[B5 1Z] Prośba o ocenę logów (zaczął dymić na czarno)
Od jakiegoś czasu stracił troszkę na mocy i powolutku zaczynał dymić na czarno :( teraz to już jak mu przycisnę to zostawia chmurę taka ze z tylu nic nie widać :(((
(moge dodac ze koncowki wtryskow byly wymieniane na nowe jakies 5miesiace temu na bosch 0216)a dymic i na mocy stracil jakies 1-2 miechy temu
Errors:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 028 906 021 F
Component and/or Version: 1,9l R4 EDC SG D3I
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found:
01117 - Generator Terminal DF Load Signal
27-10 - Implausible Signal - Intermittent
01237 - Fuel Shut-Off Valve (N109)
31-10 - Open or Short to Ground - Intermittent
Logi:
BS:
<img src="http://img188.imageshack.us/img188/5366/bs000.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img26.imageshack.us/img26/9826/bs001.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img191.imageshack.us/img191/1889/bs003.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img81.imageshack.us/img81/8959/bs004.jpg" alt="Image Hosted by ImageShack.us" />
Dynamiczne :
<img src="http://img30.imageshack.us/img30/2391/dyn000.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img188.imageshack.us/img188/2539/dyn001.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img196.imageshack.us/img196/6528/dyn003.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img197.imageshack.us/img197/7642/dyn004.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img81.imageshack.us/img81/1333/dyn008.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img19.imageshack.us/img19/5476/dyn010q.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img26.imageshack.us/img26/9972/dyn011.jpg" alt="Image Hosted by ImageShack.us" />
podaj wszystkie statyczne jeszcze
Z tego co zamiesciles:
Sprezarka - zdrowizna
Wymienilbym filtr powietrza i rozwazylbym wyczyszczenie nastawnika. :)
Czekamy na reszte logów. :wink4:
To jeszcze zrobic statyczne od 04 w gore ? [br]Dopisany: 14 Czerwiec 2009, 08:36_________________________________________________Dalsze logi BS :
<img src="http://img8.imageshack.us/img8/5807/bs005.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img504.imageshack.us/img504/6343/bs007.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img504.imageshack.us/img504/5818/bs008.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img199.imageshack.us/img199/4251/bs009.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img191.imageshack.us/img191/2105/bs010.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img41.imageshack.us/img41/6299/bs011.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img20.imageshack.us/img20/8192/bs012.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img7.imageshack.us/img7/7153/bs013.jpg" alt="Image Hosted by ImageShack.us" />
<img src="http://img8.imageshack.us/img8/7757/bs015.jpg" alt="Image Hosted by ImageShack.us" />
Podtrzymuje swoją pierwszą diagnoze... :wink4:
Czyli czemu dymi ???
mialem na mysli 000,001,003,004,007,013,014,018 staytczne ,a nie wszystkie i to nie nawet te ktore potrzebne , dymi ci prawdopodobnie przez duze korekcje dwoch wtryskow juz , masz slabe odczyty z przeplywomierza -wymien filtr , przeczysc przepływke, zrób nowe logi jak radził przemik , i napisz ładnie ci pracuje na wolnych nic nie przerywa , bo moze i nastawink do przeczyszczenia , po wymianie wtryskow nie dymil , bo przydalo by sie nastawy pompy zmienic po wymianie wtryskow
Kurde to tak, wymienie filtr przeczyszcze przeplywke , a co z tymi korekcjami to wina wtryskow czy pompy ?? jesli wtryskow to czy te wtryski ci co mi zmieniali moge wyregulowac jeszcze rac?(cisnienia w nich)
a korekta softu byla po wymianie koncowek ... ?
dosyc duze korekcke jak na 5 miesiecy ... :mysli:
reszta ok ...
reszta ok ...
Po wymianie koncowek byly robione nastawy pompy czyli kot wtrysku dawka i cos tram jeszcze ale nic pozatym i to od neidawna zaczol dymic :((( , czy ci pompiarze cow ymieniali koncowki moge je bnaprawic zeby korekcje byly leprze? cze te korekcje wskazuja na zle wyregulowane cisnienia ?? na wtryskach ?[br]Dopisany: 15 Czerwiec 2009, 08:28_________________________________________________POZATYM to napewno niejes to przez korekcje wtryskow bo niedlugo po wymianie koncowek byly wiekrze i jak widze powoli sie normuja i spadaja
Logi niedlugo po wymianie koncowek
013sq4.jpg[br]Dopisany: 15 Czerwiec 2009, 10:06_________________________________________________No wiec Filtr wymieniony powietrza, zaslepiony egr, :
I auto dostalo lekkiego kopa ;) , juz mniej dymi, i po tej przegazowce jaka zrobilem mu, korekcje spadly na 0,54 0,89 0,34
Autko i Tak nadal poddymia , a wczesniej niedymilo co to moze byc jeszcze?? Czy moze to byc spowodowane jakas neiszczelnoscia? bo albo rura ktura leci od interculera do turbiny na opasce poci mi sie, albo na zlaczu tej gruszki przy turbinie.Poniewaz te dwa elementy sa obok siebie i neiwiem z kturego leci ??
moze zalales jakiegos gownianego paliwa ...
po logach nie widac zeby byla jakas nieszczelnosc ....
Mozliwe bo ostatnio zatankowalem na prube orenzade ;) , czy to moze byc jej wina?
takie probowanie moze Cie drogo kosztowac jak Ci wlozą szpryce do zbiornika...zmien paliwo i zrob logi statyczne...
Mozliwe bo ostatnio zatankowalem na próbę orenzade ;)
OMG,bym Cie nazwal po i mieniu ale zaraz sie obrazisz.
Robisz zamieszanie,ludzie tracą czas i chca ci pomóc a ty
opalu nalałeś? :wallbash: :wallbash: :wallbash:
tak, na próbę i latasz tak juz 2 miesiące? :cool1:
chłopie dokladnie po co marnujesz czas komus jak ty na opale latasz i dziwisz sie ze ci podymia :polew: :polew: :polew:
hehehehehe tak jak mowie opal ostatnio na próbę nalałem a poddymia od dawna , ale czy przez opal jeszcze bardziej może dymić ? stary nalał do afn i ani dymku
chłopaku błagam Cię.. sprawdzaj pisownię.. tego się nie da czytać
