[B5 AHU] 00542 - Needle lift Sensor (G80)
Błąd ABS zapalił się jak jechałem koło 180km/h, później zgasł :mysli:
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 038 906 018 R
Component: 1,9l R4 EDC 10SG 1632
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
27-00 - Implausible Signal
Readiness: N/A
Address 03: ABS Brakes
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
1 Fault Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-00 - -
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 919 860 E
Component: B5-KOMBIINSTR. VDO D09
Coding: 00040
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0V0224419
No fault code found.
Address 25: Immobilizer
Controller: Bit teA dre ssw
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35: Centr. Locks
Controller: 8LO 862 257 D
Component: ZV-Pumpe, Funk D03
Coding: 12864
Shop #: WSC 65535
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
Address 56: Radio
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00201
Shop #: WSC 06325
End --------------------------------------------------------------------------------------------------
statyczne:
normalne:
Grupy: 000 - http://vaglog.rtnet.pl/dir14_42541.html
Grupy: 001 - http://vaglog.rtnet.pl/dir14_42537.html
Grupy: 003 - http://vaglog.rtnet.pl/dir14_42538.html
Grupy: 004 - http://vaglog.rtnet.pl/dir14_42542.html
Grupy: 007 - http://vaglog.rtnet.pl/dir14_42539.html
Grupy: 013 - http://vaglog.rtnet.pl/dir14_42545.html
Grupy: 014 - http://vaglog.rtnet.pl/dir14_42540.html
Grupy: 018 - http://vaglog.rtnet.pl/dir14_42544.html
Grupy: 023 - http://vaglog.rtnet.pl/dir14_42543.html
Basic Settings:
Grupy: 000 - http://vaglog.rtnet.pl/dir14_42549.html
Grupy: 003 - http://vaglog.rtnet.pl/dir14_42547.html
Grupy: 004 - http://vaglog.rtnet.pl/dir14_42546.html
Grupy: 011 - http://vaglog.rtnet.pl/dir14_42548.html
dynamiczne:
Grupy: 000 - http://vaglog.rtnet.pl/dir14_42530.html
Grupy: 001 - http://vaglog.rtnet.pl/dir14_42532.html
Grupy: 003 - http://vaglog.rtnet.pl/dir14_42531.html
Grupy: 004 - http://vaglog.rtnet.pl/dir14_42535.html
Grupy: 008 - http://vaglog.rtnet.pl/dir14_42536.html
Grupy: 010 - http://vaglog.rtnet.pl/dir14_42533.html
Grupy: 011 - http://vaglog.rtnet.pl/dir14_42534.html
Co ty masz tam za graty wsadzone?? Koksu jest doje......
Czujnik temp paliwa,cos za duzo pokazuje,nie widac w logach braku mocy.Termostat dalej do wymiany
Tzn. źle coś jest? :D Bo tylko chip jest wsadzony, który miał dawać ~~120KM. No właśnie teraz jak robiłem te logi to nie tracił aż tak mocy chociaż było przy 4tys. chwilowe przycięcie. A co tego czujnika paliwa to co z tym zrobić? A ten ABS to może być zabrudzony czujnik?
szkoda auta na takie wynalazki ....
Już i tak z tym nic nie zrobię. Ale wracając do tematu to ten regulator w pompie jest ok? Bo jeśli tak to wychodzi na to, że znowu sypie się wtrysk sterujący... No i co z resztą?[br]Dopisany: 10 Kwiecień 2011, 16:54_________________________________________________up
odepnij impulsator od skrzynki i zobacz czy przestanie szarpać
już dawno ci pisałem o termostacie, ale widzę że nie potrzebnie..
No spróbuję z tym impulsatorem. A co do termostatu to trochę roboty jest żeby wymienić, a nie mam zbytnio miejsca by to zrobić. Wiadomo mogę u mechanika ale za darmo nie robią. Ale dzięki za poinformowanie, że jest do wymiany :)[br]Dopisany: 11 Kwiecień 2011, 12:42_________________________________________________Ok, odłączyłem dzisiaj impulsator no i przerywał i nawet chyba gorzej było bo od 3 do 4 tyś kompletnie nie chciał iść. Czyli w takim razie wtrysk do wymiany?[br]Dopisany: 16 Kwiecień 2011, 19:30_________________________________________________Wypowie się ktoś? :wink4:
jak dawno nie był wymieniany filtr paliwa profilaktycznie go wymień
odepnij kabelek od wtrysku sterującego i zobaczy czy przestanie szarpać podczas jazdy
druga sprawa jedz do dobrego pompiarza niech sprawdzi wszystkie wtryski bo prawdopodobnie leją
Ja wiem czy ten program to taki megakoks.... fakt ze ociera sie o wydumke...
ten program to g...., ale fakt faktem te ahu nie są posłusznę choć tutaj leża podstawy
był przymulony a szarpał?
Właśnie nie szarpał. Tylko to jest tak, że czasem cały prawie dzień przejadę i nie szarpię, a innego dnia ledwo co odpalę i już na 1 i 2 szarpie :confused4:
zrób długiego 2min loga 013
to samo z 001
no i poszukaj dobrego pompiarza niech sprawdzi wtryski.. do roboty :)
A co do tego chipa to i tak nic z tym już nie zrobię :kwasny:
dla chcacego nic trudnego ...
spanky zastanów się, namawiasz do korekty soft'u w aucie z nie sprawnym układem wtryskowym, zamiast przynudzać tym czym umiesz najlepiej porać koledze co ma zrobić by silnik zaczął normalnie jeździć, bo pewnie do niedawna pomimo "jakiegoś tam programu" auto nie szarpało a teraz szarpie
fantom89 na swoją odpowiedzialność możesz zaryzykować jeszcze taki zabieg http://www.a4-klub.pl/smf/index.php?topic=186089.0
to samo z 001
Grupy: 001 - http://vaglog.rtnet.pl/dir14_43582.html
Grupy: 013 - http://vaglog.rtnet.pl/dir14_43583.html
Tak dziś sprawdzałem to nie było błędów :mysli: Tylko teraz nie pamiętam czy kasowałem błąd, chyba że same kasują się.
Chyba spróbuję wykonać ten zabieg czyszczenia.
Same błędy się nie kasują
O takie logi mi chodziło, moja propozycja to wizyta u pompiarza i sprawdzenie i regulacja wtrysków :)
Zrób dynamiczny 001 i 004 od 1000obr do 4200
Grupy: 001 - http://vaglog.rtnet.pl/dir14_44225.html
Grupy: 004 - http://vaglog.rtnet.pl/dir14_44226.html
Od 5 dni kompletnie nic nie przycina, wręcz chodzi jak żyleta :blink: Dlatego też jeśli w logach nic nie jest niepokojącego to nie chciałbym zbytnio wydawać pieniędzy na sprawdzanie wtrysków bo to koszt 150zł :([br]Dopisany: 28 Kwiecień 2011, 19:24_________________________________________________up
jest ok poza temp ktora moglaby byc ciut wieksza
