[ALL B6] Błędy wykryte scanem w RNSe
Witam,
mam nastepujace bledy przy RNS-e:
Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H72 0650
Coding: 0301715
Shop #: WSC 00000
9 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 80
Freeze Frame:
Mileage: 655350 km
Count: 1003
Clock: 19:56
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 80
Freeze Frame:
Mileage: 655350 km
Count: 1003
Clock: 19:56
00858 - Connection; Radio ZF Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Freeze Frame:
Mileage: 655350 km
Count: 1210
Clock: 16:19
00878 - Connection to Speaker Front Left
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 80
00879 - Connection to Speaker Front Right
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 80
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Date: 2008.03.10
Time: 20:02:42
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Time Indication: 0
Date: 2009.05.27
Time: 17:53:37
Freeze Frame:
Bin. Bits: 11011011
Bin. Bits: 11
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 17
Reset counter: 80
02444 - Disk Drive Load / Eject Malfunction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 82
Z wyjatkiem ostatniego, czy przyczyna tych pierwszych osmiu jest/ moze byc kiepsko osadzona wtyczka, badz brud na stykach? Czy pomoze wyciagniecie RNSa, wypiecie i spsikanie sprayem do stykow? Dodam, ze ani razu nie zauwazylem, zeby byly jakikolwiek klopoty z komunikacja, czy niegrajace glosniki. Acha, jak kupilem auto w marcu, to scan przy kupnie nie pokazal tych bledow.
Prosze o rade
Dzieki
madbar
Wygląda to właśnie tak, jak opisałeś - być może wtyczka trochę luzu miała i zdarzyło się jej kiedyś lekkie wysunięcie, co spowodowało błędy.
kolego poradziłeś sobie z tym błędem u mnie też tkwi ten błąd i nie mam pojęcia jak się z nim uporać może pomożesz
Szczerze mowiac, to te bledy nie martwily mnie jakos szczegolnie, wiec na razie sie nie zajmowalem ich usuwaniem. Kupilem Auto w marcu i wtedy scan VASem w servisie nie wykazywal zadnych bledow w RNSie. Byl tylko blad VINu w 09 Central electronics. Na poczatku Pazdziernika dostalem nowa "zabawke"- VAGa, to machnalem ten scan doslownie na godzine przed wyjazdem na miesiac- auto zostalo w domu, a ja fru... Po powrocie udalo mi sie wykasowac blad w 09 i "nauczyc" central electronics nowego VIN-u. Pozostalymi bledami sie nie przejmowalem. Jak sie przyjrzysz one wszystkie maja niski priorytet: 5 i zdarzyly sie dosc niewiele razy. Wykasuje je pewnie w najblizszym czasie i zobacze, czy sie powtorza. Jesli tak, to pewnie wyciagne RNSa i zobacze jak tam wtyczka. Wiem, ze moj RNS byl dokladany, tzn auto mialo fabrycznie RNS, ale Niemiec, albo Turek, czy Cygan wydlubal i poprzedni wlasciciel zamontowal dokupiony RNS juz tu w kraju, zakladal go sam, wiec byc moze sie nie przylozyl, albo kabelki sa gdzies naciagniete.
Dzieki za odpowiedz, DeeJay_Kill
