[BEX] 1.8TQ AVANT
Witam,
A4 B6 1.8T BEX Quattro na taki polowałem
Samochód ze Szwajcarii
Wyposażenie z naklejki z dekodera po angielsku
E4J = "S-line"
7A2 = CD changer
4UE = Air bag for driver and front seat passenger
6XD = Exterior mirrors: electrically adjustable/heated
5SL = Left exterior mirror: aspherical
5RU = Right exterior mirror: convex (large viewing field)
1KP = Disc brakes, rear
J0L = Battery 340 A (70 Ah)
1LT = Disc brakes, front
1BV = Sports suspension/shock absorption troche jednak za sztywne :)
3FA = Without roof insert (standard roof)
5TG = Decorative aluminum inserts, dulling
7X0 = Without park distance control
4R4 = Power windows with comfort operation andcircuit breaker
F0A = No special purpose vehicle, standard equipment
8GL = Alternator 120 A
0G1 = Gearshift lever
0YL = Weight range 11 installation control only, no requirement forecast
0JG = Weight category front axle weight range 7
T0L = 4-cylinder gasoline engine 1.8 L unit 06B.G
3NZ = Rear seat bench unsplit, backrest split folding
8JG = Headlight with gas discharge lamp for driving on the right
U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
X4B = National sales program Switzerland
1N1 = Power steering
1ML = Leather trimmed sports steering wheel
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q4 = Multi-function display/on-board computerwith check control
8Z5 = Not hot country
D7E = 4-cyl. gasoline engine 1.8 L/140 kW 20V turbo base engine is T0L/T8C
7Q2 = Navigation system with color screen
CL6 = Alloy wheels 7.5J x 17
7K0 = Without tire pressure warning light
4X3 = Side air bag front with curtain air bag
VJ1 = Reinforced bumpers
6R2 = Leather gearshift boot
3L3 = Manual height adjustment for front seats
4KC = Side and rear windows in heat-insulatingglass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
1SA = Without additional front underbody guard
0GG = Emission standard EU4
Q1D = Sports front seats
4GH = Windshield in heat-insulating glass with sunshield
Zostało zrobione
Wyrzucony katalizator
Nowa odma
Założone turbo k03-073 po regeneracji, wcześniej siedziało k03-029
Log na k03-029
http://vaglog.pl/log_191253.html
A tu już na k03-073
http://vaglog.pl/log_204314.html
Moc i moment nie jest mi znany. Serią na pewno nie jest
Założone LPG
Stag 4
ACr01
Wtryski OMVL REG Fast XXl wtryski zostaną zastąpione na wydajniejsze (Pan gazownik tak samo jak ja nie wiedział, że auto ma powyżej 190 kunia) jeszcze nie wiem jakie myślę o dragonach
Do zrobienia uszczelki pod pokrywą zaworów, rozrząd oraz HHO tu już turbo także nie odczuwalne będzie w starej a3 było lekko czuć różnice.
Kilka fotek
Edit: Wymienione uszczelki pod pokrywą zaworów
Edit: Nowy cały rozrząd filtry i olej i od czasu do czasu kontrolka OIL :o
Edytowane przez Waść Kolorowość
Ładna sztuka :good:
Witam,
E4J = "S-line"
7A2 = CD changer
Zostało zrobione
Nowa odma
Log na k03-029
A tu już na k03-073
Założone LPG
Stag 4
ACr01
Kilka fotek
Witaj,
Gratulacje znalezienia ładnej opcji!
Planujesz wizytę na hamowni?
Ciekawe jaki soft tam siedzi?
Pozdrawiam!
Witaj,
Pozdrawiam!
W samochodzie siedzi soft firmy ABT, co widać w oznaczniu sterownika w logach jak i jest plomba na ECU ABT
Z hamownią możliwe, że kiedyś się wybiorę póki muszę LPG wzmocnić
Pamiętam ją z ogłoszeń, jakiś czas wisiała. Były gdzieś tutaj też zdjęcia sprzed naprawy blacharskiej, ogólnie bez dramatu.
Gdzie LPG montowałeś?
Posiadam te zdjęcia przed naprawą.
LPG monotwane u Pana Leszka Jabłońskiego ul. Junoszy w Lublinie
ladne wnetrze :hi:
Jakie Ty masz tam tarcze hamulcowe, bo felga chyba 15"...?
Dziwne, bo w BEXie szly standardowo 312mm, a te w 15" felgi nie wejdą.
Raczej jest to 16"
Fajna sztuka :)
To są 16'', w oryginale według naklejki powinny być 17 s-line
Nowy nierząd olej filtry i uszczelki pod pokrywą zaworów,
A teraz od czasu do czasu kontrolka OIL :o
Sprawdź jakie masz ciśnienie oleju. Może smok pompy zapchany.
Ciśnienie jest 1,2 bara nie ma tragedii. Może czujnik mi się psuję :)
Nadejszła wiekopomna chwila
Rwę silnik z powodu zużytego wału oraz bloku.
A miał być taki ładny :D
Dziś przyszło komplet sprzęgła z dwu-masem od AWX Sachsa, zobaczymy na dniach czy podejdzie.
Plus nowa uszczelka pod głowicą, uszczelniacz wału przód i tył.
Wrzucę foty jak znajdę aparat
Audi skończone cały komplet sprzęgła Sachsa z AWX-a podszedł bez problemu, blok wymieniony, tankować i jeździć.
Audi jeździ aż miło biegi wchodzą tak jak wchodziły, pasuję teraz wybrać się na hamowanie by zmierzyć moc i niuta.
Fajno, niech śmiga! Robiłeś remont tego pieca co masz czy kupiłeś słupek?
Jakie koszty w końcu wyszły takich zabaw?
Moc i niuta oszacujesz po logach.
Kupiłem kompletny blok bez głowicy 800 zł od bfb
Przy okazji z racji że silnik miałem na podłodze wymieniłem wszystkie uszczelniacze no i sprzęgło bo nie chciało mi się kiedyś tam rwać skrzyni, panewek nie ruszałem bo miały kompozyt jeszcze
Do tego uszczelka głowicy nowa.
Filtry olej i jakieś duperele
Łącznie jakoś 1400 zł części plus 1400 zł komplet sprzęgła robota nic bo sam robiłem czyli coś koło 2800 zł.
I chyba sztywny tip trzeba bo coś pierdzi, albo to DV
Ile masz obrotów na szóste przy 100 km/h ?
U mnie jest 2600 obr/min
http://vaglog.pl/log_204554.html
Log ile szacujesz ? kunia i niuta ?
Po przepływie jakieś 210KM.
Chyba turbo od 4400RPM lekko niedoładowuje.
Nm sprawdzisz jak dobrze pamiętam na kanale 120 - ale musisz w miarę dokładnie zważyć auto. Popytaj bardziej obeznanych.
Koszty w miarę jak na zakres i to, że sprzęgło z dwumasem wrzuciłeś nowe.
U mnie przy 100kmph na VI jest jakies 2500RPM, góra 2600RPM. Niestety, skrzynia BEXowa jest krótka... w BFB przy skrzyni VI biegowej jest sporo mniej obrotów.
