B6 DIVISION
Panowie i Panie jak zakodować fis tak aby pokazywał ta mala cyferkę 1-2 po prawej w rogu? ktoś kiedyś pisał a nie mogę teraz tego znaleźć
udi A4 2001 > Dash panel insert, adapting illumination, DIS, radio clock and on-board computer
In adaption channel 19 the following functions are adapted:
Radio clock
Driver information system
On-board computer
Illumination options
The following options are possible:
1st digit: Radio clock and sports seats:
Coding value XXXX0 = Radio clock not active
Coding value XXXX1 = Radio clock active (with PR no. U2A)
Coding value XXXX2 = Radio clock not active and sports seat active (only RS4) (with PR no. Q4P)
Coding value XXXX3 = Radio clock active and sports seat active (only RS4) (with PR no. U2A and Q4P)
2nd digit is not coded, so always 0:
XXX0X
3rd digit: Driver Information System:
Coding value XX1XX = Highline dash panel insert without driver information system, (no drive time alarm, no washer fluid/brake light/bulb warning (even in Check) and Computer option not selectable from menu. Only range displayed on on-board computer. (dash panel inserts with PR no. 9Q3)
Coding value XX2XX = Driver information system with menu guidance
Coding value XX3XX = Driver information system with menu guidance and unit switching (dash panel inserts with PR no. 9Q2 and 9Q4)
4th digit: On-board computer:
Coding value X0XXX = On-board computer (only level 2 - long-term memory)
Coding value X1XXX = Level 1 and 2 (dash panel inserts with PR no. 9Q2 and 9Q4)
5th digit: Illumination options:
Coding value 0XXXX = Illumination (pointer and scale) on only active with lights on
Coding value 1XXXX = Pointer illumination on active with ignition on, scale (1st dimming characteristic) and pointer illumination active with lights on
Coding value 2XXXX = Scale illumination (1st dimming characteristic) active with ignition on, scale and pointer illumination active with lights on
Coding value 3XXXX = Scale (with 2nd dimming characteristic) and pointer illumination active with ignition on or lights on
  • Odpowiedzi 86.1 tys.
  • jozek726
    5807
  • Wandej
    4734
  • wladi
    3818
  • kaju
    3324
Pany, próbuje u kumpla wyregulować bixy (bez spryskow i samopoziomu) i kręce tą śrubą imbusową co nachodzi w błotnik i próbowałem tą śrubą plastikową od długich i też nic... żadnych zmian. Co moze być nie tak ? (zębatka od śruby imbusowej się kręci ale żadnej reakcji na kręcenie nie ma, w długich też...)
:facepalm:
potrzebna wasza pomoc :hi:
Skad wiesz ze zadnej reakcji nie ma ? to nie bedzie tak widoczny ruch soczewki ze po kilka cm bedzie sie ruszala , sprawdz wieczorem kilka metrow od sciany i wtedy zobacz czy sie zmienia
Exacly, dobrze radzi polać mu :D
no ok dzięki :hi: bede próbował, a jest możlwiość, że sruba do regulacji w jakiś sposób się wykręciła ?
Krecac pokretlami w lampie odlaczonej czy wylaczonej nie zauwazysz po soczewce roznicy, musisz ustawic sie kilka metrow od sciany moze byc 3-4m odpalic lampiony i wtedy krecac mozna zauwazyc zmiany w ustawieniach. Troche watpiwe jest aby w obu lampach byly niesprawne wszystkie 4 regulacje nieprawdaz? :D
Ja ustawialem wedlug tych schematow i potem bylem na stacji i nie musieli nic poprawiac.vahase7e.jpg
przecież w lampach kręcąc regulacją przesuwa się cały plastik ,co jest widoczne nawet przy wyjętej lampie ,ja miałem przypadek że ten plastik zeskoczył z regulacji i się nie ruszał zdejmij dekiel i sprawdź czy nie spadł
:hi:
Panowie i Panie,
czy ktoś zdjął te plastikowe listwy z drzwi (w połowie ich wysokości) ??
Zastanawiam się jak by wyglądało autko bez tych listew i co o tym sądzicie ?? :eusathink:
Będę się pozbywał tych listew z przedniego i tylnego zderzaka i zastanawiam się czy ich z boków również nie zdjąć ... :whistling:
jak zdejmiesz listwy to będziesz miał dziury w drzawiach
Ooo, tego nie wiedziałem :shock3:
Z tego co czytałem to pisali że na taśmę dwustronną są przymocowane, więc nie spodziewałem się że pod nimi będą dziury.. :facepalm:
W takim razie wszystko jasne - listwy muszą zostać :decayed:
Dzięki za info :hi:
tak przyklejone na taśmę ,ale mają kołki ustalające
To w takim razie te listwy na przednim i tylnym zderzaku też będą miały takie kołki ustalające ?? :eusathink:
Te nie mają:wink:
Te nie mają:wink:
To tych się pozbędę bo mam już ich dosyć :naughty:
---------- Post dopisany at 19:10 ---------- Poprzedni post napisany at 19:09 ----------
Nie no takich dziur to nie zostawię - od wentylacji mam klimę :grin:
Yyyy a to Ty wygrales te lusterka? Bo jak tak to pytanie spoznione ;) wygladaja na ori, ale nie wiadomo jakie fotochromy wklady tam sa czy z B6 czy z B7 czy z A6 itp
yyyy a to ty odpuściłeś ???
obudowy wydaje mi się że ori
ledy z A6
no i te foto to jest pytanie
Nie ja nie bralem udzialu w aukcji lsuterka mam elektr.skladane i jedynie wklady bede zmienial na foto ;)
