A4 B6 Multi Opublikowano 25 Lipca 2018 Opublikowano 25 Lipca 2018 Witam koledzy, mam problem.W aucie został wymieniony ECU i nie wiem jakim sposobem przerzucić immo ze starego do nowego? Stawiam flaszkę jak mi ktoś pomoże:) A4 B7 2.0TDI 2005R
kamil-vag Opublikowano 26 Lipca 2018 Opublikowano 26 Lipca 2018 (edytowane) Immo3 [Select][01 - Engine] [Login - 11]For the following procedure, use the PIN of the REPLACEMENT (USED) ECU. 4-digit PIN The PIN needs to be entered as 5-digit number in the New Value box. For example, if your PIN is 1234, enter 01234. [Do it!] [Adaptation - 10] Enter 050 in "Channel Number".[Read]For the following procedure, use the PIN of the ORIGINAL (OLD) ECU. 4-digit PIN The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234. [Test] The values may change to "32000", this is normal [Save][Done, Go Back][Close Controller, Go Back - 06] Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again. Verify that the REPLACEMENT (USED) ECU now shows the VIN and if supported IMMO-ID of the vehicle now. Verify that the REPLACEMENT (USED) ECU has the same Coding as the original unit, or code it from scratch using the repair manual or coding chart in VCDS when applicable. Immo4 [Select][01 - Engine] [Security Access - 16]For the following procedure, use the PIN of the NEW (USED) ECU. 4/5-digit PIN The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234. [Do it!] The instrument cluster now shows Immobilizer Adaptation active, wait until it changes to Immobilizer active - this may take up to 2 Minutes. [Adaptation - 10] Enter 050 in "Channel Number".[Read]For the following procedure, use the PIN of the OLD (ORIGINAL) ECU. 4/5-digit PIN The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234. [Test] Check the 1st measuring value.[Save][Done, Go Back][Close Controller, Go Back - 06] Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again. Verify that the NEW (USED) ECU now shows the VIN (and if supported IMMO-ID) of the vehicle now. The challenge of instrument cluster and ECU never matches, so don't bother checking them. Edytowane 26 Lipca 2018 przez kamil-vag
