Błedy w A4B7 po udezeniu
Witam, wczoraj moja czarnula oberwala w kufer i oto takie bledy pomoze ktos to rozpracowac??
Swieci sie ABS ESP ,Poducha i kontrolka z recznego, usuwac nie prubuje bo czekam na żeczoznawce do wyceny szkody wszystko moge odczytac ale nie mam polaczenia z poduchami,
Friday,16,January,2015,04:49:51:32264
VCDS Version: Release 11.11.3
Data version: 20121206
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Control Module Part Number: 8E0 910 517 H HW: 8E0 614 517 BF
Component and/or Version: ESP8 FRONT H06 0140
Software Coding: 0004401
Work Shop Code: WSC 06335 000 00000
VCID: 2C5D1A698F10169
3 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x0100
Hex Value: 0x0300
Hex Value: 0x0024
Hex Value: 0x0187
Hex Value: 0x0001
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0020
Hex Value: 0x0013
Hex Value: 0x1694
Hex Value: 0x0001
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x0C04
Hex Value: 0x4034
Hex Value: 0x0008
Hex Value: 0x379F
Hex Value: 0x0001
Friday,16,January,2015,04:55:56:32264
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Control Module Part Number: 8E0 907 279 N
Component and/or Version: int. Lastmodul ECE 0907
Software Coding: 10001
VCID: 3D7B272D376A8F1
1 Fault Found:
01501 - Bulb for Blinkers; Rear Left (M6)
30-00 - Open or Short to Plus
Friday,16,January,2015,04:57:58:32264
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Control Module Part Number: 8E0 920 931 P HW: 8E0 920 931 P
Component and/or Version: KOMBI+WFS 4 H14 0110
Software Coding: 0006101
Work Shop Code: WSC 01473 202 104822
VCID: 356B3F0D5F5A571
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
01316 - ABS Control Module
Friday,16,January,2015,04:59:22:32264
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Control Module Part Number: 8E0 959 433 CJ
Component and/or Version: Komfortgerát TBF 4135
Software Coding: 06986
Additional Info: 8E1959801H Tőrsteuer.FS BRM 0606
Additional Info: 8E1959802H Tőrsteuer.BF BRM 0606
VCID: 7BFFE93569FE411
2 Faults Found:
01366 - Opened Due to Crash Signal
36-00 - Open Circuit
00955 - Key 1
35-10 - - - Intermittent
Friday,16,January,2015,04:53:24:32264
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 03G 906 016 JA HW: 028 101 272 3
Component and/or Version: R4 1,9L EDC G000SG 8002
Software Coding: 0000071
VCID: 6BDFD9754A9ED11
5 Faults Found:
005641 - Crash Shut-Down Activated
P1609 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 220802 km
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00101000
Torque: 151.3 Nm
Torque: 0.0 Nm
005686 - Powertrain Data Bus
P1636 - 000 - Missing Message from Airbag Controller
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 8
Mileage: 220802 km
Time Indication: 0
Freeze Frame:
RPM: 819 /min
Speed: 14.0 km/h
Load: 0.0 %
Voltage: 13.38 V
Bin. Bits: 00101000
Torque: 153.7 Nm
Torque: 0.0 Nm
001384 - Cruise Control Switch (E45)
P0568 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.79 V
Bin. Bits: 11001100
Bin. Bits: 11100000
(no units): 0.0
005713 - Powertrain Data Bus
P1651 - 000 - Missing Messages - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.87 V
Bin. Bits: 11001100
Bin. Bits: 11100000
Bin. Bits: 00000000
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 1008 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 11001100
Bin. Bits: 11100000
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Większość błedów jest związana z rozładowanym akumulatorem. 10.8V !
Naładuj porządnie akumulator. Wykasuj błedy sprawdź które wrócą i dopiero zastanowimy się co nie działa...
Poza rozładowanym aku masz też brak komunikacji z wieloma sterownikami - może to być spowodowane również za słabym zasilaniem tych sterowników.
Powiem Ci że rzeczoznawcy nie będzie za bardzo obchodziło co tam są za błedy on przyjedzie od niechcenia pstryknie pare fotek sprawdzi czy nie miałeś przypadkiem malowanego tyłu jesli tak to opier*li Ci ze 50 albo 70 % naleznego odszkodowania i tyle.
Z reszta jeśli nie był lakierowny to też opier*oli i tyle będziesz go widział.
pewnie tak będzie, aku faktycznie padło bo czekałem na milicjantów i na strażaków, chwile zeszło aku nie wytrzymało, poczekam na magika z warty i bede kasował, tylko dziwne jest to ze po odpaleniu rano zaraz gaśnie wcześniej tak nie miałem
Uzupełnij prawidłowo profil bo nie wiadomo jak się do tego odnieść
Co było źródłem problemu? Sam zmagam się z taka przypadłością...
no są błędy po słabym aku ale też z dzwona, jak chyba wyłączenie silnika po wypadku + rejestracja w którymś module
Ale też błąd lewego tylnego czujnika obrotów koła - a to już mógł kabel ucierpieć w wypadku, albo czujnik przy piaście itp
