Montaż i kodowanie nawigacji RNS-E w Audi A4 B6/B7 od A do Z
jak masz interfejs i program to tu masz kodowanie
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
    [*]0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
    [*]0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
    [*]0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
    [*]0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
    [*]0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
i tutaj adaptacje
[h=2]Adaptation[/h][h=3]Channel 001: Tire Circumference[/h]The tire circumference is being adapted in "mm".
[h=3]Channel 002: Wheel Pulse[/h]The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
[h=3]Channel 003: Language (Screen)[/h]
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
[h=3]Channel 004: Back-Up Camera[/h]
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
[h=3]Channel 005: Speed Threshold (Video Input)[/h]
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
[h=3]Channel 007: Options[/h][h=3]Channel 008: Volume Characteristic[/h][h=3]Channel 010: Region[/h]
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
[h=3]Channel 011: Language (Speech Recognition)[/h]
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
[h=3]Channel 018: Start Screen[/h]The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
[h=3]Channel 065: Read Test[/h][h=3]Channel 066: Self Test[/h][h=3]Channel 067: CD/DVD Drive[/h]
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
[h=3]Channel 068: Screen Test[/h]Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
[h=3]Channel 069: Display Mechanism[/h]
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
[h=3]Channel 070: Display Brightness[/h]
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
[h=3]Channel 099: Transport Mode[/h]Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
[h=3]Channel 111: Reset[/h]
  • To perform a system reset/restart save 1 as new value.
[h=3]Channel 114: FM Frequency[/h]
  • Range: 875...1080
[h=3]Channel 117: Signal Test (Output)[/h]
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
[h=3]Channel 136: Driver Position[/h]
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
    [*]RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
  • Odpowiedzi 4.5 tys.
czyli zmieniam ostatnią cyfrę na 2 0311152 i mam tv
jeśli masz zainstalowany tuner tv to tak
chcę podłączyć adapter multimedialny z naviserwis czy to kodowanie będzie dobre
jak chcesz tam podłączyć jakis odtwarzacz dvd lub tuner dvbt to adaptera to powinno wszystko działać
tuner dvbt i kamerke cofania
---------- Post dopisany at 11:41 ---------- Poprzedni post napisany at 11:25 ----------
chciałby się jeszcze dowiedziec jak włączyć inormację w navi o fotoradarach , nir mogę znależć ikony speedcontroll .Navi led mapa 8p0919884bk bk ue2
kamerke cofania musisz jeszcze aktywować w adaptacjach konał 004
Pytanie do speców od softu RNS-E... Pacjent to wersja LED. Dostałem sofcik pod VIM od Kobry ale po wypaleniu płytki nie chce to w navi zaskoczyć. Oczywiście kanał 97 adaptacji zwolniony (=1). Po włożeniu płytki do napędu widzi, że to update:
Jednak zaraz po zamknięciu wyświetlacza system woła płytkę navi i nawet jeśli tak zostawię - nic się nie dzieje...
Jakieś podpowiedzi? Może źle wypaliłem?
podeślij mi ten soft mam od innego użytkownika z forum to porównam ze swoim :wink:
nie siedzę w ledach więc za dużo nie pomogę :kwasny:
ten soft dostałeś od kobry na płycie czy ściągnąłeś ? jak nagrywałeś ? może coś się uwaliło podczas ściągania albo nagrywania
Przykro mi ale obiecałem, że to do nikogo więcej nie powędruje :wink:
---------- Post dopisany at 18:28 ---------- Poprzedni post napisany at 18:27 ----------
Soft dostałem od kobry (podesłane mejlem). Wcześniej wysyłałem dane swojej navi (log z navi + setup kanałów ADP i na tej podstawie powstał program dla mojej navi).
to jak mamy pomóc ???
to gruba sprawa a z Kobrą się kontaktowałeś w tej sprawie ?
Wpaść na to co robię nie tak bo soft jest na 99% OK.
A ten soft który Ty masz działa?
---------- Post dopisany at 18:38 ---------- Poprzedni post napisany at 18:38 ----------
Szkoda gadać - od pół roku próbuję się do niego dodzwonić :facepalm:
czyli zacznijmy od początku
jaki masz aktualnie soft ?
200.
jasnowidzem nie jestem napisz do osoby od kogo dostałeś soft skoro to taka tajemnica :decayed:
czyli jak miałeś 200 a ta aktualizacja z VIM ma jak widzę nr 270 więc wgrywanie aktualizacji może się odbyć bez ingerencji vaginy.
i co wkładasz płytkę z VIM i nic się absolutnie nie dzieje ?
Tak jak pokazałem na foto - system navi widzi aktualizację ale zaraz po zamknięciu czytnika mam ekran "Prosze włożyć nośnik z navigacją" i jeśli tak zostawię nawet na godzinę to nic się nie wydarzy (nie aktualizuje się).
---------- Post dopisany at 18:44 ---------- Poprzedni post napisany at 18:44 ----------
To nie tajemnica ale obiecałem... Potrafisz to zrozumieć?
