pelonek1 Opublikowano 27 Lutego 2021 Opublikowano 27 Lutego 2021 Potrzebuję pilnie opis grup bloku pomiarowego silnika CDYA. Z góry dziękuję.
Banan Opublikowano 27 Lutego 2021 Opublikowano 27 Lutego 2021 (edytowane) Basic setting as at 30.10. 2008 for 2.7/3.0 L TDI CR Engine code letters: CANA, CANB, CANC, CAND, CDYA, CDYB, CDYC 001 Quantity adjustment 1) Engine speed At idle: 610 ... 810 rpm 2) Injection quantity mean At idle: 4 ... 11 mg/stroke 3) Rail pressure actual Check values with measured value block 020 4) Coolant temperature Warmed-up: 70 ... 115 °C 002 Idling speed 1) Engine speed At idle: 610 ... 810 rpm 2) Accelerator pedal position At idle: 0 % At full throttle: 100% 3) Accelerator pedal switch settings X X X X X X X 1 Status AC compressor ON X X X X 1 X X X Idling speed switch ON X X X 1 X X X X Kickdown switch ON X 1 X X X X X X Idling speed increased 4) Coolant temperature Warmed-up: 70 ... 115 °C 003 Exhaust gas recirculation EGR 1) Engine speed At idle: 610 ... 810 rpm 2) Specified intake air mass [mg/stroke] 3) Actual air mass [mg/stroke] 4) EGR control value [%] 004 Main injection 1) Engine speed At idle: 610 ... 810 rpm 2) Main injection, start of activation [°CA] 3) Main injection, duration of activation [ms] 4) Rail pressure actual Check values with measured value block 020 005 Starting conditions Stored from last engine start 1) Engine speed [rpm] 2) Starting injection quantity [mg/stroke] 3) Start synchronisation 001 No synchronisation between engine control unit and engine 005 Too many resynchronisation cycles Torsion between crankshaft and camshaft too large 020 Position for synchronisation set by run-out detector 033 Synchronisation present, but still being checked 036 Synchronisation present, but still being checked (slave engine control unit only) 038 No valid camshaft signal, run camshaft emergency mode to synchronise 048 Synchronisation complete --> Starting OK 060 No valid crankshaft signal, crankshaft emergency running mode 4) Coolant temperature [°C] 006 Cruise control system CCS 1) Vehicle speed CCS activatable: above 35 km/h 2) CCS status X X X X X X X 1 Brake light switch pressed X X X X X X 1 X Brake pedal switch pressed X X X X X 1 X X Clutch pedal switch pressed X X X X 1 X X X CCS enabled X X X 1 X X X X ACC enabled X X 1 X X X X X Main switch ON 0 0 X X X X X X ACC/CCS mode inactive 1 0 X X X X X X State overspill 0 1 X X X X X X ACC/CCS in control range 1 1 X X X X X X ACC not enabled 3) CCS target speed [km/h] 4) CCS switch settings X X X X X X X 1 Main switch ON X X X X X X 1 X Tapped OFF X X X X X 1 X X Tap Down, reduce X X X X 1 X X X Tap Up, increase X X X 1 X X X X Set X X 1 X X X X X Resume X 1 X X X X X X Fault message steering column module 1 X X X X X X X Main switch hardware locked ON 007 Temperature senders 1) Fuel temperature to 70 °C 2) Oil temperature Warmed-up: 70 ... 110 °C 3) Intake air temperature to 90 °C 4) Coolant temperature Warmed-up: 70 ... 115 °C 008 Limiting torques 1) Engine speed [rpm] 2) Engine torque specification [Nm] Driver input via accelerator pedal 3) Torque limitation [Nm] 4) Smoke limitation [Nm] 009 Limiting torques 1) Engine speed [rpm] 2) CCS limiting torque [Nm] 3) Limiting torque gearbox control unit [Nm] 4) Limiting torque [Nm] 010 Air quantities 1) Actual air mass At idle: 210 ... 280 mg/stroke At full throttle: > 1050 mg/stroke At ambient air pressure 970 ... 1020 mbar 2) Ambient air pressure [mbar] 3) Actual charge pressure At idle: 950 ... 1080 mbar At full throttle: > 2150 mbar At ambient air pressure 970 ... 1020 mbar 4) Accelerator pedal position [%] - With exhaust gas recirculation switched off, e.g. due to high intake air temperature the air mass at idle may be increase In this case press the accelerator in short bursts and check whether the air mass then decreases. - Additionally check air mass via basic setting of EGR and turbocharger basic setting. 011 Charge pressure control 1) Engine speed [rpm] 2) Specified charge pressure [mbar] 3) Actual charge pressure At idle: 950 ... 1080 mbar At full throttle: > 2150 mbar At ambient air pressure 970 ... 1020 mbar 4) Charge pressure control value [%] 012 Preheating system 1) Preheating system status 0 0 0 0 0 0 0 0 Waiting for coolant temperature 0 0 0 0 0 0 0 1 Waiting for start request 0 0 0 1 0 0 0 0 Glow period 0 1 0 1 0 0 0 0 No glow 1 0 1 1 0 0 0 0 After-glow 1 1 0 0 0 0 0 0 No start glow 1 1 1 1 0 0 0 0 Intermediate glow 0 0 1 1 0 0 0 0 Readiness glow 0 1 1 1 0 0 0 0 Start glow 1 0 1 1 0 0 0 1 Waiting for after-glow 1 1 0 1 0 0 0 0 No after-glow 1 1 1 1 0 0 0 1 Waiting for intermediate glow 1 1 1 1 1 1 1 1 No glow 2) Glow period [s] 3)Vehicle voltage [V] 4) Coolant temperature [°C] 013 Smooth running control 1) Cylinder 1 injection quantity variation [mg/stroke] 2) Cylinder 2 injection quantity variation [mg/stroke] 3) Cylinder 3 injection quantity variation [mg/stroke] 4) Vacant Permissible values at idle: +- 1.5 mg/stroke A If the permissible tolerance is exceeded first check injector IQA-IVA adaption values, if OK electrical wiring and connectors from engine control unit to injector 014 Smooth running control 1) Cylinder 4 injection quantity variation [mg/stroke] 2) Cylinder 5 injection quantity variation [mg/stroke] 3) Cylinder 6 injection quantity variation [mg/stroke] 4) Vacant Permissible values at idle: +- 1.5 mg/stroke A If the permissible tolerance is exceeded first check injector IQA-IVA adaption values, if OK electrical wiring and connectors from engine control unit to injector 015 Fuel consumption 1) Engine speed [rpm] 2) Actual engine torque [Nm] 3) Fuel consumption [litres/h] 4) Engine torque specification [Nm] Driver input via accelerator pedal 016 Additional heater Only A4, A5, A6 1) Additional heater enable 0 0 No enable 0 1 No enable stage 1 1 0 No enable stage 2 1 1 Enable stages 1 and 2 2) Additional heater shut-off conditions X X X X X X X 0 No shut-off condition X X X X X X X 1 Coolant temperature adequate X X X X X X 1 X Alternator load signal fault X X X X X 1 X X Battery voltage too high X X X X 1 X X X Engine speed too low X X X 1 X X X X Start delay active X X 1 X X X X X Water temperature sensor, air temperature sensor or output stage defective X 1 X X X X X X Operating switch (not active) 1 X X X X X X X Intake manifold temperature adequate 3) Additional heater relay activation 0 0 Relay not activated 0 1 Low heat output relay 1 0 High heat output relay 1 1 Both relay contacts active 4) Alternator output 017 --- For readiness code see 089 018 Rail pressure control 1) Engine speed [rpm] 2) Fuel temperature [°C] 3) Rail pressure control status 00 Ignition on, open-loop control mode 01 Open-loop control mode after start 02 Closed-loop control via pressure regulating valve (on switch between open-loop and closed-loop control) 03 Closed-loop control via solenoid valve (on switch between open-loop and closed-loop control) 04 Closed-loop control via pressure regulating valve (normal operating mode) 05 Closed-loop control via solenoid valve (normal operating mode) 06 Closed-loop control via pressure regulating valve (on switch to pressure regulation via quantity control valve) 07 Open-loop control (engine is stopped) 08 Open-loop control (on switch from open-loop to closed-loop control) 11 Open-loop control after running tank empty 15 Closed-loop control via pressure regulating valve and quantity control valve 16 Switch after closed-loop control via pressure regulating valve to quantity control valve 17 Switch after CPC closed-loop control 18 Switch after closed-loop control via quantity control valve 4) Vacant 020 Rail pressure control 1) Engine speed At idle: 610 ... 810 rpm 2) Specified rail pressure [bar] 3) Rail pressure actual [bar] 4) Pressure regulating valve activation At idle: 13 ... 37 % - Values for warmed-up engine - Permissible difference between specified and actual value at Idle: maximum +-20 bar 021 Rail quantity control 1) Engine speed At idle: 610 ... 810 rpm 2) Specified rail pressure Check values with measured value block 020 3) Rail pressure actual Check values with measured value block 020 4) Quantity adjuster valve activation At idle: 33 ... 62 % - Values for warmed-up engine 024 Pre-injection 3 1) Engine speed [rpm] 2) Pre-injection 3 start of activation [°CA] 3) Pre-injection 3 duration of activation [ms] 4) Rail pressure actual Check values with measured value block 020 025 Pre-injection 2 1) Engine speed [rpm] 2) Pre-injection 2 start of activation [°CA] 3) Pre-injection 2 duration of activation [ms] 4) Rail pressure actual Check values with measured value block 020 026 Pre-injection 1 1) Engine speed [rpm] 2) Pre-injection 1 start of activation [°CA] 3) Pre-injection 1 duration of activation [ms] 4) Rail pressure actual Check values with measured value block 020 028 Post-injection 2 1) Engine speed [rpm] 2) Post-injection 2 start of activation [°CA] 3) Post-injection 2 duration of activation [ms] 4) Rail pressure actual Check values with measured value block 020 029 Post-injection 1 1) Engine speed [rpm] 2) Post-injection 1 start of activation [°CA] 3) Post-injection 1 duration of activation [ms] 4) Rail pressure actual Check values with measured value block 020 030 Accelerator pedal position 1) Accelerator pedal sender 1 [V] 2) Accelerator pedal sender 2 [V] 3) Accelerator pedal switch settings X X X X X X X 1 Status AC compressor ON X X X X 1 X X X Idling speed switch ON X X X 1 X X X X Kickdown switch ON X 1 X X X X X X Idling speed increased 4) Accelerator pedal position [%] 032 Camshaft edges 1) Engine speed [rpm] 2) Start synchronisation 001 No synchronisation between engine control unit and engine 005 Too many resynchronisation cyclesTorsion between crankshaft and camshaft too large 020 Position for synchronisation set by run-out detector 033 Synchronisation present, but still being checked 036 Synchronisation present, but still being checked (slave engine control unit only) 038 No valid camshaft signal, run camshaft emergency mode to synchronise 048 Synchronisation complete--> Starting OK 060 No valid crankshaft signal, crankshaft emergency running mode 3) Camshaft edge 1 [°CA] 4) Camshaft edge 2 [°CA] 033 Temperature protection Only 3.0 L TDI CR 1) Engine speed At idle: 610 ... 810 rpm 2) Exhaust gas temperature before turbocharger At idle: 100 ... 310 °C (with radiator fluid > 75 °C) At full throttle: 540 ... 830 °C 3) Exhaust gas temperature governing factor At idle: 99 ... 101 % or 0.99 ... 1,01 4) Overall governing factor At idle: 99 ... 101 % or 0.99 ... 1,01 [b]034 Charge pressure control[/b] 1) Engine speed At idle: 610 ... 810 rpm 2) Charge pressure adjuster activation [%] 3) Charge pressure adjuster feedback [%] 4) Charge pressure adjuster output stage [%] Permissible difference between activation and feedback at Idle: maximum +/- 2 % 036 Intake manifold flap bank 1 1) Engine speed At idle: 610 ... 810 rpm 2) Intake manifold flaps activation [%] 3) Intake manifold flaps feedback [%] 4) Intake manifold flaps output stage [%] Permissible difference between activation and feedback at Idle: maximum +/- 2 % 037 Intake manifold flap bank 2 1) Engine speed At idle: 610 ... 810 rpm 2) Intake manifold flaps 2 activation [%] 3) Intake manifold flaps 2 feedback [%] 4) Intake manifold flaps 2 output stage [%] Permissible difference between activation and feedback at Idle: maximum +/- 2 % 038 EGR valve 1) Engine speed [rpm] 2) EGR valve activation [%] 3) EGR valve feedback [%] 4) EGR valve output stage [%] 040 Throttle valve 1) Engine speed [rpm] 2) Throttle valve activation [%] 3) Throttle valve feedback [%] 4) Throttle valve output stage [%] 041 Lambda probe 1) Lambda probe calibration value internal resistance [Ohm] 2) Oxygen signal offset [V] 3) Oxygen concentration [%] 4) Oxygen signal calibration status 0 inactive 1 active 042 Lambda probe 1) Air mass throughput [-] 2) Lambda probe heater activation [%] 3) Lambda probe temperature signal [V] 4) Lambda signal [-] 043 Lambda probe 1) Air mass throughput [-] 2) Ambient temperature [°C] 3) Lambda probe pressure [mbar] 4) Lambda probe oxygen concentration [mV] 044 Lambda probe 1) Engine speed [rpm] 2) Lambda probe electronics X X X X X X X 1 Full throttle regulator on/off X X X X X X 1 X Full throttle X X X X X 1 X X Control deviation negative, i.e. mixture too rich X X X X 1 X X X System fault X X X 1 X X X X Oxygen signal invalid or no correction by lambda probe adaption X X 1 X X X X X Engine starting X 1 X X X X X X Torque limitation or quantity limitation active 1 X X X X X X X Regeneration exhaust gas treatment 3) Lambda probe plausibility check 001 Current oxygen concentration implausibly high 002 Current oxygen concentration implausibly low 004 Oxygen concentration stationary 008 Plausibility checking enabled 016 Oxygen concentration zero 032 In last time interval no rich operation 4) Lambda probe diagnosis 004 Dynamics of signal too low 008 Cable open circuit 016 Oxygen signal in overrun implausibly low 032 Oxygen signal in overrun implausibly high 064 Oxygen signal at part throttle implausibly low 128 Oxygen signal at part throttle implausibly high 256 Oxygen signal at full throttle implausibly low 512 Oxygen signal at full throttle implausibly high 045 Fan activation 1) Coolant temperature [°C] 2) Air conditioner fan activation [%] 3) Radiator fan 1 activation [%] 4) Radiator fan 2 activation [%] 046 AC compressor 1) Ambient temperature [°C] 2) Temperature at air conditioner heat exchanger output [°C] 3) AC compressor shut-off status 1 X X X X X X X 1 Vehicle starting off X X X X X X 1 X Shut-off due to starting off state X X X X X 1 X X Vehicle acceleration status X X X X 1 X X X Shut-off due to acceleration X X X 1 X X X X Shut-off due to starting X X 1 X X X X X System fault detected X 1 X X X X X X Shut-off due to system fault 1 X X X X X X X Shut-off due to inadequate idling speed 4) AC compressor shut-off status 2 0 Compressor not switched off by control unit 1 Compressor switched off by control unit 051 Speed recording 1) Engine speed [rpm] 2) Camshaft speed [rpm] 3) Start synchronisation 001 No synchronisation between engine control unit and engine 005 Too many resynchronisation cycles Torsion between crankshaft and camshaft too large 020 Position for synchronisation set by run-out detector 033 Synchronisation present, but still being checked 036 Synchronisation present, but still being checked (slave engine control unit only) 038 No valid camshaft signal, run camshaft emergency mode to synchronise 048 Synchronisation complete --> Starting OK 060 No valid crankshaft signal,crankshaft emergency running mode 4) Vacant 057 Engine mounting 1) Engine speed [rpm] 2) Vehicle speed [km/h] 3) Engine mounting valve, right, activation [%] 4) Engine mounting valve, left, activation [%] 059 Ancillaries 1) Engine speed [rpm] 2) Actual engine torque [Nm] 3) Engine torque loss [Nm] 4) Ancillaries torque [Nm] 060 Ancillaries 1) Engine torque loss [Nm] 2) Clutch torque min [Nm] 3) AC compressor torque [Nm] 4) Alternator output [W] 070 Zero quantity calibration ZQC 1) ZQC learning cycle counter 1st calibration pressure [-] 2) ZQC learning cycle counter 2nd calibration pressure [-] 3) ZQC learning cycle counter 3rd calibration pressure [-] 4) Vacant 072 Zero quantity calibration ZQC 1) ZQC cyl. 1 Activation time 1st calibration pressure [ms] 2) ZQC cyl. 1 Activation time 2nd calibration pressure [ms] 3) ZQC cyl. 1 Activation time 3rd calibration pressure [ms] 4) Vacant 073 Zero quantity calibration ZQC 1) ZQC cyl. 2 Activation time 1st calibration pressure [ms] 2) ZQC cyl. 2 Activation time 2nd calibration pressure [ms] 3) ZQC cyl. 2 Activation time 3rd calibration pressure [ms] 4) Vacant 074 Zero quantity calibration ZQC 1) ZQC cyl. 3 Activation time 1st calibration pressure [ms] 2) ZQC cyl. 3 Activation time 2nd calibration pressure [ms] 3) ZQC cyl. 3 Activation time 3rd calibration pressure [ms] 4) Vacant 075 Zero quantity calibration ZQC 1) ZQC cyl. 4 Activation time 1st calibration pressure [ms] 2) ZQC cyl. 4 Activation time 2nd calibration pressure [ms] 3) ZQC cyl. 4 Activation time 3rd calibration pressure [ms] 4) Vacant 076 Zero quantity calibration ZQC 1) ZQC cyl. 5 Activation time 1st calibration pressure [ms] 2) ZQC cyl. 5 Activation time 2nd calibration pressure [ms] 3) ZQC cyl. 5 Activation time 3rd calibration pressure [ms] 4) Vacant 077 Zero quantity calibration ZQC 1) ZQC cyl. 6 Activation time 1st calibration pressure [ms] 2) ZQC cyl. 6 Activation time 2nd calibration pressure [ms] 3) ZQC cyl. 6 Activation time 3rd calibration pressure [ms] 4) Vacant 089 Readiness code 1) EOBD data A X 0 0 0 0 0 0 0 No fault messages stored in engine control unit 0 X X X X X X X Emissions warning lamp (MIL) OFF 1 X X X X X X X Emissions warning lamp (MIL) ON 2) EOBD data B - X X X - X X 1 Misfire monitoring activated - X X X - X 1 X Fuel system monitoring activated - X X X - 1 X X Complete system monitoring activated - X X X - 1 X X Misfire detection monitoring activated - X 0 X - X X X EOBD test fuel system completed with OK - 0 X X - X X X EOBD test overall system completed with OK 3) EOBD data C X X X X X X X 1 Catalytic converter monitoring activated X X X X X X 1 X Catalytic converter hot monitoring activated X X X X X 1 X X Evaporation system monitoring activated X X X X 1 X X X Secondary air system monitoring activated X X X 1 X X X X Air conditioner coolant monitoring activated X X 1 X X X X X Lambda probe monitoring activated X 1 X X X X X X Lambda probe heating monitoring activated 1 X X X X X X X EGR monitoring activated 4) EOBD data D X - - - - - - 0 EOBD test EGR completed with OK 0 - - - - - - X EOBD test EGR completed with OK 095 Starter control 1) Start request terminal 50 X X 1 Start request from driver X 1 X Holding circuit to bridge resets active 1 X X Read-back activation status of starter 2) Interlock or P/N signal Interlock: Signal from selector lever switch Only vehicles with automatic gearbox P/N: Signal from clutch pedal switch for engine start Only vehicles with manual gearbox X X X X X X X 1 Clutch closed X X X 1 X X X X Interlock or P/N signal 3) Starter control status 1 X X X X X X X 1 Start command X X X X X X 1 X Engine does not turn over X X X X X 1 X X Starter motor does not turn over X X X X 1 X X X Power enable X X X 1 X X X X Restart enable X X 1 X X X X X Start command from start/stop coordinator X 1 X X X X X X Engine speed permitted, engage starter 1 X X X X X X X Start mode announcement 4) Starter control status 2 X X X X X X X 1 Start delay active 096 Starter control 1) Start request terminal 50 X X 1 Start request from driver X 1 X Holding circuit to bridge resets active 1 X X Read-back activation status of starter 2) Starter control shut-off conditions 1 X X X X X X X 1 New fault in starter control X X X X X X 1 X Start by term. 15 off X X X X X 1 X X Fast start (direct start) 3) Starter control shut-off conditions 2 X X X X X X X 1 Start rejection speed reached X X X X X X 1 X Engine speed reached and term.50 off X X X X X 1 X X Maximum operating time exceeded X X X X 1 X X X Term.50 off after number of time false starts X X X 1 X X X X Abort panic start X X 1 X X X X X Power detected X 1 X X X X X X Vehicle speed exceeded 1 X X X X X X X Abort semi-automatic start 4)Vehicle voltage [V] 098 EGR cooler coolant pump 1) Coolant temperature [°C] 2) Coolant temperature at radiator outlet [°C] 3) EGR cooler coolant pump, activation [%] 4) EGR temperature [°C] 099 Exhaust gas temperature 1) Engine speed [rpm] 2) Exhaust gas temperature before turbocharger [°C] 3) Exhaust gas temperature before particulate filter [°C] 4) Exhaust gas temperature before particulate filter [°C] Only on vehicles with particulate filter The temperature sender is not fitted on the Q7. The readout is calculated. 100 Service regeneration Only on vehicles with particulate filter Note: Starting service regeneration is possible via Guided Fault Finding if the <service regeneration> test procedure was entered in the test plan. 1) Engine speed In service regeneration: approx. 1500 rpm 2) Surface temperature of filter [°C] 3) Service regeneration current regeneration time 0 ... 255 or 0 to max. 1200 s Total duration: 10 to 40 minutes, depending on loading state 4) Service regeneration abort detected 0 = Not aborted 1 = Aborted 101 Service regeneration Only on vehicles with particulate filter Note: With this measured value block fault causes can be located if the service regeneration was aborted by the engine control unit 1) Service regeneration enable conditions 1 Before start of service regeneration: 0 0 0 0 0 0 0 0 OK, because no service regeneration active After start of service regeneration: 1 1 1 1 1 1 1 1 All enable conditions 1 OK X X X X X X X 1 Minimum waiting time before start of service regeneration with engine running observed X X X X X X 1 X Coolant temperature OK X X X X X 1 X X Oil temperature OK X X X X 1 X X X Ambient air pressure OK X X X 1 X X X X Fuel temperature OK X X 1 X X X X X Battery voltage OK X 1 X X X X X X No clutch pressed 1 X X X X X X X No gear engaged 2) Service regeneration enable conditions 2 Before start of service regeneration: 0 0 0 0 0 0 0 0 OK, because no service regeneration active After start of service regeneration: 1 1 1 1 1 1 1 1 All enable conditions 2 OK X X X X X X X 1 Road speed = 0 X X X X X X 1 X Engine speed OK X X X X X 1 X X Injection quantity OK X X X X 1 X X X Accelerator pedal not pressed X X X 1 X X X X Particulate filter temperature bank 1 OK X X 1 X X X X X Particulate filter temperature bank 2 OK X 1 X X X X X X Pre-catalyst temperature bank 1 OK 1 X X X X X X X Pre-catalyst temperature bank 2 OK 3) Service regeneration enable conditions 3 Before start of service regeneration: 0 0 0 0 0 0 0 0 OK, because no service regeneration active After start of service regeneration: 1 1 1 1 1 1 1 1 All enable conditions 3 OK X X X X X X X 1 Soot mass in particulate filter in permissible Range X X X X X X 1 X No faults in particulate filter functions X X X X X 1 X X No faults in engine functions X X X X 1 X X X Maximum regeneration time not exceeded --> If not OK: Consumers not switched on, ambient temperature too cold X X X 1 X X X X Exhaust gas system heat-up time bank 1 within permissible limits --> If not OK: Consumers not switched on, ambient temperature too cold X X 1 X X X X X Exhaust gas system heat-up time bank 2 within permissible limits --> If not OK: Consumers not switched on, ambient temperature too cold X 1 X X X X X X Maximum temperature before particulate filter bank 1 not exceeded 1 X X X X X X X Maximum temperature before particulate filter bank 2 not exceeded 4) Service regeneration phase X X X X X X X 1 Normal operation X X X X X X 1 X Start X X X X X 1 X X Heat-up 1 X X X X 1 X X X Heat-up 2 X X X 1 X X X X Regeneration X X 1 X X X X X Cool-down X 1 X X X X X X Regeneration successful 1 X X X X X X X Regeneration active 102 Exhaust gas cleaning Only on vehicles with particulate filter 1) Exhaust gas temperature after pre-catalyst A5, B8, Q5, C6 [°C] 2) Vacant 3) Particulate filter differential pressure 0 ... 950 mbar 4) Differential pressure offset particulate filter [mbar] 103 Field regeneration Only on vehicles with particulate filter 1) Field regeneration status 1 X X X X X X X 1 Normal operation X X X X X X 1 X Regeneration mode 2) Field regeneration status 2 X X X 1 X X X X Normal operation X X X 1 X X 1 X Regeneration mode 3) Field regeneration request X X 1 Request by fuel consumption X 1 X Request by operating time 1 X X Request by distance driven 4) Field regeneration block 0 Regeneration disabled 1 Maximum regeneration time elapsed 104 Particulate filter Only on vehicles with particulate filter 1) Oil ash [Ltr] 2) Soot mass calculated [g] 3) Soot mass measured [g] 4) Distance since last regeneration [km] 107 Particulate filter Only on vehicles with particulate filter 1) Loading limit 4 [g] - Value depends on software version and fitted Particulate filter - If the soot mass ("calculated" or "measured", se measured value block 104, zone 2 or 3) exceeds this limit,field and service regeneration is disabled. - If after a test drive (approx. 20 minutes at > 2500 rpm) one of the soot mass values is still higher than load limit 4, the particulate filter must be replaced. 2) Loading limit 3 [g] - Value depends on software version and fitted Particulate filter - If this limit is exceeded, the engine switches to emergency running and the fault memory entry"Particulate filter overloaded" is stored 3) Loading limit 1 [g] - Value depends on software version and fitted Particulate filter - If this limit is exceeded, an attempt is made to start field regeneration (during driving) 4) Exhaust gas volumetric flow particulate filter [m^3/h] Calculated value 110 Adaptive cruise control ACC 1) ACC specification adjustment 001 Specification adjustment free-wheeling 002 Specification adjustment ON 003 Specification adjustment OFF 2) ACC status X X X X X X 0 0 ACC inactive X X X X X X 0 1 ACC active X X X X X X 1 0 ACC passive X X X X X X 1 1 ACC initialisation X X X X X 0 X X No neutral value X X X X X 1 X X Neutral value X X 0 X X X X X Not permitted X X 1 X X X X X Permitted 3) Vehicle speed [km/h] 4) Vacant 125 CAN communication 1) CAN communic. Automatic gearbox 2) CAN communic. ABS/ESP 3) CAN communic. Instrument cluster 4) CAN communic. Airbag 0 = inactive 1 = active 126 CAN communication 1) CAN communic. AC 2) Vacant 3) Vacant 4) CAN communic. ACC 0 = inactive 1 = active 127 CAN communication 1) CAN communic. 4WD 2) CAN communic. Level 3) CAN communic. Drive authorisation 4) CAN communic. Steering column module 0 = inactive 1 = active 128 CAN communication 1) CAN communic. Gateway 2) CAN communic. Battery energy management 3) CAN communic. Steering angle sender 4) CAN communic. Parking brake 0 = inactive 1 = active CAN = Controller Area Network The CAN bus is a network for local interconnection of control units. 202 Oil pressure pump 1) Engine speed [rpm] 2) Control oil pump activation 3) Oil low-pressure switch active 4) Oil high-pressure switch active Basic setting for 2.7 L and 3.0 L TDI CR as at 30.10. 2008 Engine code letters: CANA, CANB, CANC, CAND, CDYA, CDYB, CDYC KNote: To start the "Basic setting" function from Guided Fault Finding: 1) Press mode button 2) Choose "Vehicle self-diagnosis" menu option 3) Self-diagnosis 003 Basic setting: Exhaust gas recirculation 1) Coolant temperature at least 80 °C 2) Switch off ignition briefly, then start engine 3) Start basic setting 4) Follow driver instructions (pedals must be pressed) 5) Wait for the engine speed rise to approx. 1000 rpm KNote: The exhaust gas recirculation is now switched on and off intermittently. Specifications with "EGR not active": Engine speed: approx. 1000 rpm Activation: EGR not active Actual air mass: 380 ... 550 mg/stroke EGR valve feedback: 0 ... 2 % Specifications with "EGR active": Engine speed: approx. 1000 rpm Activation: EGR active Actual air mass: 140 ... 270 mg/stroke EGR valve feedback: 80 ... 100 % 033 Basic setting: Turbocharger 1) Coolant temperature at least 80 °C 2) Switch off ignition briefly, then start engine 3) Start basic setting 4) Follow driver instructions (pedals must be pressed) 5) Wait for the engine speed rise to approx. 1000 rpm KNote: The turbocharger is now activated at intervals at different duty cycles. Specifications at "closed": Engine speed: approx. 1000 rpm Activation: closed Actual charge pressure: 970 ... 1150 mbar Charge pressure adjuster feedback: 98 ... 100 % Specifications at "open": Engine speed: approx. 1000 rpm Activation: open Actual charge pressure: 910 ... 1050 mbar Charge pressure adjuster feedback: 0 ... 2 % Charge pressure difference between "closed/open": 50 ... 135 mbar OK is OK 044 Basic setting: Intake manifold flap bank 1 1) Coolant temperature at least 80 °C 2) Switch off ignition briefly, then start engine 3) Start basic setting 4) Follow driver instructions (pedals must be pressed) 5) Wait for the engine speed rise to approx. 2800 rpm KNote: The bank 1 intake manifold flaps are now alternately opened and closed at intervals. Specifications with "flap open": Engine speed: approx. 2800 rpm Activation: Flap open Actual air mass: [mg/stroke] Intake manifold flap bank 1 feedback: 3 ... 7 % Specifications with "flap closed": Engine speed: approx. 2800 rpm Activation: Flap closed Actual air mass: [mg/stroke] Intake manifold flap bank 1 feedback: 93 ... 97 % Air mass difference between "flap open/closed": min. 20 mg/stroke 055 Basic setting: Intake manifold flap bank 2 1) Coolant temperature at least 80 °C 2) Switch off ignition briefly, then start engine 3) Start basic setting 4) Follow driver instructions (pedals must be pressed) 5) Wait for the engine speed rise to approx. 2800 rpm KNote: The bank 2 intake manifold flaps are now alternately opened and closed at intervals. Specifications with "flap open": Engine speed: approx. 2800 rpm Activation: Flap open Actual air mass: [mg/stroke] Intake manifold flap bank 2 feedback: 3 ... 7 % Specifications with "flap closed": Engine speed: approx. 2800 rpm Activation: Flap closed Actual air mass: [mg/stroke] Intake manifold flap bank 2 feedback: 93 ... 97 % Air mass difference between "flap open/closed": min. 20 mg/stroke 063 Adapting kickdown point Not AUDI A8 Only vehicles with automatic gearbox 1) Switch off ignition briefly, then ignition on 2) Start basic setting 3) Press down accelerator pedal until status ADP OK is displayed 4) Value is only stored in engine control unit after approx. 10 seconds ignition OFF. Specifications: Sender 1 Accelerator position: 12 ... 97 % --- Status: ADP.OK 159 Basic setting: Oil pressure valve 1) Engine oil temperature at least 60 °C 2) Switch off ignition briefly, then start engine 3) Start basic setting 4) Follow driver instructions (pedals must be pressed) KNote: First the low pressure stage is run for 8 seconds. During this time the engine speed is increased to 2300 rpm. Then the system switches to the high pressure stage, whichis likewise active for 8 seconds. Specifications in the low pressure stage: Oil pressure switching valve: 1(low pressure requested) Low-pressure switch: 1(closed) High-pressure switch: 0(open) Specifications in the high pressure stage: Oil pressure switching valve: 0(high pressure requested) Low-pressure switch: 1(closed) High-pressure switch: 1(closed) Edytowane 27 Lutego 2021 przez Banan 1
pelonek1 Opublikowano 27 Lutego 2021 Autor Opublikowano 27 Lutego 2021 Dziękuję @Banan . Masz może jeszcze dopuszczalne (wymagane) wartości w tych grupach. Potrzebuję 72-77 oraz 102, 104 i 107.
Tomnik Opublikowano 27 Lutego 2021 Opublikowano 27 Lutego 2021 (edytowane) 15 minut temu, pelonek1 napisał: 72-77 Nie mogą przekraczać/być mniejsze (a według mnie nie powinny zbliżać się do tych wartości) Blok 1 pomiar -/minus 45ms Blok 2 pomiar -/minus 15ms Blok 3 pomiar -//minus 5ms Właściwy pomiar/test wtryskiwaczy należy przeprowadzić po za autem, na odpowiednim do tego sprzęcie. 15 minut temu, pelonek1 napisał: 102, 104 i 107 W przypadku tych grup, to źle postawione pytanie...nie ma tu określonych wartości granicznych. Jedynym wyjątkiem jest 104.1 ale w tym przypadku po przekroczeniu wart. gran. w pamięci sterownika silnika zapisany zostaje błąd/usterka o zbyt dużym zapełnieniu filtra popiołem. 102.3 - na obrotach biegu jałowego, zaraz po przeprowadzonej regeneracji DPF im mniej tym lepiej (najlepiej zero). Edytowane 27 Lutego 2021 przez Tomnik
pelonek1 Opublikowano 27 Lutego 2021 Autor Opublikowano 27 Lutego 2021 2 minuty temu, Tomnik napisał: Jedynym wyjątkiem jest 104.1 Potrzebuję właśnie dopuszczalną zawartość popiołu w oleju czyli 104.1 dla CDYA.
pelonek1 Opublikowano 27 Lutego 2021 Autor Opublikowano 27 Lutego 2021 (edytowane) 47 minut temu, Tomnik napisał: Blok 1 pomiar -/minus 45ms Blok 2 pomiar -/minus 15ms Blok 3 pomiar -//minus 5ms Nie do końca rozumiem powyższe. Moje na 2 i 6 cylindrze wg VCDSa trochę leją, jednak to tylko VCDs i jak wiadomo najlepiej sprawdzić na stanowisku próbnym, chociaż nie wydaje mi się żeby było źle, auto nie kopci, oleju nie przybywa, raczej nie będę się martwił na zapas. Edytowane 27 Lutego 2021 przez pelonek1
Tomnik Opublikowano 27 Lutego 2021 Opublikowano 27 Lutego 2021 Napisałem, cytuję : "104.1 ale w tym przypadku po przekroczeniu wart. gran. w pamięci sterownika silnika zapisany zostaje błąd/usterka o zbyt dużym zapełnieniu filtra popiołem. " Zostaniesz w ten właśnie sposób poinformowany o jej przekroczeniu. Błąd ten nie jest możliwy do usunięcia. Jedyny sposób na "pozbycie się" błędu (ale nie problemu ! ) jest wyzerowanie * 104.1 (procedura w VCDS, Odis, itp. lepszych narzędzi diagnostycznych). Nie pamiętam tej wartości granicznej - coś około 0.3 l (?) *Procedura ta przeprowadzana jest po wymianie filtra DPF na nowy lub ewentualnie po jego odpowiednim przeczyszczeniu. Nie powinno się zerować zawartości popiołu zostawiając zanieczyszczony filtr popiołem.
pelonek1 Opublikowano 27 Lutego 2021 Autor Opublikowano 27 Lutego 2021 (edytowane) W 13, 14 mam max. -052mg/suw, więc faktycznie nie będę się martwił zbytnio niczym. Edytowane 27 Lutego 2021 przez pelonek1
Tomnik Opublikowano 27 Lutego 2021 Opublikowano 27 Lutego 2021 4 minuty temu, pelonek1 napisał: Nie do końca rozumiem powyższe Ale co jest niezrozumiałe ? Wtryski testujemy po za autem na odpowiedniej aparaturze pomiarowej. Tylko wynik takiego testu jest miarodajny. Proszę zwrócić uwagę, że po tzw. trasie bloki, w których teraz są minusy, pokażą plusy. Jeśli nie, należy monitorować wartości tego właśnie wtrysku.
Tomnik Opublikowano 27 Lutego 2021 Opublikowano 27 Lutego 2021 (edytowane) 18 minut temu, pelonek1 napisał: W 13, 14 mam tak więc faktycznie nie będę się martwił zbytnio. Napisz lepiej w czym tkwi problem. W tej chwili oczekujesz, że ktoś napisze to, o czym Ty wiesz (określi usterkę). Edytowane 27 Lutego 2021 przez Tomnik
pelonek1 Opublikowano 27 Lutego 2021 Autor Opublikowano 27 Lutego 2021 3 minuty temu, Tomnik napisał: Ale co jest niezrozumiałe ? Wtryski testujemy po za autem na odpowiedniej aparaturze pomiarowej. Tylko wynik takiego testu jest miarodajny. Proszę zwrócić uwagę, że po tzw. trasie bloki, w których teraz są minusy, pokażą plusy. Jeśli nie, należy monitorować wartości tego właśnie wtrysku. 1. Już wszystko zrozumiałem. 2. Wiem, że miarodajne testy robimy na stole pomiarowym, pisałem o tym wcześniej. 3. U mnie nigdy nie miałem plusów, nawet po trasie 1300 km przejechanej jednego dnia. 3 minuty temu, Tomnik napisał: Napisz lepiej w czym tkwi problem. W tej chwili oczekujesz, że ktoś napisze to, o czym Ty wiesz (określi usterkę). Nie ma żadnego problemu, jest wszystko w porządku, nie szukam dziury w całym. Nie chciałem zadawać zbędnych pytań toteż założyłem temat myśląc że będzie więcej dopuszczalnych wartości dla tego silnika jak np. 104.1 oraz 72-77 (dużo osób na różnych forach pisze że wtryski leją bądź są zapieczone tylko na podstawie tych korekt, także myślałem że coś tam jednak producent dopuszcza). Tak czy inaczej wszystko z moim autem w porządku, muszę tylko jeszcze dowiedzieć się ile mogę mieć dopuszczalnie w 104.1.
Tomnik Opublikowano 27 Lutego 2021 Opublikowano 27 Lutego 2021 20 minut temu, pelonek1 napisał: muszę tylko jeszcze dowiedzieć się ile mogę mieć dopuszczalnie w 104.1. 0.37 l 1
