[B6 AVB] Nowa niunia na 3miejskie spotowanie :) + kilka pytań
Witam,
Czas się pochwalić. Autko jest świeże i właśnie walczę z biurokracją.
Narzeczonej i mnie bardzo się podoba nowa niunia, wreszcie będzie czym zajechać pod kościół :>
Czas na konkrety:
0G1 = gearshift lever
0GE = emissions concept EU 3
0JJ = weight category front axle weight range 9
0YH = weight category rear axle weight range 8
1BA = standard suspension/shock absorption
1KD = disc brakes, rear
1LZ = front disc brakes, standard ventilation
1N1 = power steering
1SA = without additional engine guard
2K1 = reinforced bumpers
2PV = leather trimmed sports steering wheel
3FA = without roof insert (standard roof)
3L2 = manual height adjustment for right front seat
3NZ = rear seat bench unsplit, backrest split folding
3Y0 = without roll-up sun screen
4GH = windshield tinted with windshield sunshield
4K4 = radio remote controlled central locking operated from inside and separate trunk release
4KC = side and rear windows tinted
4R4 = power windows with comfort operation andcircuit breaker
4UE = airbag for driver and front seat passenger
4X3 = side airbag front with curtain airbag
5MG = decorative burr walnut inserts
5RU = outer right rear view mirror: convex (large viewing field)
5SL = outer left rear view mirror: non-spherical
6R2 = leather gearshift boot
6XE = outer rear view mirrors: powered, heatedelectrically foldable
7A0 = without CD changer/CD player
7K0 = without tire pressure warning light
7Q0 = without navigation device
7X0 = without park distance control
8GU = alternator 140A
8JH = ellipsoidal headlight for driving on the right
8Q1 = headlight-range adjustment
8Z6 = engine cooling system, type 2
9Q3 = multi-function indicator, without on-board computer and check control
C1W = forged alloy wheels 7J x 15 type 1, offset 39
E0A = no special edition
F0A = no special purpose vehicle, standard equipment
J0R = battery 380 A (80 Ah)
MS7 = 4-cylinder turbo diesel engine 1.9 L/74 kW TDI pump-jet injection system, base engine is T5X/T21/T71
Q1A = standard front seats
T5X = components for, base engine, unit 038.L
U1A = instrument insert with km/h speedometer, clock, tachometer and trip odometer
X4C = national sales program Italy
fotki:
Moja pierwsza modyfikacja:
Tomason TN 4 18'' 235/40
Pytanka:
1. Radio nie gra na tył. Ktoś wie czemu? Może nie ma wyjścia na tył w tym modelu? (Może nie mam tam głośników? Nie miałem czau sprawdzić :embarrassed:) Fader mam ustawiony na środek.
2. Jak to jest z wyposażeniem tego modelu w głośniki. Z tyłu pod półką mam wolne miejsce. Nie było tam nic, czy jest oszabrowany?
3. Ktoś miał problem z niezamykającym się wlewem paliwa - mam na myśli ten bolec co się zamyka przy zamykaniu auta. Ile to może kosztować?
4. Nie składają mi się lusterka. Prawe drgnie i nic, lewe wcale nie rusza/
5. Nie zamykają się drzwi od strony kierowcy z centrala. Tylko kluczyk. Co to może być i ile kosztuje?
Czekam na opinie i wskazówki. W planach mam tylko dołożyć do pieca na jakieś 120-130 kucy.
Do zobaczenia na spocie w 3mieście.
Hehe jak najbardziej zapraszam na spocik bryczka godna oględzin z bliska :th: Pozdrawiam
Co do mocy, spokojnie bedziesz mial 150PS po programie.
Felgi nawet ladne, pasuja do auta, ale kierownica... :shocked:
Moc spokojnie podniesiesz do 140-150PS.
Kiera na fotkach jest złachana, ale jest już obszyta na nowo.
Nad mocą się zastanawiam. Najpierw zrobię rozrząd i hamulce, potem się pomyśli nad przyspieszaniem niuni.
bardzo ładny sprzęcik :th:, ale co z tą kierą czemu taka zmęczona ??
Niunia taka jak moja. Jest piękna.
Po wizycie u Rogala mam 156 KM :th:
Hula jak marzenie i mało pali :th:
Poprostu :kox: nic dodac nic ujac, troche ja dopiescisz i bedzie bajka :]
No po zmianach ....super :th: Pod kościołem to zwariują, :)
Bardzo ładna ,choć środek nie w moim guście.
Witam
Mam to co ty służe informacją . Niunie mam od 2 miesiecy: wymieniałem rozrząd , napinacz paska alternatora , przepływomierz , zawór N75 , bede teraz wymieniał zawór recylkulacji spalin no i wymieniałem wszystkie płyna.
Co do twych pytań radio masz Concert wiec sądze ze powinieneś mieć głośniki, tył i subwoofer gra ze wzmacniacza może ktoś zmieniał sprzet i przy sprzedarzy go zabrał. Warto sprawdzić czy posiadasz wzmacniacz masz lokalizacje masz podaną w moim watku
http://www.a4-klub.pl/smf/empty-t27461.0.html;highlight=wzmacniacz
sprawdz czy tam jest jak jest to napewno miałeś głośniki jak nie ma sprawdz czy są ślady po śrubkach
Co do wlewu paliwa sprawdz czy nie był czasem awaryjnie otwierany, może być tak że linka od awaryjnego otwierania gdzies chaczy
Jak sie dostać do zamka i linki awaryjnego otwierania, opis masz tutaj no i przy okazji sprawdzisz czy masz wzmacniacz :
http://www.a4-klub.pl/smf/empty-t28189.0.html;highlight=awaryjne+otwieranie
No Nonilion furka gitara :naughty:. Trzeba bedzie ją obejrzeć dokładniej na spocie. :th:
Wczoraj była wymiana rozrządu (wszystkie rolki i pompa wody) oraz oleju (castrol edge) i wszystkich filterków a także FIS na angielski. Już mi nie gada "mano amano feroocośtam" :rolleyes:
Dziś się robią zabezpieczenia i wreszcie będzie można się pokazać.
Dziękuje kazuyaet za odpowiedź. Będę szukał dopałki i głośników albo śladów po nich:) W razie czego odezwę sie na pw.
basen, Ty masz pomalowane dokładki, jak to wychodzi w eksploatacji? Nie niszczy się, nie ma odprysków?
No to zalales sobie olej stary...
dokladek nie mialem szarych tylko juz oryginalnie w kolorze. Ale jak lakiernik je dobrze pomaluje to bedzie si (dokladki sa gladkie takze nie ma problemu z ich pomalowaniem, gorzej jak by byly chropowate) :evil:
Taka tragedia z tym olejem castrol edge? :embarrassed:
Temat wałkowany wiele razy na forum. Wcześniej lałem Mobila, kumpel leje Shella a kuzyn Valvoline. Wszystkim motorki się kręcą.
Swoją droga, można by zebrać najpopularniejsze rodzaje olejów i zrobić ankietę :mysli:
Miałem zagwozdkę przy wyborze oleju, przyznaję bez bicia. Flyer jaki masz olej u siebie?
Nonilion trzeba było Motula zalać
Castrol to bardzo olej, ale nie ten z Polski.
U siebie mam Motula.
Poczytaj temat o olejach, wszystko tam napisano...
No cacy jeździdełko :) i drewnolandia w środku, taki mały powiew luksusu :)
Niech Ci sie sprawuje dobrze. :th:
no spot był, a auta nie widziałem :tongue4:
