[B6 TDI PD] Problem z odpaleniem - Immo ?
Witam. Mam problem z odpaleniem samochodu. W nocy była duża mgła i duża wilgotność, rano gdy przekreciłem kluczyk w stacyjce ujrzałem choinkę na desce. Przy próbie odpalenia samochód na sekundę sie uruchamia i odrazu gaśnie. Podłączyłem komputer i było bardzo dużo błędów :
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01     -------------------------------------------------------
   Controller: 038 906 019 LF
   Component: 1,9l R4 EDC G000SG  4907
   Coding: 00002
   Shop #: WSC 63351
   WAUZZZ8E04A001499     AUZ6Z0C0138718
5 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
            P1650 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
            P1635 - 35-10 - - - Intermittent
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
            P1699 - 35-00 - -
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 - -
Readiness: N/A
Address 03     -------------------------------------------------------
   Controller: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04155
   Shop #: WSC 12345
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
            49-10 - No Communications - Intermittent
18265 - Load Signal: Error Message from ECU
            P1857 - 35-10 - - - Intermittent
Address 08     -------------------------------------------------------
   Controller: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   Shop #: WSC 00000
2 Faults Found:
01172 - Temperature Sensor: Driver's Heated Seat (G59)
            30-00 - Open or Short to B+
01171 - Temperature Sensor: Passenger Side Heated Seat (G60)
Address 09     -------------------------------------------------------
   Controller: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0606
   Coding: 00001
   Shop #: WSC 63351
1 Fault Found:
01312 - Powertrain Data Bus
            79-10 - Please Check Fault Codes - Intermittent
Skipping Address 15-Airbags
Address 16     -------------------------------------------------------
   Controller: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 00041
   Shop #: WSC 12345
No fault code found.
Address 17     -------------------------------------------------------
   Controller: 8E0 920 900 K
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 00100
   Shop #: WSC 00222
3 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
            27-10 - Implausible Signal - Intermittent
00668 - Supply Voltage Terminal 30
            53-00 - Supply Voltage Too Low
Address 46     -------------------------------------------------------
   Controller: 8E0 959 433 AR
   Component: Komfortgerát T85    1310
   Coding: 00064
   Shop #: WSC 30011
5 Faults Found:
01561 - Left Rear Door
            58-10 - Can't Lock - Intermittent
            60-10 - Won't Safe - Intermittent
01562 - Right Rear Door
01331 - Door Control Module: Driver Side (J386)
            80-00 - Single-Wire Operation
End   -------------------------------------------------------
Objaw przy odpalaniu prawie na pewno związany z tym błędem: 17978 - Engine Start Blocked by Immobilizer
Próbowałeś odpalać po usunięciu błędów i sprawdzić, które z nich wracają?
próbowałem usuwać błędy, niektóre zniknęły a niektóre zostały ale efekt z odpalaniem taki sam. Odłączyłem akumulator na jakiś czas i pomogło, odpalił odrazu i na desce żadnej złej kontrolki. Niestety nie miałem jeszcze jak sprawdzić czy są błędy. Macie jakieś pomysły czym mogło to być spowodowane?
Immobiliser zablokował, przeczyścić wtyczkę z immo w kierownicy.
Ja bym się nad tym błędem raczej skupił...
  • 11 miesięcy temu...
@grappa28   Witam  , przypadkiem znalzlem ten temat tak z ciekawości co bylo przyczyną ze auto nie odpalalo i wywaliło tyle błędów?
Edytowane przez Damian_97
