Problem z tempomatem oraz parę błędów
Witam.
Kupiłem niedawno A4 z 2002 roku i jest taki problem, że tempomat nie działa.
Sprawdzłem czujnik sprzęgła i hamulca. Manetka też sprawna według VAGa
A niestety się nie załącza. Może któryś z błędów to powoduje
VAG-COM Version: Release  311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01     -------------------------------------------------------
   Controller: 038 906 019 FP
   Component: 1,9l R4 EDC G000SG  1467
   Coding: 00002
   Shop #: WSC 63351
   WAUZZZ8E02A180172     AUZ6Z0C0437651
1 Fault Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
            P1586 - 35-10 - - - Intermittent
Readiness: N/A
Address 03     -------------------------------------------------------
   Controller: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04255
   Shop #: WSC 77879
No fault code found.
Address 08     -------------------------------------------------------
   Controller: 8E0 820 043
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
Address 09     -------------------------------------------------------
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   Shop #: WSC 00000
Skipping Address 15-Airbags
Address 16     -------------------------------------------------------
   Controller: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 00042
   Shop #: WSC 00000
Address 17     -------------------------------------------------------
   Controller: 8E0 920 900 M
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 00000
   Shop #: WSC 00006
Address 37     -------------------------------------------------------
   Controller: 4B0 919 887 E
   Component: BNS 4.2 H05    BNO 0008
Address 46     -------------------------------------------------------
   Controller: 8E0 959 433 AD
   Component: Komfortgerát T85    0315
   Coding: 06976
   Shop #: WSC 63351
3 Faults Found:
01562 - Right Rear Door
            59-10 - Can't Unlock - Intermittent
            61-10 - Won't De-Safe - Intermittent
01560 - Passenger Door
            61-00 - Won't De-Safe
Address 56     -------------------------------------------------------
   Controller: 8E0 035 152
   Component: chorus II   GRO    0007
   Coding: 00030
   Shop #: WSC 78174
2 Faults Found:
01303 - Telephone Transceiver (R36)
            49-00 - No Communications
00852 - Loudspeaker(s): Front
            36-10 - Open Circuit - Intermittent
Address 76     -------------------------------------------------------
   Controller: 8Z0 919 283 A
   Component: Parkingsyst. A4 RDW D07
   Coding: 00114
   Shop #: WSC 63351
2 Faults Found:
01546 - Sensor for Parking Aid: Rear Mid-Left (G204)
            31-00 - Open or Short to Ground
01548 - Sensor for Parking Aid: Rear Right (G206)
            30-00 - Open or Short to B+
End   -------------------------------------------------------
Jest tego trochę. Skasuj i sprawdź co wróci? Odnośnie tempomatu to może moduł nie bangla lub taśma ??
Te błędy co widaćto wracają. Już je kasowałem.
Zamki muszę przejrzeć. Czujniki w zderzaku także na dodatek wiązkę do poduszek pod silnikiem.
To niestety nie wiem co oznacza i jak zlikwidować
Gdzie szukaćtego głośnika?
Jeżeli chodzi o tempomat to w Vag gdzie jest Engine blok 06 chyba
Pokazuje, że czujniki sprzęgła i hamulca działają, tempomat też załącza i wyłącza.
Nie pokazuje tylko aktualnej prędkośći.
Sprawdzałem jeszcze gdzieś manetke i wyświetlało się co dany przycisk lub ruch nią robi. Na wszystko reagowała.
Jakby moduł nie działał lub taśma to jakie objawy mogłyby jeszcze być?
Sproboj aktywowac jeszcze raz tempomat Vagiem
Sprawdz kodowanie :) masz telefon ?
Coding: 00030
Shop #: WSC 78174
2 Faults Found:
Telefonu nie mam. Ale jest navi która też nie działa i też wywala błęda. Nie mam go w tej chwili na dniach zrzuce go.
Jak zrobić poprawnie kodowanie w tym radiu ktoś poprowadzi?
Co do tempomatu to sprawdzone manetka, czujniki sprzęgła i hamulca, czujniki prędkości mam juz 3.
Jak wcześniej pisałem w sterowniku silnika nie pokazuje mi prędkości mimo iż czujniki prędkości sprawne.
Juz nie mam pojęcia za co się wziąść aby to działało.
Kontrolka nawet nie chce mrygnąć.
Robiłem test zegarów to tylko brzęczyk od świateł nie działał poza tym wszystko ok.
Ma ktoś jeszcze jakieś pomysły?
Co prawda nie jestem wielkim znawca ale skoro wszystko ci dziala spod VAGA, widze jest zaprogramowane ok to ja bym sie zajal raczej tym pierwszym bledem w 01 silnik:
1 Fault Found:
Readiness: N/A
Byc moze poogogluj i znajdziesz przyczyne. Tasma chyba powinna byc ok bo wydaje mi sie ze by ABS lub ESP blad wywalilo.
A ja przy okazji podepne sie pod temat moze ktos mi pomoze please :-) Chodzi o a4 b6 1.9 awx avant manual . Zostal wymieniony modul kierownicy i dolozona manetka tempomatu. Wszystko zaadoptowane i zaprogramowane, tempomat dziala, przyspiesza i zwalnia. Niestety pozostal ABS I ESP na tym niestety leze. Oczywiscie mam starego skana robionego wczesniej ale niestety nie wchodzi mi login do ABS 09555 (chyba ze ma byc jakis inny do tego auta ?) i dlatego nie moge wbic mojego stargeo kodu 04255 (heble 1LB) . Skoro Abs nie wchodzi to z tego co wiem G85 tez nie pojdzie bo to trzeba robic po kolei. Czy zdazylo sie komus ze byl inny login ABS niz ten ktory powinien byc wedlug ross-techa czyli jak np u mnie w 3-ej pozycji loginu (mam 1LB z ksiazki serwisowej) ma byc 5 moze byc inny ? Nie wiem jak to ugyzc zastanawiam sie jeszcze czy ten modul kierownicy nie jest uszkodzony... Wszelkie sugestie mile widziane. Z gory dziekuje i pozdrawiam.
wrclaguna radio przekodowałem i na szczęście już nic nie wyrzuca.
grzegorzbanbury ten błąd co mówisz to poduszka pod silnikiem albo już koniec jej albo została wymieniona na zwykłą.
Wracając do tempomatu wyskakuje mi taki błąd
16885 -  Vehicle Speed Sensor: Implausible Signal
            P0501 - 35-00 -
Czujnik sprzęgła i hamulca sprawne. W vagu.
3 czujniki prędkości podkładane wszystkie sprawne. Fizycznie sprawdzane na innym aucie.
Wiązka czujnik licznik sprawdzana masa i drugi przewód idzie do licznika zielona kostka pin 5
Manetka sprawdzona w vagu.
Kodowanie sprawdzone.
W blokach pomiarowych silnika tam gdzie sprawdza się tempomat w pierwszym polu jest prędkość samochodu cały czas pokazuje 0 podczas jazdy.
Radio fabryczne z dołożoną zmieniarką i chyba navi.
Co jeszcze można sprawdzić aby go uruchomić?
Czy ktoś posiada schemat do tempomatu?
Edytowane przez Kilker
Juz rozwiazalem ptoblem zmienilem kabel z hex na moj stary obd2 kkl i poszlo do strzalu na starym vagcomie 311. Po zakodowaniu modulu abs byla jeszcze jazda testowa i wszystkie swiatla abs i esp pogasly. :-) Do tej pory w moim b7 i b5 robilem to wszystko vcds-em na kablu hex i nie bylo problemow a tu taka jazda.
Wysłane z mojego SM-G900F przy użyciu Tapatalka
            P0501 - 35-00 -
3 czujniki podkładane sprawne.
Manetka sprawdzona.
Co rozumiesz przez 3 czujniki podkladane sprawne ? Tzn hamulca, sprzegla i ?.... Sprawdzales je vagiem czy po prostu wkladales do innego auta ?
Poprawiłem posta.
Czujniki prędkości 3 razy podkładałem. Mam nowy i używany. Okazuje się, że wszystkie sprawne bo miałem możliwość podłożenia do drugiego auta.
A czujniki hamulca i sprzęgła sprawdzone na początku.
Temat nareszcie do zamknięcia.
Przyczyną nie działającego tempomatu był licznik.
Moje auto jest z 2002 r. a zegary jakie był u mnie to 8E0 920 900M.
Po założeniu z końcówką 900G i dopisaniu do auta tempomat działa prawidłowo.
Dodatkowo klima potrafiła wyłączać się podczas jazdy a po zmianie już jest ok.
Bloki pomiarowe pokazują prędkość.
Ogólnie to po tej operacji chyba doszło kilka koni :decayed:
