby, -centralka, -oświetlenie wnętrza nie działa tzn. działa ale np. światło nie gaśnie samo Dodatkowo jak sprawdzałem bezpieczniki przestał działać panel klimy Jeszcze jedno, co powinno być z tyłu w bagażniku po prawej stronie, tam gdzie znajduje się trójkąt i inne gratu bo mam dwie wtyczki luzem Edytowane 17 Października 2014 przez ganjaq
Robero321 Opublikowano 17 Października 2014 Opublikowano 17 Października 2014 Większość błędów ma związek z słabym napięciem podejrzewam ze rozładował Ci się aku i zostały błędy w pamięci. Naładuj porządnie aku pokasuj wszystkie błędy i zobacz które wrócą. Spora cześć pewnie nie wróci
Homiczek Opublikowano 18 Października 2014 Opublikowano 18 Października 2014 a drzwi to wygląda że problem z modułem komfortu - zasilanie. może jakieś bezpiecznik, ale pewnie trzeba się do niego dobrać
jacek70 Opublikowano 18 Października 2014 Opublikowano 18 Października 2014 W b5 niema modułu komfortu. Proponuję zacząć od sprawdzenia aku,bezpieczników następnie jeszcze raz vag.
Homiczek Opublikowano 18 Października 2014 Opublikowano 18 Października 2014 W b5 niema modułu komfortu Address 46 -------------------------------------------------------Controller: 8E0 959 433 ASComponent: Komfortgerát T01 1210Coding: 06976Shop #: WSC 632517 Faults Found:01330 - Central Control Module for Central Convenience (J393)53-10 - Supply Voltage Too Low - Intermittent01331 - Door Control Module: Driver Side (J386)49-00 - No Communications01332 - Door Control Module: Passenger Side (J387)49-00 - No Communications01333 - Door Control Module: Rear Left (J388)49-00 - No Communications01334 - Door Control Module: Rear Right (J398)49-00 - No Communications00892 - Switch for Trunk Closing Cylinder (F248)27-10 - Implausible Signal - Intermittent00955 - Key 135-10 - - - Intermittent a toto coto ?!? może w poliftowych juz dodali ?
Robero321 Opublikowano 19 Października 2014 Opublikowano 19 Października 2014 Zwróć uwagę na błąd 53-10 problem z napięciem. Pomierz napięcia zasilające moduły i napięcie jakie masz na aku
ganjaq Opublikowano 25 Października 2014 Autor Opublikowano 25 Października 2014 Zwróć uwagę na błąd 53-10 problem z napięciem. Pomierz napięcia zasilające moduły i napięcie jakie masz na aku Coś się goni ewidentnie, choinka sie robi, powyjmowałem wszystkie małe bezpieczniki, zostawiłem tylko 3, od kierunków, od świateł dziennych i narazie spokój, muszę kolejno wkładać je i sprawdzać które robią zamieszanie To nie bezpieczniki, zauważyłem że jak wepnę kostkę w moduł od szyb, prawa strona od pasażera, to wtedy się zaczyna. Klimatronik podświetla się tak jakbym włączył światła. Jak wepnę kostkę w moduł od strony kierowcy to niby nic się nie dzieje ale cały czas miga mi dioda w drzwiach tak jakbym zamknął auto z pilota, dodam że centralka nie działa i szyby nie jadą a światła w kabinie jak są przycisk jest na środku to świecą się cały czas. Po tych logach powinienem mieć 4 szyby w prądzie? Bo mam tylko dwie
GreGoriO Opublikowano 25 Października 2014 Opublikowano 25 Października 2014 auto angol czy EU. ściągnij sobie ELSĘ i posprawdzaj według niej kolejność połączeń i kolory przewodów w odpowiednich pinach kostek.
ganjaq Opublikowano 26 Października 2014 Autor Opublikowano 26 Października 2014 Auto europa, chcesz żebym prześledził wszystkie kable, wszystkie ich połączenia z A do B w każdym miejscu auta czy na podstawie tego co napisałem da się zawęzić obszar poszukiwań
