RumJanek Opublikowano 19 Lipca 2016 Opublikowano 19 Lipca 2016 Witajcie mam na oku jedna sztukę, ale ma kilka błędów, ktoś powie co jej nie halo i jakie sa koszty doprowadzenia tego do porzadku? Z góry dzięki Tuesday,19,July,2016,20:33:25:65217VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.0.0Data version: 20130910VIN: WAUZZZ8K4AA074103 License Plate: SGSFCVGDHSVCMileage: 208100km-129307mi Repair Order:----------------------------------------------------------------------------------------------------------------------------------------------------------------Chassis Type: 8K (8T0)Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72 77VIN: WAUZZZ8K4AA074103 Mileage: 208100km/129307miles01-Engine -- Status: Malfunction 001003-ABS Brakes -- Status: OK 000004-Steering Angle -- Status: OK 000005-Acc/Start Auth. -- Status: OK 000008-Auto HVAC -- Status: OK 000009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: Malfunction 001042-Door Elect, Driver -- Status: Malfunction 001046-Central Conv. -- Status: Malfunction 001047-Sound System -- Status: OK 000052-Door Elect, Pass. -- Status: OK 000053-Parking Brake -- Status: OK 000056-Radio -- Status: OK 000062-Door, Rear Left -- Status: OK 000072-Door, Rear Right -- Status: OK 000077-Telephone -- Status: OK 0000-------------------------------------------------------------------------------Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb Part No SW: 03L 906 022 NP HW: 03L 906 019 AL Component: R4 2,0L EDC H21 9098 Revision: 25H21--- Coding: 0A194012232503080000 Shop #: WSC 00047 210 92509 ASAM Dataset: EV_ECM20TDI03L906022NP A02009 ROD: EV_ECM20TDI03L906022NP.rod VCID: 800518401BFD421E143-80D53 Faults Found:4985 - Cylinder 2 Glow Plug Circuit (Q11) P0672 00 [109] - Electrical Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 6 Mileage: 196266 km Date: 2014.09.06 Time: 10:31:404986 - Cylinder 3 Glow Plug Circuit (Q12) P0673 00 [109] - Electrical Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 6 Mileage: 199871 km Date: 2015.02.10 Time: 13:01:074891 - EGR Valve (N18) P0403 00 [032] - Malfunction Intermittent - Not Confirmed - Tested Since Memory ClearReadiness: 0 0 0 0 0-------------------------------------------------------------------------------Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK Component: ESP8 front H04 0070 Revision: -------- Serial number: -------------- Coding: 160504 Shop #: WSC 06325 000 00000 VCID: 820112481DF1500E027-80D7No fault code found.-------------------------------------------------------------------------------Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DC HW: 8K0 907 064 DC Component: BCM2 1.1 H02 0326 Revision: 00002001 Coding: 033100 Shop #: WSC 06325 000 00000 VCID: 74EDC490D745EEBE80B-8021 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042No fault code found.-------------------------------------------------------------------------------Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG Component: KLIMA 3 ZONEN H08 0171 Revision: D1000000 Serial number: 01141020091452 Coding: 34240000 Shop #: WSC 06325 000 00000 VCID: 77F7F39CC63385A6A59-8022No fault code found.-------------------------------------------------------------------------------Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 M HW: 8K0 907 063 M Component: BCM1 1.0 H25 0380 Revision: 08025001 Serial number: 00000000363469 Coding: 690040B10034A7010001000300005F5F001D020804000141000000 Shop #: WSC 06325 000 00000 VCID: 397335A4B0A753D693D-806C Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 121009 H05 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090No fault code found.-------------------------------------------------------------------------------Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD06E0L0 Coding: 30363435363030303030554A3052384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 41835D44D0770B16DBD-8014 Crash sensor for side airbag; driver side: Serial number: 6334MSME4C142746D Crash sensor for side airbag; passenger side: Serial number: 6344MSME4C4531003 Crash sensor for side airbag; rear driver side: Serial number: 6352QSME19404A36E Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME513E2D18P Crash sensor for front airbag; driver side: Serial number: 63732SME1E3F4C36E Crash sensor for front airbag; passenger side: Serial number: 63832SME143F3D00$No fault code found.-------------------------------------------------------------------------------Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304IJD000EF Coding: 000016 Shop #: WSC 06325 000 00000 VCID: 3D7B21B4A48F6FF6BF5-8068 Component: E221 - MFL H02 0003No fault code found.-------------------------------------------------------------------------------Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 980 N HW: 8K0 920 980 N Component: KOMBIINSTR. H20 0255 Revision: 00000000 Serial number: CIZ51C7A9 Coding: 2F04080002002600010000 Shop #: WSC 06325 000 00000 VCID: 3D7B21B4A48F6FF6BF5-8068No fault code found.-------------------------------------------------------------------------------Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 R HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0105 Revision: GB600050 Serial number: 5000G09929826C Coding: 00CF07 Shop #: WSC 06325 000 00000 VCID: 50A56800031DF29E443-8005 Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181 Component: J367-BDM H07 0125 Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663 Component: J532_DCDCStab H14 00371 Fault Found:03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 95 Reset counter: 31 Mileage: 196748 km Time Indication: 0 Date: 2014.09.25 Time: 00:29:00 Freeze Frame: Bin. Bits: 00000 Voltage: 12.40 V Count: 17-------------------------------------------------------------------------------Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 J HW: 8K0 959 793 E Component: TSG FA H11 0306 Revision: Serial number: 0000102065763 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 4797435CF6533526159-80121 Fault Found:02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 10 Reset counter: 34 Mileage: 207427 km Time Indication: 0 Date: 2016.02.11 Time: 12:07:20-------------------------------------------------------------------------------Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 DC HW: 8K0 907 064 DC Component: BCM2 1.1 H02 0326 Revision: 00002001 Serial number: 0122556527 Coding: 011B0622003904400020010400000000 Shop #: WSC 06325 000 00000 VCID: 74EDC490D745EEBE80B-8021 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 13011 Fault Found:01503 - Bulb for 3rd Brake Light (M25) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 35 Mileage: 208100 km Time Indication: 0 Date: 2016.07.15 Time: 13:07:38-------------------------------------------------------------------------------Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb Part No SW: 8T0 035 223 AH HW: 8T0 035 223 Component: DSP STD H07 0230 Revision: S2200000 Coding: 0203010102 Shop #: WSC 06325 000 00000 VCID: 74EDC490D745EEBE80B-8021No fault code found.-------------------------------------------------------------------------------Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 J HW: 8K0 959 792 E Component: TSG BF H11 0306 Revision: Serial number: 0000102076268 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 46894E58F1592C2EEEF-8013No fault code found.-------------------------------------------------------------------------------Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000473124 Shop #: WSC 00000 000 00000 VCID: 346D049097C5AEBE40B-8061No fault code found.-------------------------------------------------------------------------------Address 56: RadioCannot be reached-------------------------------------------------------------------------------Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000102087536 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 42815248DD71100EC27-8017No fault code found.-------------------------------------------------------------------------------Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000102087484 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 42815248DD71100EC27-8017No fault code found.-------------------------------------------------------------------------------Address 77: TelephoneCannot be reachedEnd ---------------------------------------------------------------------
sowiq Opublikowano 20 Lipca 2016 Opublikowano 20 Lipca 2016 Jak dla mnie to te błędy to jakieś pierdoły: - jakiś niezidentyfikowany problem z EGR (to chyba najpoważniejszy problem) - dwa stare błędy o problemie ze świecami / cewkami (zalogowane w 2014 i na początku 2015 roku) - zarządzanie energią, czyli rozładowany akumulator - problem z zamkiem drzwi (standard w tych modelach) - przepalona żarówka
RumJanek Opublikowano 20 Lipca 2016 Autor Opublikowano 20 Lipca 2016 Auto pierwsze dwa lata latały w firmie, ponoć taxi, robiło rocznie po 55k mil = +/-86k km, później kupił je dziadek gdzie przez ponad trzy lata zrobił nią 30k km, w ostatnim roku zrobił 2k km, w tym zmarł na raka zostawiając auto w ostatnich dniach przyjacielowi... Ma różne wpisy w serwis, chodzi ładnie na wolnych, trzyma 800rpm, nie szarpie nią, nie miałem jednak możliwości jazdy próbnej, była ubezpieczona jeszcze na zmarłego, nie wycofali jeszcze ubezpieczenia. Jest podany VIN, może mógłbym kogoś prosić o sprawdzenie jej co dokładnie z nią było robione, za co dziękuję. Wieczorem muszę albo odmówić albo zostawić zadatek i odebrać kiedy chce. Arku był rozladowany, stała prawie rok. Zaraz wklejenia linka, może ktoś coś zauważy w niej ciekawego. Wysłane z mojego GT-I9505 przy użyciu Tapatalka
sowiq Opublikowano 20 Lipca 2016 Opublikowano 20 Lipca 2016 Raczej tutaj pisz jak potrzebujesz pomocy w zakupie: http://a4-klub.pl/index.php?/forum/242-audi-a4-b8/
RumJanek Opublikowano 20 Lipca 2016 Autor Opublikowano 20 Lipca 2016 A ma ktoś dojścia do VIN i wkleić mi tutaj? Wysłane z mojego GT-I9505 przy użyciu Tapatalka Czyli mówisz że technicznie błędy które są to niewielkie problemy i nie ma się czego obawiać? Wysłane z mojego GT-I9505 przy użyciu Tapatalka
Wolf1991 Opublikowano 20 Lipca 2016 Opublikowano 20 Lipca 2016 Jesli chcesz sprawdzic po historię po vinie to pisz do kolegi Stanley
MarcinOslo Opublikowano 22 Lipca 2016 Opublikowano 22 Lipca 2016 Cos tu jest tez nie halo z multimedia ,bo 56 radio i 77 telephone jest nieosiagalne. Moze byc tylko bezpiecznik ,ale moze byc rowniez cos powazniejszego.
RumJanek Opublikowano 22 Lipca 2016 Autor Opublikowano 22 Lipca 2016 Sprawdzałem radio i działało, telefonu jeszcze nie. Auto stało przez ostatni rok, wyładował się totalnie akku i założyli nowy. Czy jest możliwe że nałapane błędy mogą być od tego? Pozdrawiam, Rum
komoornik Opublikowano 22 Lipca 2016 Opublikowano 22 Lipca 2016 Zdajesz sobie sprawę z tego, że pchanie się w auto które stało rok to proszenie się o kłopoty?
RumJanek Opublikowano 22 Lipca 2016 Autor Opublikowano 22 Lipca 2016 (edytowane) Zdaje sobie sprawę że będzie za ulotne i trzeba będzie go trochę rozruszac. Swoją drogą, moje też wyrwalem jak stało w kącie komisu, zakurzone i nikt go nie chciał z prostego powodu: sprzęgło wysokie, benzyna, quattro, turbo, sport i jak nie masz dużych zniżek to lepiej omijaj takie auto. Odkad go mam jestem zadowolony... Poza tym zamiast pocieszyć to od razu dolujesz człowieka Najwyzej się wystawi na ebayu i po kłopocie Mała poprawka: 5.5k mil od ostatniego MOT, 1k mil zrobił gość jak przejął niedawno samochód. Ostatni przegląd końcem listopada ubiegłego roku. Czyli stał ale niewiele, na 100% całego roku nie stał. Edytowane 22 Lipca 2016 przez RumJanek
