zertaul Opublikowano 12 Sierpnia Opublikowano 12 Sierpnia (edytowane) Na razie nic nie kodowałem, tylko dodałem moduł przyczepy do CAN Gateway List. -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: F5-AU49 (8W7) Scan: 01 02 03 08 09 13 15 16 17 19 22 29 2B 36 39 3C 42 44 46 52 5F 69 6C 6D 80 81 8B A5 A9 BB BC CF D6 D7 VIN: XXXXXXXXXXXXXX Mileage: 88427km-54945miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 29-Left Light -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 39-Right Light -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 69-Trailer -- Status: Cannot be reached 0100 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 80-Batt. reg. aux. accum. -- Status: OK 0000 81-Gear Shift -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 CF-Lane Chge Asst 2 -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-DDWA) Labels:. 06L-907-115-V1.clb Part No SW: 8W0 906 259 K HW: 06L 907 425 C Component: R4 2.0l TFSI H15 0006 Revision: --H15--- CVN: 54C3C1D6 Coding: 1A6500322366050B34002000000000000000000000000000 Shop #: WSC 06314 790 00001 ASAM Dataset: EV_ECM20TFS0208W0906259K 001009 ROD: EV_ECM20TFS0208W0906259K.rod VCID: 49CF5D39493AFC92187-801C VINID: 9D196AAAA5851DA440106043088661DE56 No fault code found. Readiness: 1110 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb Part No SW: 80A 927 155 BE HW: 0CJ 927 156 Component: 0CJ 20TFSIRdW H04 0003 Revision: --H04--- Serial number: 0000000068 CVN: 86AE417B Coding: 000001 Shop #: WSC 05761 780 00200 ASAM Dataset: EV_TCMDL382021 002027 ROD: EV_TCMDL382021_AU49.rod VCID: 6D87C9A91D1200B254F-8038 MTF pump: Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L Component: V553 MTFP 003 0576 Serial number: 75145041170247000437 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8W0-907-379-V1.clb Part No SW: 8W0 907 379 M HW: 8W0 907 379 D Component: ESP9 Premium H13 0767 Dataset Number: 8W2909504D 0008 CVN: 6C105E67 Coding: 14AA409A2CA60A9C119F4894207F52A2F4A5DA280234508812044A452FA55B Shop #: WSC 06334 790 00001 ASAM Dataset: EV_ESP9BOSCHCMP 002013 ROD: EV_ESP9BOSCHCMP_004_AU49.rod VCID: 4FFB7321B75ED2A2463-801A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (E87) Labels:* Redir Fail! Part No SW: 8W0 820 043 T HW: 8W0 820 043 T Component: Klima Zone 3 H55 0210 Coding: 140900095544400D02000100880000000000000000000000000000000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AirCondiBHTCAU491 001013 ROD: EV_AirCondiBHTCAU491.rod VCID: 44D14C0D6E1821FAEB1-8010 Fresh air blower control module (front): Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A Component: J216 FLuftV H08 0003 Serial number: 00000000000001494518 Humidity sensor: exterior: Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A Component: AQ_Hum_Sensor H02 0007 Serial number: A4D159C800PAG0MUFU02 Rear air conditioning block 1: Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A Component: E265 Kli Fond H40 0080 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:* Redir Fail! Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG Component: BCM1 MLBevo H13 0267 Dataset Number: 8W2909514E 0033 Coding: 07501343E17B00CD0515F70818AD84F9130B3108000000000000000060001A010A4501AB02B709 Shop #: WSC 09780 007 104857 ASAM Dataset: EV_BCM1BOSCHAU736 018006 ROD: EV_BCM1BOSCHAU736_018_AU49.rod VCID: 025D8A15348CEFCA99D-8056 Wiper motor control module: Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB Component: 494 LL 210717 036 0471 Serial number: 00000001707180302144 Coding: 5FC7F7 Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555 Component: G397_RLFSS H06 0002 Serial number: 20708300X81A955555A0 Coding: 02005D Light switch: Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA Component: E1 - LDS H06 0008 Serial number: 20 06 2017 00992473 Automatic dimming interior mirror: Subsystem 4 - Part No SW: 8W0 857 511 F HW: 8W0 857 511 Component: Y7_Innenspieg H09 0002 Serial number: GX1CE105102325610189 Coding: 010000 Interior Light Module: Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135 Component: J528-Dachele H14 0130 Serial number: B00500508 Control head for driving and comfort functions: Subsystem 6 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF Component: SL-B9/Q5NF H17 0010 Serial number: 4919000055203002 Coding: 000000 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail! Part No SW: 8W0 907 561 C HW: 8W0 907 561 Component: LRR4 H10 0340 Dataset Number: 8W2909863L 0003 Coding: D477FFF3DEFFEC0A949B83BE Shop #: WSC 00046 123 12345 ASAM Dataset: EV_ACCBOSCHAU49X 003022 ROD: EV_ACCBOSCHAU49X_003_AU49.rod VCID: 3E253EE500F44B2ABD5-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8W0-959-655.clb Part No SW: 8W0 959 655 F HW: 8W0 959 655 F Component: Airbag10.44 H03 0106 Serial number: 003UP008B0F6 Dataset Number: 8W2909602AC 0010 Coding: AACCF0C00CA00000985400F3D04C00000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AirbaAU10BPAAU736 006015 ROD: EV_AirbaAU10BPAAU736_006.rod VCID: 4CC1642D4648E9BA231-8018 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 442 061 808 17 Component: SideSensor_Df 1E2 0887 Serial number: 3577Y00B3249F6B1E317 Coding: 2D2D2D Crash sensor for side airbag: passenger side: Subsystem 2 - Part No SW: ----------- HW: 442 061 808 17 Component: SideSensor_Pf 1E2 0887 Serial number: 3587Y00B3249F6B1240$ Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 442 0B3 008 17 Component: SideSensor_Dr 1C7 0148 Serial number: 35177009D277783601EE Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 442 0B2 508 17 Component: SideSensor_Pr 1C7 0148 Serial number: 3527700C527830A4F329 Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 442 0C0 207 17 Component: FrontSensor_D 1C5 014A Serial number: 3557500BF26FD7B1017S Coding: 2D2D2D Crash sensor for front airbag: passenger side: Subsystem 6 - Part No SW: ----------- HW: 442 0C0 207 17 Component: FrontSensor_P 1C5 014A Serial number: 3567500BF26FD7B4B01- Coding: 2D2D2D Center pedestrian protection crash sensor: Subsystem 7 - Part No SW: ----------- HW: 442 0C0 207 17 Component: PedP_Sensor_C 1C5 014A Serial number: 2307500C326FD7B2D32K Coding: 2D2D2D Driver's side crash data pedestrian protection 2: Subsystem 8 - Part No SW: ----------- HW: 442 432 108 17 Component: PedPSensor_D2 256 0887 Serial number: I0M9M00C3249F6B362FU Coding: 2D2D2D Passenger's side crash data pedestrian protection 2: Subsystem 9 - Part No SW: ----------- HW: 442 432 108 17 Component: PedPSensor_P2 256 0887 Serial number: I0N9M00C3249F6B3732K Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb Part No SW: 4M0 907 129 MH HW: 4M0 907 129 MH Component: Lenks.Modul H11 0009 ASAM Dataset: EV_SMLSKLOAU736 006008 ROD: EV_SMLSKLOAU736_006.rod VCID: 025D8A15348CEFCA99D-8056 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2 Part No SW: 8W5 920 790 B HW: 8W5 920 790 B Component: FBenRDW H12 0379 Coding: 01A541D6EC9C000807A3FF645000401000000200 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DashBoardAU736 001027 ROD: EV_DashBoardAU736_AU49.rod VCID: 41DF4519710A34D2C07-8014 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:* None Part No SW: 8W7 907 468 E HW: 8W7 907 468 E Component: Gateway H42 0118 Revision: 6C020003 Serial number: 0386C534617916 Dataset Number: 8W2909515C 0038 Coding: 0201000100200640298700000059001278380007100000000175078E10000000 Shop #: WSC 06335 790 00001 GVL: 01D43C1008000200C0DCC8000002C800000C0000004000000000000000000000 ASAM Dataset: EV_CGateCONTIAU491 003092 ROD: EV_CGateCONTIAU491_003_AU49.rod VCID: 4DC76929BD52E0B234F-8018 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H Component: J453 MFL H04 0002 Serial number: 20170911085747 21018 Battery Monitoring Control Module: Subsystem 2 - Part No SW: 8W0 915 181 A HW: 8W0 915 181 A Component: J367-BDMHella H10 9070 Serial number: 4779344904 1 Fault Found: 131655 - No Communication with Towing System Control Module (J345) U1003 00 [00001001] - - [Timeout_Node_0x47_DiagAdress_69_AAG] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 100 Mileage: 88427 km Date: 2025.08.13 Time: 00:28:14 ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:| 0CJ-927-749.clb Part No SW: 8W0 927 755 A HW: 0CJ 927 749 Component: B9_DL3_N_SD6H18 0005 Serial number: 1712821346 Coding: 110C0000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AWDCQUOD31 001048 ROD: EV_AWDCQUOD31.rod VCID: 43D34F116B1626C2D2B-8016 No fault code found. ------------------------------------------------------------------------------- Address 29: Left Light (J1018) Labels: 4M0-907-397.clb Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B Component: LCM_MLBevoH05 0024 Dataset Number: 8W2909519B 0003 ASAM Dataset: EV_LCMLeftHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW48.rod VCID: 77ABEBC16F4EBA62BE3-8022 No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A Component: ELV-MLBevo H05 0032 Serial number: 17000230120003 Coding: 8800000000000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_ELVMarquMQBB 001007 ROD: EV_ELVMarquMQBB_VW37.rod VCID: 323D1AD5C4AC9F4A49D-8066 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:* None Part No SW: 4K0 959 760 HW: 4K0 959 760 Component: MEM-FS 011 0071 Serial number: 00000521430326 Dataset Number: 8W2909856F 0021 Coding: 015813400000B4010003010101010000000000000000000000000000000200 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013 ROD: EV_SCMDriveSideCONTIAU736_AU49.rod VCID: 73B3DFD17B36D64282B-8026 No fault code found. ------------------------------------------------------------------------------- Address 39: Right Light (J1023) Labels: 4M0-907-397.clb Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D Component: LCM_MLBevoH05 0024 Dataset Number: 8W2909520B 0003 ASAM Dataset: EV_LCMRightHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW48.rod VCID: 79AFEDF9595AAC12C87-802C No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels:| 4M0-907-566.clb Part No SW: 4M0 907 566 B HW: 4M0 907 566 Component: MRR1Rear H13 0230 Revision: -------- Dataset Number: 8W0909535B 0017 Coding: 0EC002 Shop #: WSC 06334 790 00001 ASAM Dataset: EV_RearRadarS1BoschAU736 001015 ROD: EV_RearRadarS1BoschAU736.rod VCID: 34311CCD3EB8917A5B1-8060 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:* None Part No SW: 4M0 959 793 H HW: 4M0 959 793 F Component: TSG FS 009 0130 Serial number: 0000359459710 Dataset Number: 8W5909872G 0032 Coding: 001F4B625E000002000114B0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005 ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod VCID: 43D34F116B1626C2D2B-8016 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:* None Part No SW: 8W0 909 144 H HW: 8W0 909 144 B Component: EPS_MLBEVO_ZF H08 0410 Dataset Number: 8W2909852P 0030 Coding: 0D888380808080 Shop #: WSC 06334 790 00001 ASAM Dataset: EV_EPSZFAU49X 003023 ROD: EV_EPSZFAU49X_003.rod VCID: 42DD4A15740C2FCAD9D-8016 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:* None Part No SW: 8W0 907 064 DB HW: 8W0 907 064 DB Component: BCM2 MLBevo 019 0366 Dataset Number: 8W2909501D 0032 Coding: 01340000002000E06329A0000600080233020000904706502F04000000040030001F0001000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_BCM2HellaAU736 013013 ROD: EV_BCM2HellaAU736_013_AU49.rod VCID: 7F5B03E1477E8222F63-802A ID - sensor: Coding: 000000 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:* None Part No SW: 4M0 959 792 H HW: 4M0 959 792 F Component: TSG BFS 009 0130 Serial number: 0000359500790 Dataset Number: 8W5909873G 0032 Coding: 001F4B225F000000000114B0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005 ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod VCID: 42DD4A15740C2FCAD9D-8016 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb Part No SW: 8W5 035 035 C HW: 8W5 035 035 Component: MU-P-LND-EU 035 1329 Serial number: 71887149414218 Dataset Number: 8W2909545AB 0042 Coding: 01940301EB0A000053111101004E02332F000EE401F08100FE Shop #: WSC 00046 123 12345 ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 ROD: EV_MUHig6C3Gen2HBAS_AU49.rod VCID: 372B2BC12FCE7A627E3-8062 Data carrier: Subsystem 1 - Part No SW: V03 959 803 HW: ----------- Component: ECE 2025 --- 0390 Serial number: -------------------- Multimedia display unit 1: Subsystem 2 - Part No SW: 8W2 919 620 HW: 8W2 919 620 Component: DU Top AU49x H41 0070 Serial number: TPO00123092110110390 Multimedia system control head: Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T Component: ControlUnit_H H30 0206 Serial number: APVAK104061800040463 Compact disc data bank: Subsystem 4 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1017 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Cannot be reached ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4M0 907 428 F HW: 4M0 907 428 Component: Areaview 2 H13 0318 Serial number: C854607JG022602 Dataset Number: 80B909460G 0011 Coding: 02940201BE0FA10008004084 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015 ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod VCID: 353721C935C288726CF-8060 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb Part No SW: 8W8 959 107 B HW: 8W8 959 107 Component: HDSG-Modul H13 0163 Revision: -------- Serial number: 31547355600000 Dataset Number: 8W2909541B 0004 Coding: 0610 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DeckLidCONTIAU736 001015 ROD: EV_DeckLidCONTIAU736_VW37.rod VCID: 48C9583D5230059A079-801C No fault code found. ------------------------------------------------------------------------------- Address 80: Batt. reg. aux. accum. (-----) Labels: 8W0-915-101.clb Part No SW: 8W0 915 101 HW: 8W0 915 101 Component: MQ-BMS H19 0091 Serial number: 17000035681001 Coding: 1000000000000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001 ROD: EV_BMS12VLiIonSDIAU49X.rod VCID: 70B9D0DD0A20ED5A7F9-8024 No fault code found. ------------------------------------------------------------------------------- Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb Part No SW: 8W1 713 041 G HW: 8W1 713 041 J Component: GSM-LL H09 0077 Revision: 0L0D5012 Serial number: 17090443958241 ASAM Dataset: EV_GSMWaehlZFAU736 001017 ROD: EV_GSMWaehlZFAU736.rod VCID: 372B2BC12FCE7A627E3-8062 No fault code found. ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb Part No SW: 8W0 907 541 C HW: 8W0 907 541 Component: LRR4 H10 0330 Dataset Number: 8W2909885G 0001 ASAM Dataset: EV_ACC2BOSCHAU49X 003022 ROD: EV_ACC2BOSCHAU49X_003_AU49.rod VCID: 3C2134ED16E8593A931-8068 No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail! Part No SW: 8W6 907 217 A HW: 8W6 907 217 A Component: BVS H16 0050 Dataset Number: 8W2909466C 0019 Coding: 0404090300000401022023A6A50100FCB0F0C0208020 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026 ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod VCID: 40D9401D7A003DDACF9-8014 No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 8W0 907 159 H HW: 4H0 907 159 A Component: SAS-GEN 2 H07 0008 Serial number: 170825201279 ASAM Dataset: EV_SoundActuaGen2AU64X 003010 ROD: EV_SoundActuaGen2AU64X_003_VW37.rod VCID: 46D55605582413EAF55-8012 No fault code found. ------------------------------------------------------------------------------- Address BB: Door Rear Drv (J388) Labels:* None Part No SW: 4M0 959 795 H HW: 4M0 959 795 F Component: TSG HFS 005 0129 Serial number: 0000274584722 Dataset Number: 8W0909896E 0029 Coding: 000F492200000000000010B0 Shop #: WSC 21870 823 28888 ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005 ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod VCID: 45D75109652218F2FCF-8010 No fault code found. ------------------------------------------------------------------------------- Address BC: Door Rear Pass (J389) Labels:* None Part No SW: 4M0 959 795 H HW: 4M0 959 795 F Component: TSG HBFS 005 0130 Serial number: 0000333682083 Dataset Number: 8W0909897G 0031 Coding: 000F492200000000000010B0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005 ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod VCID: 45D75109652218F2FCF-8010 No fault code found. ------------------------------------------------------------------------------- Address CF: Lane Chge Asst 2 (J770) Labels:. 4M0-907-566.clb Part No SW: 4M0 907 590 B HW: 4M0 907 590 Component: MRR1Rear H13 0230 Revision: -------- Coding: 0EC002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_RearRadarS2BoschAU736 001015 ROD: EV_RearRadarS2BoschAU736.rod VCID: 313F15D9C1AAA452307-8064 No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Component: LED1L H09 0008 Dataset Number: 8W2909471A 0008 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LEDModLeftMELCOAU736 001004 ROD: EV_LEDModLeftMELCOAU736_VW37.rod VCID: 176BCB414F0E5A625E3-8042 No fault code found. ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Component: LED1R H09 0008 Dataset Number: 8W2909472A 0008 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LEDModRightMELCOAU736 001004 ROD: EV_LEDModLeftMELCOAU736_VW37.rod VCID: 176BCB414F0E5A625E3-8042 No fault code found. End----(Elapsed Time: 02:21, VBatt start/end: 11.9V/11.9V. VIgn 0.1V)------ -------------------------------1 Fault Found------------------------------- Edytowane 12 Sierpnia przez zertaul
Muskel1 Opublikowano 13 Sierpnia Opublikowano 13 Sierpnia Ewidentnie błąd podłączenia albo uwalony sterownik.
zertaul Opublikowano 13 Sierpnia Opublikowano 13 Sierpnia Czyli sterownik do polifta powinien też działać w przedlifcie?
zertaul Opublikowano 13 Sierpnia Opublikowano 13 Sierpnia Prawdopodobnie moduł uwalony. Jeszcze tylko dla pewności zapytam, czy prawidło go podłączyłem. Zasilanie haka(czarna wtyczka T6e): Pin 2 - masa Piny 1,3,4,5,6 - +12V CAN + zasilanie modułu(czarna wtyczka T10i) Pin 1 - +12V po zapłonie ((połączony z modułem komfortu J393, czarna wtyczka T32C, pin 17) Pin 3 - CAN H komfort (połączony z modułem komfortu J393, niebieska wtyczka T32d, pin 1) Pin 4 - CAN L komfort (połączony z modułem komfortu J393, niebieska wtyczka T32d, pin 2) W ELSA sygnały zasilania modułu i CAN idą do modułu Gateway J533, ale są one chyba zamienne z modułem komfortu J393?
turzol Opublikowano 13 Sierpnia Opublikowano 13 Sierpnia (edytowane) Godzinę temu, zertaul napisał(a): Prawdopodobnie moduł uwalony. Jeszcze tylko dla pewności zapytam, czy prawidło go podłączyłem. Zasilanie haka(czarna wtyczka T6e): Pin 2 - masa Piny 1,3,4,5,6 - +12V CAN + zasilanie modułu(czarna wtyczka T10i) Pin 1 - +12V po zapłonie ((połączony z modułem komfortu J393, czarna wtyczka T32C, pin 17) Pin 3 - CAN H komfort (połączony z modułem komfortu J393, niebieska wtyczka T32d, pin 1) Pin 4 - CAN L komfort (połączony z modułem komfortu J393, niebieska wtyczka T32d, pin 2) W ELSA sygnały zasilania modułu i CAN idą do modułu Gateway J533, ale są one chyba zamienne z modułem komfortu J393? Zasilanie terminal30 - stałe 12V weź ze skrzynki bezpieczników, nr 5,7,8,9 Wtyczka czarna T32C musisz wpiąć się w pin 12 oraz 17 Bez parametryzacji powinno znaleźć moduł na magistrali CAN jeżeli cany i zasilanie są poprawnie wpięte Edytowane 13 Sierpnia przez turzol
zertaul Opublikowano 13 Sierpnia Opublikowano 13 Sierpnia Zasilanie sprawdzałem miernikiem i dochodzi na pewno, masa też. Pin 12 jest też podłączony w T32c. Nie wspominałem o nim, bo nie ma on żadnego znaczenia przy próbie połączenia ze sterownikiem. Chciałem się tylko upewnić, że CAN komfort w w module Komfortu (J393) oraz Gateway (J533) są zamienne.
turzol Opublikowano 13 Sierpnia Opublikowano 13 Sierpnia 5 godzin temu, zertaul napisał(a): Chciałem się tylko upewnić, że CAN komfort w w module Komfortu (J393) oraz Gateway (J533) są zamienne. Tak, te same. Masa na pewno jest?
zertaul Opublikowano 14 Sierpnia Opublikowano 14 Sierpnia 12 godzin temu, turzol napisał(a): Masa na pewno jest? Tak, czarna wtyczka T6e, pin 2. Na karoserię podłączona w dwóch miejscach (oryginalna wiązka). Tylko tam masa przychodzi?
audififi Opublikowano 29 Sierpnia Opublikowano 29 Sierpnia Posiada ktoś prawidłową listę kodowań dla haka elektrycznego do Q5 80a po FL 2023 rok? W wątku są jakieś instrukcje jednak nie do tego samochodu. Mój VCDS niestety nie ma podpowiedzi we wszystkich modułach i nie chce czegoś popsuć używając nieprawidłowej instrukcji bez podpowiedzi. Zatrzymałem się na ABS, bo raz, że nie było podpowiedzi to jeszcze potrzebny był login. Jeszcze jedno pytanko jakim programem najlepiej, najłatwiej zakodować moduł haka? Mam do dyspozycji VCDS, VCP i ODIS.
turzol Opublikowano 29 Sierpnia Opublikowano 29 Sierpnia 8 minut temu, audififi napisał(a): Posiada ktoś prawidłową listę kodowań dla haka elektrycznego do Q5 80a po FL 2023 rok? W wątku są jakieś instrukcje jednak nie do tego samochodu. Mój VCDS niestety nie ma podpowiedzi we wszystkich modułach i nie chce czegoś popsuć używając nieprawidłowej instrukcji bez podpowiedzi. Zatrzymałem się na ABS, bo raz, że nie było podpowiedzi to jeszcze potrzebny był login. Jeszcze jedno pytanko jakim programem najlepiej, najłatwiej zakodować moduł haka? Mam do dyspozycji VCDS, VCP i ODIS. w każdym mlbevo tak samo. Jak masz głowicę VAS to pomogę zdalnie
zertaul Opublikowano 7 godzin temu Opublikowano 7 godzin temu (edytowane) W dniu 13.08.2025 o 00:40, zertaul napisał(a): Na razie nic nie kodowałem, tylko dodałem moduł przyczepy do CAN Gateway List. -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: F5-AU49 (8W7) Scan: 01 02 03 08 09 13 15 16 17 19 22 29 2B 36 39 3C 42 44 46 52 5F 69 6C 6D 80 81 8B A5 A9 BB BC CF D6 D7 VIN: XXXXXXXXXXXXXX Mileage: 88427km-54945miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 29-Left Light -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 39-Right Light -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 69-Trailer -- Status: Cannot be reached 0100 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 80-Batt. reg. aux. accum. -- Status: OK 0000 81-Gear Shift -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 CF-Lane Chge Asst 2 -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-DDWA) Labels:. 06L-907-115-V1.clb Part No SW: 8W0 906 259 K HW: 06L 907 425 C Component: R4 2.0l TFSI H15 0006 Revision: --H15--- CVN: 54C3C1D6 Coding: 1A6500322366050B34002000000000000000000000000000 Shop #: WSC 06314 790 00001 ASAM Dataset: EV_ECM20TFS0208W0906259K 001009 ROD: EV_ECM20TFS0208W0906259K.rod VCID: 49CF5D39493AFC92187-801C VINID: 9D196AAAA5851DA440106043088661DE56 No fault code found. Readiness: 1110 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb Part No SW: 80A 927 155 BE HW: 0CJ 927 156 Component: 0CJ 20TFSIRdW H04 0003 Revision: --H04--- Serial number: 0000000068 CVN: 86AE417B Coding: 000001 Shop #: WSC 05761 780 00200 ASAM Dataset: EV_TCMDL382021 002027 ROD: EV_TCMDL382021_AU49.rod VCID: 6D87C9A91D1200B254F-8038 MTF pump: Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L Component: V553 MTFP 003 0576 Serial number: 75145041170247000437 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8W0-907-379-V1.clb Part No SW: 8W0 907 379 M HW: 8W0 907 379 D Component: ESP9 Premium H13 0767 Dataset Number: 8W2909504D 0008 CVN: 6C105E67 Coding: 14AA409A2CA60A9C119F4894207F52A2F4A5DA280234508812044A452FA55B Shop #: WSC 06334 790 00001 ASAM Dataset: EV_ESP9BOSCHCMP 002013 ROD: EV_ESP9BOSCHCMP_004_AU49.rod VCID: 4FFB7321B75ED2A2463-801A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (E87) Labels:* Redir Fail! Part No SW: 8W0 820 043 T HW: 8W0 820 043 T Component: Klima Zone 3 H55 0210 Coding: 140900095544400D02000100880000000000000000000000000000000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AirCondiBHTCAU491 001013 ROD: EV_AirCondiBHTCAU491.rod VCID: 44D14C0D6E1821FAEB1-8010 Fresh air blower control module (front): Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A Component: J216 FLuftV H08 0003 Serial number: 00000000000001494518 Humidity sensor: exterior: Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A Component: AQ_Hum_Sensor H02 0007 Serial number: A4D159C800PAG0MUFU02 Rear air conditioning block 1: Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A Component: E265 Kli Fond H40 0080 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:* Redir Fail! Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG Component: BCM1 MLBevo H13 0267 Dataset Number: 8W2909514E 0033 Coding: 07501343E17B00CD0515F70818AD84F9130B3108000000000000000060001A010A4501AB02B709 Shop #: WSC 09780 007 104857 ASAM Dataset: EV_BCM1BOSCHAU736 018006 ROD: EV_BCM1BOSCHAU736_018_AU49.rod VCID: 025D8A15348CEFCA99D-8056 Wiper motor control module: Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB Component: 494 LL 210717 036 0471 Serial number: 00000001707180302144 Coding: 5FC7F7 Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555 Component: G397_RLFSS H06 0002 Serial number: 20708300X81A955555A0 Coding: 02005D Light switch: Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA Component: E1 - LDS H06 0008 Serial number: 20 06 2017 00992473 Automatic dimming interior mirror: Subsystem 4 - Part No SW: 8W0 857 511 F HW: 8W0 857 511 Component: Y7_Innenspieg H09 0002 Serial number: GX1CE105102325610189 Coding: 010000 Interior Light Module: Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135 Component: J528-Dachele H14 0130 Serial number: B00500508 Control head for driving and comfort functions: Subsystem 6 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF Component: SL-B9/Q5NF H17 0010 Serial number: 4919000055203002 Coding: 000000 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail! Part No SW: 8W0 907 561 C HW: 8W0 907 561 Component: LRR4 H10 0340 Dataset Number: 8W2909863L 0003 Coding: D477FFF3DEFFEC0A949B83BE Shop #: WSC 00046 123 12345 ASAM Dataset: EV_ACCBOSCHAU49X 003022 ROD: EV_ACCBOSCHAU49X_003_AU49.rod VCID: 3E253EE500F44B2ABD5-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8W0-959-655.clb Part No SW: 8W0 959 655 F HW: 8W0 959 655 F Component: Airbag10.44 H03 0106 Serial number: 003UP008B0F6 Dataset Number: 8W2909602AC 0010 Coding: AACCF0C00CA00000985400F3D04C00000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AirbaAU10BPAAU736 006015 ROD: EV_AirbaAU10BPAAU736_006.rod VCID: 4CC1642D4648E9BA231-8018 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 442 061 808 17 Component: SideSensor_Df 1E2 0887 Serial number: 3577Y00B3249F6B1E317 Coding: 2D2D2D Crash sensor for side airbag: passenger side: Subsystem 2 - Part No SW: ----------- HW: 442 061 808 17 Component: SideSensor_Pf 1E2 0887 Serial number: 3587Y00B3249F6B1240$ Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 442 0B3 008 17 Component: SideSensor_Dr 1C7 0148 Serial number: 35177009D277783601EE Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 442 0B2 508 17 Component: SideSensor_Pr 1C7 0148 Serial number: 3527700C527830A4F329 Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 442 0C0 207 17 Component: FrontSensor_D 1C5 014A Serial number: 3557500BF26FD7B1017S Coding: 2D2D2D Crash sensor for front airbag: passenger side: Subsystem 6 - Part No SW: ----------- HW: 442 0C0 207 17 Component: FrontSensor_P 1C5 014A Serial number: 3567500BF26FD7B4B01- Coding: 2D2D2D Center pedestrian protection crash sensor: Subsystem 7 - Part No SW: ----------- HW: 442 0C0 207 17 Component: PedP_Sensor_C 1C5 014A Serial number: 2307500C326FD7B2D32K Coding: 2D2D2D Driver's side crash data pedestrian protection 2: Subsystem 8 - Part No SW: ----------- HW: 442 432 108 17 Component: PedPSensor_D2 256 0887 Serial number: I0M9M00C3249F6B362FU Coding: 2D2D2D Passenger's side crash data pedestrian protection 2: Subsystem 9 - Part No SW: ----------- HW: 442 432 108 17 Component: PedPSensor_P2 256 0887 Serial number: I0N9M00C3249F6B3732K Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb Part No SW: 4M0 907 129 MH HW: 4M0 907 129 MH Component: Lenks.Modul H11 0009 ASAM Dataset: EV_SMLSKLOAU736 006008 ROD: EV_SMLSKLOAU736_006.rod VCID: 025D8A15348CEFCA99D-8056 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2 Part No SW: 8W5 920 790 B HW: 8W5 920 790 B Component: FBenRDW H12 0379 Coding: 01A541D6EC9C000807A3FF645000401000000200 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DashBoardAU736 001027 ROD: EV_DashBoardAU736_AU49.rod VCID: 41DF4519710A34D2C07-8014 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:* None Part No SW: 8W7 907 468 E HW: 8W7 907 468 E Component: Gateway H42 0118 Revision: 6C020003 Serial number: 0386C534617916 Dataset Number: 8W2909515C 0038 Coding: 0201000100200640298700000059001278380007100000000175078E10000000 Shop #: WSC 06335 790 00001 GVL: 01D43C1008000200C0DCC8000002C800000C0000004000000000000000000000 ASAM Dataset: EV_CGateCONTIAU491 003092 ROD: EV_CGateCONTIAU491_003_AU49.rod VCID: 4DC76929BD52E0B234F-8018 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H Component: J453 MFL H04 0002 Serial number: 20170911085747 21018 Battery Monitoring Control Module: Subsystem 2 - Part No SW: 8W0 915 181 A HW: 8W0 915 181 A Component: J367-BDMHella H10 9070 Serial number: 4779344904 1 Fault Found: 131655 - No Communication with Towing System Control Module (J345) U1003 00 [00001001] - - [Timeout_Node_0x47_DiagAdress_69_AAG] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 100 Mileage: 88427 km Date: 2025.08.13 Time: 00:28:14 ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:| 0CJ-927-749.clb Part No SW: 8W0 927 755 A HW: 0CJ 927 749 Component: B9_DL3_N_SD6H18 0005 Serial number: 1712821346 Coding: 110C0000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_AWDCQUOD31 001048 ROD: EV_AWDCQUOD31.rod VCID: 43D34F116B1626C2D2B-8016 No fault code found. ------------------------------------------------------------------------------- Address 29: Left Light (J1018) Labels: 4M0-907-397.clb Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B Component: LCM_MLBevoH05 0024 Dataset Number: 8W2909519B 0003 ASAM Dataset: EV_LCMLeftHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW48.rod VCID: 77ABEBC16F4EBA62BE3-8022 No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A Component: ELV-MLBevo H05 0032 Serial number: 17000230120003 Coding: 8800000000000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_ELVMarquMQBB 001007 ROD: EV_ELVMarquMQBB_VW37.rod VCID: 323D1AD5C4AC9F4A49D-8066 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:* None Part No SW: 4K0 959 760 HW: 4K0 959 760 Component: MEM-FS 011 0071 Serial number: 00000521430326 Dataset Number: 8W2909856F 0021 Coding: 015813400000B4010003010101010000000000000000000000000000000200 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013 ROD: EV_SCMDriveSideCONTIAU736_AU49.rod VCID: 73B3DFD17B36D64282B-8026 No fault code found. ------------------------------------------------------------------------------- Address 39: Right Light (J1023) Labels: 4M0-907-397.clb Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D Component: LCM_MLBevoH05 0024 Dataset Number: 8W2909520B 0003 ASAM Dataset: EV_LCMRightHELLAAU736 001012 ROD: EV_LCMLeftHELLAAU736_VW48.rod VCID: 79AFEDF9595AAC12C87-802C No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels:| 4M0-907-566.clb Part No SW: 4M0 907 566 B HW: 4M0 907 566 Component: MRR1Rear H13 0230 Revision: -------- Dataset Number: 8W0909535B 0017 Coding: 0EC002 Shop #: WSC 06334 790 00001 ASAM Dataset: EV_RearRadarS1BoschAU736 001015 ROD: EV_RearRadarS1BoschAU736.rod VCID: 34311CCD3EB8917A5B1-8060 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:* None Part No SW: 4M0 959 793 H HW: 4M0 959 793 F Component: TSG FS 009 0130 Serial number: 0000359459710 Dataset Number: 8W5909872G 0032 Coding: 001F4B625E000002000114B0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005 ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod VCID: 43D34F116B1626C2D2B-8016 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:* None Part No SW: 8W0 909 144 H HW: 8W0 909 144 B Component: EPS_MLBEVO_ZF H08 0410 Dataset Number: 8W2909852P 0030 Coding: 0D888380808080 Shop #: WSC 06334 790 00001 ASAM Dataset: EV_EPSZFAU49X 003023 ROD: EV_EPSZFAU49X_003.rod VCID: 42DD4A15740C2FCAD9D-8016 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:* None Part No SW: 8W0 907 064 DB HW: 8W0 907 064 DB Component: BCM2 MLBevo 019 0366 Dataset Number: 8W2909501D 0032 Coding: 01340000002000E06329A0000600080233020000904706502F04000000040030001F0001000000 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_BCM2HellaAU736 013013 ROD: EV_BCM2HellaAU736_013_AU49.rod VCID: 7F5B03E1477E8222F63-802A ID - sensor: Coding: 000000 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:* None Part No SW: 4M0 959 792 H HW: 4M0 959 792 F Component: TSG BFS 009 0130 Serial number: 0000359500790 Dataset Number: 8W5909873G 0032 Coding: 001F4B225F000000000114B0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005 ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod VCID: 42DD4A15740C2FCAD9D-8016 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb Part No SW: 8W5 035 035 C HW: 8W5 035 035 Component: MU-P-LND-EU 035 1329 Serial number: 71887149414218 Dataset Number: 8W2909545AB 0042 Coding: 01940301EB0A000053111101004E02332F000EE401F08100FE Shop #: WSC 00046 123 12345 ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 ROD: EV_MUHig6C3Gen2HBAS_AU49.rod VCID: 372B2BC12FCE7A627E3-8062 Data carrier: Subsystem 1 - Part No SW: V03 959 803 HW: ----------- Component: ECE 2025 --- 0390 Serial number: -------------------- Multimedia display unit 1: Subsystem 2 - Part No SW: 8W2 919 620 HW: 8W2 919 620 Component: DU Top AU49x H41 0070 Serial number: TPO00123092110110390 Multimedia system control head: Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T Component: ControlUnit_H H30 0206 Serial number: APVAK104061800040463 Compact disc data bank: Subsystem 4 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1017 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Cannot be reached ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4M0 907 428 F HW: 4M0 907 428 Component: Areaview 2 H13 0318 Serial number: C854607JG022602 Dataset Number: 80B909460G 0011 Coding: 02940201BE0FA10008004084 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015 ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod VCID: 353721C935C288726CF-8060 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb Part No SW: 8W8 959 107 B HW: 8W8 959 107 Component: HDSG-Modul H13 0163 Revision: -------- Serial number: 31547355600000 Dataset Number: 8W2909541B 0004 Coding: 0610 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_DeckLidCONTIAU736 001015 ROD: EV_DeckLidCONTIAU736_VW37.rod VCID: 48C9583D5230059A079-801C No fault code found. ------------------------------------------------------------------------------- Address 80: Batt. reg. aux. accum. (-----) Labels: 8W0-915-101.clb Part No SW: 8W0 915 101 HW: 8W0 915 101 Component: MQ-BMS H19 0091 Serial number: 17000035681001 Coding: 1000000000000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001 ROD: EV_BMS12VLiIonSDIAU49X.rod VCID: 70B9D0DD0A20ED5A7F9-8024 No fault code found. ------------------------------------------------------------------------------- Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb Part No SW: 8W1 713 041 G HW: 8W1 713 041 J Component: GSM-LL H09 0077 Revision: 0L0D5012 Serial number: 17090443958241 ASAM Dataset: EV_GSMWaehlZFAU736 001017 ROD: EV_GSMWaehlZFAU736.rod VCID: 372B2BC12FCE7A627E3-8062 No fault code found. ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb Part No SW: 8W0 907 541 C HW: 8W0 907 541 Component: LRR4 H10 0330 Dataset Number: 8W2909885G 0001 ASAM Dataset: EV_ACC2BOSCHAU49X 003022 ROD: EV_ACC2BOSCHAU49X_003_AU49.rod VCID: 3C2134ED16E8593A931-8068 No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail! Part No SW: 8W6 907 217 A HW: 8W6 907 217 A Component: BVS H16 0050 Dataset Number: 8W2909466C 0019 Coding: 0404090300000401022023A6A50100FCB0F0C0208020 Shop #: WSC 06335 790 00001 ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026 ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod VCID: 40D9401D7A003DDACF9-8014 No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 8W0 907 159 H HW: 4H0 907 159 A Component: SAS-GEN 2 H07 0008 Serial number: 170825201279 ASAM Dataset: EV_SoundActuaGen2AU64X 003010 ROD: EV_SoundActuaGen2AU64X_003_VW37.rod VCID: 46D55605582413EAF55-8012 No fault code found. ------------------------------------------------------------------------------- Address BB: Door Rear Drv (J388) Labels:* None Part No SW: 4M0 959 795 H HW: 4M0 959 795 F Component: TSG HFS 005 0129 Serial number: 0000274584722 Dataset Number: 8W0909896E 0029 Coding: 000F492200000000000010B0 Shop #: WSC 21870 823 28888 ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005 ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod VCID: 45D75109652218F2FCF-8010 No fault code found. ------------------------------------------------------------------------------- Address BC: Door Rear Pass (J389) Labels:* None Part No SW: 4M0 959 795 H HW: 4M0 959 795 F Component: TSG HBFS 005 0130 Serial number: 0000333682083 Dataset Number: 8W0909897G 0031 Coding: 000F492200000000000010B0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005 ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod VCID: 45D75109652218F2FCF-8010 No fault code found. ------------------------------------------------------------------------------- Address CF: Lane Chge Asst 2 (J770) Labels:. 4M0-907-566.clb Part No SW: 4M0 907 590 B HW: 4M0 907 590 Component: MRR1Rear H13 0230 Revision: -------- Coding: 0EC002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_RearRadarS2BoschAU736 001015 ROD: EV_RearRadarS2BoschAU736.rod VCID: 313F15D9C1AAA452307-8064 No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Component: LED1L H09 0008 Dataset Number: 8W2909471A 0008 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LEDModLeftMELCOAU736 001004 ROD: EV_LEDModLeftMELCOAU736_VW37.rod VCID: 176BCB414F0E5A625E3-8042 No fault code found. ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Component: LED1R H09 0008 Dataset Number: 8W2909472A 0008 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LEDModRightMELCOAU736 001004 ROD: EV_LEDModLeftMELCOAU736_VW37.rod VCID: 176BCB414F0E5A625E3-8042 No fault code found. End----(Elapsed Time: 02:21, VBatt start/end: 11.9V/11.9V. VIgn 0.1V)------ -------------------------------1 Fault Found------------------------------- Problem znalziony - uwalony moduł. Pomoże ktoś z kodowaniem modułów? Hak elektryczny. EDIT: Zrobiłem kodowanie zgodnie z opisem: MLBevo - Trailer Assist | VCDS.de Wiki WIKI-ONLINE.VCDS.DE i mam jeszcze problem z kilkoma modułami. Prawdopodobnie brakuje jeszcze jakiegoś kodowania/adaptacji. Wstawiam log po kodowaniu. EDIT2: Problem rozwiązany. Z rozpędu zakodowałem za dużo opcji związanych z przyczepą. W module 17 (Instrument cluster) usunąłem Trailer maneuvering assistant (bajt 12 / bit 5) oraz w module 44 (Steering assist) usunąłem Trailer maneuvering assistant (bajt 1 / bit 5) Po wykodowaniu opcji i uśpieniu sterowników błędy nie pojawiają się już w żadnym module, a hak składa się i rozkłada z przycisku. Dziękuję wszystkim za pomoc. Log-CBAG200-WAUZZZF57JA046132-90958km-56518mi-001.txt Edytowane 52 minuty temu przez zertaul Dodano log po kodowaniu.
