doradca Opublikowano 8 Sierpnia 2016 Opublikowano 8 Sierpnia 2016 Mam ten sam problem Chciałbym uruchomić ADS bez kabla przez green menu - auto polift z Q7Z znalazłem opis For MMI Cars Only. It's not known how to enable the menu via VCDS yet so instructions are provided for enabling through the hidden menu. If you have not enabled the hidden menu yet go here To get into the hidden menu in the MMI hold down the Car and Menu button for approx 6 seconds and the menu should appear on the screen. If you can't enter the menu after a few attempts re-do the MMI Hidden Menu coding EVEN if the coding is correct. Change it to 0 and save then change it to 1 again. I've had to do this from time to time for no apparent reason. Once the menu comes up scroll to Car and select it by pushing down on the scroll wheel. Then Select cardevcelist Scroll down the list until you see Charisma and select it. Hit the back button until you are at the Car menu screen. Then Select canbusassignment: Scroll down to Charisma and set the bus to [CAN Komfort] 1/9 Return back to the Car main menu and select carmenuoperation: Scroll to Charisma and select it with the scroll wheel. It will be set to 0 you will change it to 1 or 5 then push the scroll wheel to set it. 1 allows access while your not moving 5 allows access at all times. We now need to rest the MMI. So go back to the starting menu and follow the procedure below to reset the MMI. Now reset the MMI. This is done by pushing down the Setup – Scroll Wheel and top right menu buttons at the same time. Once the MMI has reset, click on the car button and go to “Audi drive select.." menu. Provided all the coding was done correctly you should now have the following screen in your MMI.
komoornik Opublikowano 8 Sierpnia 2016 Opublikowano 8 Sierpnia 2016 (edytowane) Nie da się bez kodowania, bo MMI nie jest w stanie grzebać w innych sterownikach co jest wymagane. Edytowane 8 Sierpnia 2016 przez komoornik
doradca Opublikowano 9 Sierpnia 2016 Opublikowano 9 Sierpnia 2016 No niby czytam, ze mozna w polifcie ale nie znalazłem potwierdzenia bo nie widziałem w wątku osoby która by robiła przez zielone menu
TomekOstrzeszów Opublikowano 9 Sierpnia 2016 Opublikowano 9 Sierpnia 2016 NO to jakie jest w końcu kodowanie przez VCDS? i najważniejsze co zmieni,oprócz pracy układu kierowniczego?
komoornik Opublikowano 9 Sierpnia 2016 Opublikowano 9 Sierpnia 2016 ADS w polifcie: http://www.audienthusiasts.com/VagCom_FL_ADS.html
wrclaguna Opublikowano 9 Sierpnia 2016 Opublikowano 9 Sierpnia 2016 Oprócz kodowania w 5F ( w green menu) podstawa to kodowanie w MCE 09 oraz sterownik 44 * elektryczny uklad kierowniczy
rafaell68 Opublikowano 24 Sierpnia 2016 Opublikowano 24 Sierpnia 2016 (edytowane) Jest sens w polifcie (2013) kodować ADS jeśli mam manualną skrzynię i zawieszenie 1BA (standardowe)? Chodzi mi o praktyczne opinie osób, którzy mają taką wersję i dodali sobie ADS w VCDS. Wyczytałem, że skoro mam elektryczny układ kierowniczy to w danych trybach będzie czuć na kierownicy. A poza tym coś w dynamice? Zastanawiam się po prostu czy się bawić w kodowanie. Edytowane 24 Sierpnia 2016 przez rafaell68
wrclaguna Opublikowano 24 Sierpnia 2016 Opublikowano 24 Sierpnia 2016 Oczywiście ze odczujesz przy silniku i wspomaganiu 44
komoornik Opublikowano 24 Sierpnia 2016 Opublikowano 24 Sierpnia 2016 A to kodowanie to jakiś wysiłek? Robić.
iwadrian Opublikowano 2 Września 2016 Opublikowano 2 Września 2016 Mam pytanie, ponieważ nie znalazłem w temacie: Czy jak uruchamiam ADS tylko dla silnik i servotronic (bez przycisków na konsoli) czy w adaptacjach muszę zmienić wartość na "4" we wszystkich kanałach tzn:63,64,65,66, czy tylko we dwóch wybranych?
Hohe Opublikowano 2 Września 2016 Opublikowano 2 Września 2016 Te wartości to tylko domyślne ustawienie dla poszczególnych kluczy.
iwadrian Opublikowano 2 Września 2016 Opublikowano 2 Września 2016 Te wartości to tylko domyślne ustawienie dla poszczególnych kluczy. rozumiem, ale który odpowiada z konkretną funkcję. jak np nie mam regulowanego zawieszenia to nie muszę tego ustawiać.
Hohe Opublikowano 2 Września 2016 Opublikowano 2 Września 2016 To nie ma nic do rzeczy. Jak ustawisz 1 to po odpaleniu auta bedziesz miał komfort, jak 3, to dynamic. Tylko tyle. Kodowanie poszczególnych komponentów to inna sprawa.
iwadrian Opublikowano 2 Września 2016 Opublikowano 2 Września 2016 To nie ma nic do rzeczy. Jak ustawisz 1 to po odpaleniu auta bedziesz miał komfort, jak 3, to dynamic. Tylko tyle. Kodowanie poszczególnych komponentów to inna sprawa. O.K, wszystko działa. Dzięki.
md40 Opublikowano 6 Września 2016 Opublikowano 6 Września 2016 Pomocy, potrzebuję schematu do podłączenia wiązki do przycisku ADS w a4 b8 avant 2008, radio concert. Przycisk na konsoli centralnej
komoornik Opublikowano 6 Września 2016 Opublikowano 6 Września 2016 http://www.audienthusiasts.com/Project_ADS2.html
piotrekb_tt Opublikowano 12 Września 2016 Opublikowano 12 Września 2016 Panowie u mnie po zakodowaniu ADS mam tylko silnik i uklad kierowniczy do regulacji. Niestety nie mam opcji zmiany trybu pracy skrzyni(tiptronic)
Yoghurt Opublikowano 12 Września 2016 Opublikowano 12 Września 2016 a czy przypadkiem zmiana trybu pracy skrzyni nie dotyczy tylko s-tronic'a?
piotrekb_tt Opublikowano 13 Września 2016 Opublikowano 13 Września 2016 Nie wiem wlasnie. Tez tak przypuszczalem ale w opisie z 1 szej strony jest tylko napisane, ze kodujemy w przypadku automata. Nie ma rozroznienia na tiptronic, stronic czy multitronic.
sowiq Opublikowano 13 Września 2016 Opublikowano 13 Września 2016 a czy przypadkiem zmiana trybu pracy skrzyni nie dotyczy tylko s-tronic'a? Nie. Ja mam Multitronic i charakterystyka skrzyni też się zmienia. Co prawda polega to tylko na tym, że w trybie Dynamic skrzynia przełącza się na tryb sportowy, ale działa
