domjenick Opublikowano 1 Maja 2008 Opublikowano 1 Maja 2008 strone wczesniej wkleilem linki z kodami-przejrzyj,a co do wklejki,to na jednym linku jest wzor,chyba od jakiegos paska,pewnie bedzie lepiej jak,ktos aklei ci fotke z konkretnego rocznika
KaczorComp Opublikowano 1 Maja 2008 Opublikowano 1 Maja 2008 Szanowni koledzy, bardzo proszę o przetłumaczenie moich kodów. Z góry dziekuję E0A - no special edition 4UE - airbag f. driver a. front seat passenger 6XC - outer rear view mirrors: powered 5SL - outer left rear view mirror: non-spherical 5RQ - outer right rear view mirror: convex 1KD - disc brakes, rear JOR - battery 380 A (80 Ah) 1LB - disc brakes, front 4LA - without controls 1AC - anti-lock brake system (ABS) 1BA - standard suspension/shock absorption 3FA - without roof insert (standard roof) 5MY - decorative aluminum inserts "stars graphite" 7X0 - without park distance control 4R2 - power windows front, mechanical window regulators rear FOY - vehicle with optional features 0L2 - electric throttle actuation 8GL - alternator 120A 0G1 - gearshift lever 0YF - weight category rear axle weight range 6 0JF - weight category front axle weight range 6 T1R - components for base engine, unit 028.R 3NZ - rear seat bench unsplit, backrest split folding 8JG - headlight with gas discharge lamp for driving on the right V1A – X0A - national sales program Germany 2PG - steering Wheel 8Q2 - automatic headlight-range adjustment static 9Q0 - without multi-function indicator/ on-board computer 8Z5 - engine cooling system, type 1 M6N - 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R 7Q0 - without navigation device C8N - alloy wheels 6J x 15 style not designated; 4B0 601 025 L offset 45 7K0 - without tire pressure warning light 4X3 - side airbag front with curtain airbag 2K1 - reinforced bumpers 6R1 - leatherette gearshift BOOT 3L1 - manual height adjustment for left front seat 3Y0 - without roll-up sun screen 4K4 - radio remote controlled central locking operated from inside and separate trunk release 5D1 - carrier frequency 433.92 MHz 1SA - without additional engine guard Q1A - standard front seats 4GH - windshield tinted with windshield sunshield
HiRide Opublikowano 2 Maja 2008 Opublikowano 2 Maja 2008 Szanowni koledzy, bardzo proszę o przetłumaczenie moich kodów. Z góry dziekuję E0A - no special edition 4UE - airbag f. driver a. front seat passenger 6XC - outer rear view mirrors: powered 5SL - outer left rear view mirror: non-spherical 5RQ - outer right rear view mirror: convex 1KD - disc brakes, rear JOR - battery 380 A (80 Ah) 1LB - disc brakes, front 4LA - without controls 1AC - anti-lock brake system (ABS) 1BA - standard suspension/shock absorption 3FA - without roof insert (standard roof) 5MY - decorative aluminum inserts "stars graphite" 7X0 - without park distance control 4R2 - power windows front, mechanical window regulators rear FOY - vehicle with optional features 0L2 - electric throttle actuation 8GL - alternator 120A 0G1 - gearshift lever 0YF - weight category rear axle weight range 6 0JF - weight category front axle weight range 6 T1R - components for base engine, unit 028.R 3NZ - rear seat bench unsplit, backrest split folding 8JG - headlight with gas discharge lamp for driving on the right V1A – X0A - national sales program Germany 2PG - steering Wheel 8Q2 - automatic headlight-range adjustment static 9Q0 - without multi-function indicator/ on-board computer 8Z5 - engine cooling system, type 1 M6N - 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R 7Q0 - without navigation device C8N - alloy wheels 6J x 15 style not designated; 4B0 601 025 L offset 45 7K0 - without tire pressure warning light 4X3 - side airbag front with curtain airbag 2K1 - reinforced bumpers 6R1 - leatherette gearshift BOOT 3L1 - manual height adjustment for left front seat 3Y0 - without roll-up sun screen 4K4 - radio remote controlled central locking operated from inside and separate trunk release 5D1 - carrier frequency 433.92 MHz 1SA - without additional engine guard Q1A - standard front seats 4GH - windshield tinted with windshield sunshield wiekszosc tych kodow jak nie wsystkie sa juz w tym temacie przetlumaczone
lukasera Opublikowano 24 Czerwca 2008 Opublikowano 24 Czerwca 2008 Te mi zostały i nie jestem pewien co do nich. możecie pomóc? chodzi mi o dokladne tłumaczenie. 1MU = Leather trimmed sports steering wheel for air bag system with Tiptronic 4KC = Side and rear windows in heat-insulatingglass 6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated 9Q4 = Multi-function display/on-board computerwith check control - FIS 0YL = Weight range 11 installation control only, no requirement forecast MR1 = 6-cyl. diesel engine 2.5 L/132 kW 24V TDI with fuel distributor injection pumpbase engine is T1K/T5T 1N1 = Power steering Jak gdzieś je przeoczyłem to sory. z góry dzięki
Pepin Opublikowano 24 Czerwca 2008 Opublikowano 24 Czerwca 2008 Te mi zostały i nie jestem pewien co do nich. możecie pomóc? chodzi mi o dokladne tłumaczenie. ..... 4KC = Side and rear windows in heat-insulatingglass szybki boczne i tylna atermiczne 6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated lusterka zewn. elektrycznie składane, elektrycznie ustawiane i podgrzewane 1N1 = Power steering Wspomaganie PS. Widzę że sporo osób ma z tym problemy 4KC Зеленое теплозащитное остекление http://www.vwgolf-club.ru/forum/viewtopic.php?p=71766&highlight=&sid=0c5857a8597c205e9f579fbecebc1f72 http://audi-club.ru/forum/showthread.php?t=57568&page=12
razk Opublikowano 10 Lipca 2008 Opublikowano 10 Lipca 2008 Co do Fis i Grzanych foteli to moje auto rowniez to ma a w kodach o tym cisza jak rowniez o pompowanych ledzwiach. A teraz troszke inne pytanie: 8RY = speakers with BOSE sound czy to oznacza ze powinno byc naglosnienie BOSE? mam 8 glosnikow i wzmacniacz lecz na oslonach glosnikow nie ma BOSE i glosniki tez jakos slabo wygladaja. chyba ktos podmienil:\ Moze ma ktos fotki jak powinien wygladac sprzet odpowiadajacy temu kodowi? Auto z 95 roku. I jak to jest wkoncu z tymi kodami? Bo jak juz wyzej pisalem mam bogatsze wyposazenie niz wynika z wlepki.
ShAMAN_666 Opublikowano 10 Lipca 2008 Opublikowano 10 Lipca 2008 Witam. Panowie pewnie uznacie pytanie za debilne, ale gdzie są zapisane te kody? Tylko te z naklejki w komorze zapasu? Wydaje mi się że tam to trochę ich mało jest jak tak patrzę na te wasze spisy. proszę o odpowiedź i pozdrawiam, Tomek
razk Opublikowano 10 Lipca 2008 Opublikowano 10 Lipca 2008 tak w komorze zapasu i na pierwszej stronie ksiazki serwisowej. Z tym ze jak pisalem wyzej tez mam wiecej wyposazenia niz na tej naklejce
pre_pl Opublikowano 10 Lipca 2008 Opublikowano 10 Lipca 2008 tak w komorze zapasu i na pierwszej stronie ksiazki serwisowej. Z tym ze jak pisalem wyzej tez mam wiecej wyposazenia niz na tej naklejce pisaliśmy nie raz (zdaje się nawet w tym temacie), że na naklejce (obojętnie gdzie jest) nie ma wszystkich kodów. Pełen wykaz mozliwy przy rozkodowaniu VINu.
Popers Opublikowano 12 Lipca 2008 Opublikowano 12 Lipca 2008 Ja mam prośbę o przetłumaczenie tych 3 kodów : TD0 lub TDO (nie mogę rozróżnić czy to zero czy litera o :/ ) , X4J i CH3 , gdyż tych kodów nawet poprzez szukaj nie mogłem odnaleźć
domelq Opublikowano 12 Lipca 2008 Opublikowano 12 Lipca 2008 TD0 = 4-cylinder diesel engine 1.9 L unit 03G.5 silnik diesel 4 cylindrowy 1.9 L jednostka 03G.5 X4J = National sales program Poland wersja przeznaczona na Polskę CH3 = Steel wheels 7J x 16 Koła stalowe 7J x 16 [br]Dopisany: 12 Lipiec 2008, 15:53 _________________________________________________Nie wiecie gdzie można zdekodowac VINa, aby dostać pełną listę wyposażenia? Oczywiście oprócz ASO Powyższe linki nie chcą zadziałać
Popers Opublikowano 12 Lipca 2008 Opublikowano 12 Lipca 2008 domelq wielkie dzięki tylko, że ja mam fele aluminiowe, ale może tak się zwą, ale mniejsza z tym I podłączam się również do pytania
domelq Opublikowano 12 Lipca 2008 Opublikowano 12 Lipca 2008 To dziwne.... Fele aluminiowe to by było: Cast alloy wheels Na bank w kodzie masz stalowe. Jak masz od nowości auto to mogło być tak, że: zamówienie poszło na stalówki a na salonie założyli Ci alu. Jesli masz nie odnowości autko to może już ktoś zmienił
Popers Opublikowano 12 Lipca 2008 Opublikowano 12 Lipca 2008 alu mam od nowości od momentu wyjazdu z salonu, i są to felgi ale co tam, ważne że są :> i całkiem ładnie wyglądają (7 ramienne), a wiesz już może jak odkodować ten vin, żeby sprawdzić resztę??
domelq Opublikowano 13 Lipca 2008 Opublikowano 13 Lipca 2008 Nie. Znalazłem jakieś linki do strony, gdzie to było moźliwe, ale serwis już nie działa. Pewnie ktoś go wstrzymał komu było nie na rękę, żeby on działał. Ale jak coś znajde to dam na pewno znać.
waldi1972 Opublikowano 19 Lipca 2008 Opublikowano 19 Lipca 2008 Bardzo ciekawe, nie znalazłem jednak kilku kodów: TB3 7A0 J1D C7A 8BB 0GG 5MU 4X3 0YK 6TS 4R5 0JJ D3X 4GF a są na mojej naklejce. Może ktoś pomóc? Pozdrawiam
adamq Opublikowano 19 Lipca 2008 Opublikowano 19 Lipca 2008 Bardzo ciekawe, nie znalazłem jednak kilku kodów: TB3 7A0 J1D C7A 8BB 0GG 5MU 4X3 0YK 6TS 4R5 0JJ D3X 4GF a są na mojej naklejce. Może ktoś pomóc? Pozdrawiam TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B 7A0 = Without CD changer/CD player J1D = Battery 380 A (72 Ah) C7A = Cast alloy wheels 7J x 16 8BB = Halogen headlight for driving on the right 0GG = Emissions concept EU 4 5MU = Decorative aluminum inserts 4X3 = Side air bag front with curtain air bag 0YK = Weight range 10 installation control only, no requirement forecast 6TS = Right exterior mirror: aspherical, large viewing field 4R5 = Power windows with comfort operation andcircuit breaker, mechanical window regulators rear 0JJ = Weight category front axle weight range 9 D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0 4GF = Windshield in heat-insulating glass
kajek Opublikowano 23 Lipca 2008 Opublikowano 23 Lipca 2008 A ja zgłupiałem do granic możliwości że mi zaraz pompa stanie. Mam kodziki różne ale czy mogę mieć dwa silniki az maskę podniosłem i tylko 1 i bagażnik otworzyłem brak zapasowego, o co tu chodzi: M9L i M5S
