Audi A4 B6 - Avant - BEX - Wisienka
Małe g... no a potrafi tyle problemów narobić. Sam jakiś czas temu wymieniałem bo auto świrowało.
I did read topic again , and i love the time and passions you give to your car  , i can see it is loved :D
Some hove i thought that  you have a4 b8 window switches, not a A6 C7 , i like  C7 more , especially because a lock the doors buttons , it looks natural to the car .
What did you do exactly to fit them ,  how did you connect it , any changing in plugs , pin  , wires or similar ?
About heating wheels , i know b6 had 4 spoke steering wheel , hated  ,  maybe  buy  that that kind of wheel and install that heating in other steering wheel you like .  I had idea to do something  like that and have a steering will and shift knob heated ,  maybe from oem parts or aftermarket  , but never realize the idea.  Maybe it wood be better and ciper to add modern webasto and control the heat with the app.
So do anybody know what kind of module you need to have to have heated steering wheel  , part number of that modul
Dokładnie, po błędach zastanawiałem się czy to nie problem z przepustnicą, ale wymiana tego zaworka była najtańszą i najłatwiejszą opcją, więc od tego zacząłem i akurat trafiłem :cheesy:
Thanks! :drinks: I really like this car.
Switches from A6 C7 are p&p. You don't have to modify anything but the door lock buttons don't work.
If I want heating steering wheel, probably I have to cut it, to put inside new heating wire. But I have new leather, so I don't want to destroy it :decayed:
Na zewnątrz zimowa aura, więc nadszedł czas na pakiet zima. Po przesiadce na 19" nie mogłem pogodzić się z faktem powrotu na 17", więc kupiłem drugi komplet felg Ronal 1953 :lol1: Do tego wleciały opony Imperial Snowdragon uhp 225/35/19.IMG20231119144427.thumb.jpg.5038422574f233bc682df6625b521d8f.jpgreceived_363383216146110.thumb.jpeg.1802e1586cea4387a6fe22731b6b7a57.jpeg
Jest tłusto ?
Zaraziłeś mnie tymi stołkami!
11 godzin temu, R4xx napisał(a):
Jest tłusto ?
No teraz już to jakoś wygląda :decayed:
Polecam fotele, na pewno nie pożałujesz!
Bardzo jestem ciekaw opinii o tych oponach. Szczególnie w tym konkretnym rozmiarze i na tych konkretnych felgach z tym konkretnym obniżeniem, jak u Ciebie. ;) Bo gwintu na zimę nie podnosisz? :whistling:
a powiedz jeszcze jak rozwiązałeś mocowanie pasa w fotelu od audi s5 ???  w a4 b6 pas jest w fotelu a w a5 chyba mocowny jest do progu ??
hej ja tą oponę miałem tylko że na 17calach w rozmiarze 225 45 i opona spoko naprawde jak na chinola to byłem zadowolony
Dzięki za info. Ta opona w zależności od rozmiaru jest w wersji UHP albo Snowdragon 3 stąd mogą pojawić się rozbieżne informacje. A w sieci albo je chwalą, albo wręcz przeciwnie, padają opinie, że szybko robi się 'plastikowa'.
Akurat w 19 calach, które mnie interesują, rozmiar 235/35 jest w wersji Snowdragon 3, natomiast 225/35 to już UHP. I weź tu bądź mądry :dontknow:
Trzeba dorobić mocowanie w szynie fotela.
Tu jest to dobrze pokazane https://a4-klub.pl/topic/138732-fotele-i-kanapa-z-a4-b8-a5-do-b6b7/
Gwint zostawiam jak jest.
Wizualnie wygląda bardzo dobrze na tej wysokości i jest bezpiecznie jeśli chodzi o progi i koleiny. Czasami  przycierałem osłoną na 17" i to był jeden z powodów zmiany na 19". Na 19" koło ma około 1.5cm średnicy więcej, niby niewiele ale zmienia bardzo duzo, bo przejeżdżam wszędzie bez żadnego ocierania.
Co do opon, póki co zrobiłem na nich jakieś 300km w mocno deszczowych warunkach z autostradowymi prędkościami i jechało się bardzo pewnie, są trochę głośniejsze, ale to standard w zimówkach. W weekend czeka mnie dłuższa trasa w nocy, a widzę, że zapowiadają przymrozki, więc będę mógł powiedzieć coś więcej.
W S5 coupe pas mocowany jest do progu albo słupka, pewnie przez to żeby wysiadający z tył się nie potknął o pas. W S5 sportback pas jest mocowany do fotela jak w A4 B6, więc nie ma żadnego problemu z montażem :D
no co do twardnienia mieszanki też słyszałem że po ok 3-4 sezonach zaczynają slizgać się na ten sezon kupiłem 225\40\18 goodride zuperSnow 92V i opinie kopiuj wklej co Imperiale :D
  • 2 miesiące temu...
Nowości, korek oleju na wzór audi R8 :cheesy:IMG20240210132452.thumb.jpg.bcbad63110d698598e536deabe3f5ffc.jpg
Jest krzywo ustawiony. ;)
Niestety zatrzaski są delikatnie przestawione i nie da się go przekręcić bardziej, ale będę próbował trochę porzeźbić, żeby był prosto :decayed:
  • 4 tygodnie później...
Wpadły nakładki na zamki drzwi :decayed:IMG20240210141602.thumb.jpg.0555e30817caf34e1ed3c401bfdbb568.jpgIMG20240210141842.thumb.jpg.75ebd41c91a42bd67d02cca2f543daba.jpg
Autko ładnie zrobione ,pozwole sobie pare pomysłów zapożyczyć do mojej czarnej strzały jeśli pozwolisz ? co do zderzaka przód bardziej podoba mi sie s-line'owski ale to kwestia gustu .pozdrawiam i szerokosci.
Dzięki! :thumbup1:
Korzystaj do woli, po to jest to forum, sam trochę modów zapożyczyłem od innych :grin:
Ze zderzakami jest tak jak mówisz, kwestia gustu, do mnie akurat najbardziej przemawia S4. Pozdrawiam! :cheesy:
Wpadły nowe cewki Beru. Cewka na 3 cylindrze już nie domagała i zaczęło szarpać silnikiem na biegu jałowym i przy rozpędzaniu. Profilaktycznie zmieniony cały komplet bo stare zaraz by miały 200kkm. IMG20240522151312.thumb.jpg.7ce4697095d475cb56b48935a7210d20.jpg
Dodatkowo wymieniłem filtry gazu fazy lotnej i ciekłej.IMG20240519165412.thumb.jpg.da54329574c6e0ffcaa7a2dee24aa3fd.jpg
