Gość Murzyn Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 Brynia VAG-COM Version: Release 311.2-N Control Module Part Number: 8E0 614 517 A Component and/or Version: ABS/ESP allrad 1726 Software Coding: 04475 Work Shop Code: WSC 06435 2 Faults Found: 00273 - ABS Inlet Valve: Right Rear (N133) 35-10 - - - Intermittent 00526 - Brake Light Switch-F 36-10 - Open Circuit - Intermittent VAG-COM Version: Release 311.2-N Control Module Part Number: 8E0 953 549 L Component and/or Version: Lenksáulenmodul 0308 Software Coding: 02012 Work Shop Code: WSC 63351 1 Fault Found: 00474 - Control Module for Immobilizer 49-10 - No Communications - Intermittent tak to jest szalec po sniegowych placach MAX VAG-COM Version: Release 311.2-N Control Module Part Number: 4D0 907 551 Component and/or Version: 2.8L V6/5V MOTR HS D09 Software Coding: 04201 Work Shop Code: WSC 06335 7 Faults Found: 01249 - Fuel Injector for Cylinder 1 (N30) 26-10 - Output Open - Intermittent 01250 - Fuel Injector for Cylinder 2 (N31) 26-10 - Output Open - Intermittent 01251 - Fuel Injector for Cylinder 3 (N32) 26-10 - Output Open - Intermittent 01252 - Fuel Injector for Cylinder 4 (N33) 26-10 - Output Open - Intermittent 01253 - Fuel Injector for Cylinder 5 (N83) 26-10 - Output Open - Intermittent 01254 - Fuel Injector for Cylinder 6 (N84) 26-10 - Output Open - Intermittent 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent grzesioo 5 Faults Found: 00561 - Mixture Adaptation 15-00 - Adaptation Limit (Add) Not Reached 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent 17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded P1326 - 35-10 - - - Intermittent 17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded P1327 - 35-10 - - - Intermittent 16705 - Engine Speed Sensor (G28): Implausible Signal P0321 - 35-10 - - - Intermittent schiller 7 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent 00561 - Mixture Adaptation 15-10 - Adaptation Limit (Add) Not Reached - Intermittent 01249 - Fuel Injector for Cylinder 1 (N30) 29-10 - Short to Ground - Intermittent 01250 - Fuel Injector for Cylinder 2 (N31) 29-10 - Short to Ground - Intermittent 01251 - Fuel Injector for Cylinder 3 (N32) 29-10 - Short to Ground - Intermittent 01252 - Fuel Injector for Cylinder 4 (N33) 29-10 - Short to Ground - Intermittent nie zapislem kto 5 Faults Found: 00561 - Mixture Adaptation 15-00 - Adaptation Limit (Add) Not Reached 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent 17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded P1326 - 35-10 - - - Intermittent 17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded P1327 - 35-10 - - - Intermittent 16705 - Engine Speed Sensor (G28): Implausible Signal P0321 - 35-10 - - - Intermittent
Gość Kaziu_Wichura Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 Murzyn misiu malinowy, rozwiązaliście jakoś te problemy? :biggrin: Błędy błędami ale co dalej?
Gość Kaziu_Wichura Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 zalezy co u kogo... no w zasadzie ciekawi mnie rozwiązanie wszystkich problemów ale najbardziej Shillera bo ma taki sam silnik. Co tam zdziałaliście?
Gość Murzyn Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 chyba byly 3 silniki 1.8 Nie powniem Ci teraz, bo nie pamietam dokladnie, ale niektore bledy wystarczylo wykasowac i pozniej sie nie pojawialy... (sprawdz kody bledow i od czego mogly byc) inne powstawaly od instalacji gazowej i na tym sie kompletnie nie znam.
Gość Kaziu_Wichura Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 acha kumam. Myślałem, że było jakieś ostre grzebanie. Dzięki za info. PS Kody sprawdziłem na wstępie
Gość Murzyn Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 glownie chodzilo o wykasowanie i sprawdzenie czy sie pojawia ponownie po przejechaniu kilku km. u bryni sprawa byla prosta (mam nadzieje ze wyleczona i juz nie bedzie problemow z esp)
Sprinter Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 Bo jak się grzebie pod maską i nie chce mieć błędów, to trzeba aku odpinać, a jak nie to potem kasuje się takie stosy dupereli
schiller Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 chyba byly 3 silniki 1.8 Nie powniem Ci teraz, bo nie pamietam dokladnie, ale niektore bledy wystarczylo wykasowac i pozniej sie nie pojawialy... (sprawdz kody bledow i od czego mogly byc) inne powstawaly od instalacji gazowej i na tym sie kompletnie nie znam. ale to chyba nie u mnie, bo takowej nie mam. a jak to jest z moimi bledami wtryskow? powinienem sie martwic?
MAx Opublikowano 5 Marca 2007 Opublikowano 5 Marca 2007 MAX VAG-COM Version: Release 311.2-N Control Module Part Number: 4D0 907 551 Component and/or Version: 2.8L V6/5V MOTR HS D09 Software Coding: 04201 Work Shop Code: WSC 06335 7 Faults Found: 01249 - Fuel Injector for Cylinder 1 (N30) 26-10 - Output Open - Intermittent 01250 - Fuel Injector for Cylinder 2 (N31) 26-10 - Output Open - Intermittent 01251 - Fuel Injector for Cylinder 3 (N32) 26-10 - Output Open - Intermittent 01252 - Fuel Injector for Cylinder 4 (N33) 26-10 - Output Open - Intermittent 01253 - Fuel Injector for Cylinder 5 (N83) 26-10 - Output Open - Intermittent 01254 - Fuel Injector for Cylinder 6 (N84) 26-10 - Output Open - Intermittent 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent moje co prawda pozniej nie wystapily ale czy kotrs mogl by przelozy z ichniego na nasz co to tam sie ukazlo?
szogun0 Opublikowano 6 Marca 2007 Opublikowano 6 Marca 2007 grzesioo 5 Faults Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent A kto zaglądnie do immo celem skasowania 1176 albo 1177
Gość Murzyn Opublikowano 6 Marca 2007 Opublikowano 6 Marca 2007 immo o dziwo bylo czyste :confused: sprawdzalem, immo, poduszki,ABS, centralny (bledy centralnego wywalalo chyba w kazdej, ale tym sie niema co przejmowac)... (gdzie sie dalo, bo nie u kazdego - ogolnie te pozycje z ktorymi vag sie laczy)
Gość Kaziu_Wichura Opublikowano 6 Marca 2007 Opublikowano 6 Marca 2007 MAx, 01249 P0201 Cylinder 1 – usterka wtrysku – N30 01250 P0202 Cylinder 2 – usterka wtrysku – N31 01251 P0203 Cylinder 3 – usterka wtrysku – N32 01252 P0204 Cylinder 4 – usterka wtrysku – N33 01253 P0205 Cylinder 5 – usterka wtrysku – N83 01254 P0206 Cylinder 6 – usterka wtrysku – N84 [ Dodano: 06-03-2007, 14:40 ] ale to chyba nie u mnie, bo takowej nie mam. a jak to jest z moimi bledami wtryskow? powinienem sie martwic? jeśli nie pojawiły się ponownie to nie ma czym się przejmować. Może to jakieś starocie wynikające z chwilowego niedomagania
adamq Opublikowano 6 Marca 2007 Opublikowano 6 Marca 2007 jeśli nie pojawiły się ponownie to nie ma czym się przejmować. Może to jakieś starocie wynikające z chwilowego niedomagania Takie błędy mogły wyskoczyć np. gdy instalowali LPG. Mogli na początku źle podpiąć się pod wtryski i odpalili i wariował. Potem podpięli normalnie i ok. Po prostu nie skasowali błędów...
schiller Opublikowano 6 Marca 2007 Opublikowano 6 Marca 2007 jeśli nie pojawiły się ponownie to nie ma czym się przejmować. Może to jakieś starocie wynikające z chwilowego niedomagania Takie błędy mogły wyskoczyć np. gdy instalowali LPG. Mogli na początku źle podpiąć się pod wtryski i odpalili i wariował. Potem podpięli normalnie i ok. Po prostu nie skasowali błędów... ale ja juz mowilem ze nie mam LPG
adamq Opublikowano 6 Marca 2007 Opublikowano 6 Marca 2007 ale ja juz mowilem ze nie mam LPG Ale mnie nie chodziło o Ciebie kolego. U ciebie, jeżeli się błędy nie powtarzają, to jest ok. Mnie chodziło o MAxa :biggrin: Źle zacytowałem... 01249 P0201 Cylinder 1 – usterka wtrysku – N3001250 P0202 Cylinder 2 – usterka wtrysku – N31 01251 P0203 Cylinder 3 – usterka wtrysku – N32 01252 P0204 Cylinder 4 – usterka wtrysku – N33 01253 P0205 Cylinder 5 – usterka wtrysku – N83 01254 P0206 Cylinder 6 – usterka wtrysku – N84
MAx Opublikowano 7 Marca 2007 Opublikowano 7 Marca 2007 MAX VAG-COM Version: Release 311.2-N Control Module Part Number: 4D0 907 551 Component and/or Version: 2.8L V6/5V MOTR HS D09 Software Coding: 04201 Work Shop Code: WSC 06335 7 Faults Found: 01249 - Fuel Injector for Cylinder 1 (N30) 26-10 - Output Open - Intermittent 01250 - Fuel Injector for Cylinder 2 (N31) 26-10 - Output Open - Intermittent 01251 - Fuel Injector for Cylinder 3 (N32) 26-10 - Output Open - Intermittent 01252 - Fuel Injector for Cylinder 4 (N33) 26-10 - Output Open - Intermittent 01253 - Fuel Injector for Cylinder 5 (N83) 26-10 - Output Open - Intermittent 01254 - Fuel Injector for Cylinder 6 (N84) 26-10 - Output Open - Intermittent 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent a co oznaczaj tye cyfy po "N" i czy ja dobrze rozumiem ze jakies ustawieni przepustnicy jest nie halo-gazownik mowil ze mam brudna, czy to ma cos wspolnego
Sprinter Opublikowano 7 Marca 2007 Opublikowano 7 Marca 2007 N3x to numery wtrysków, przepustnicę możesz mieć brudną, bo masz błąd jej pozycjonowania. Bieraj pendzelek, benzykę i jazda :biggrin:
MAx Opublikowano 7 Marca 2007 Opublikowano 7 Marca 2007 dzieki za wyjasnienia.zbieram sie juz od miesiac za to tylko nie zabardzo wiem jak si emam do niej dokopac
