jezeli chcesz skladac silnik z klockow to szukaj glowicy od AEB. jezeli Twoim planem jest powazniejsza modyfikacja silnika w najblizszej przyszlosci to warto sie rowniez zastanowic nad walkami z silnika ADR.
  • Odpowiedzi 7,5 tys.
  • Wyświetleń 807,1 tys.
Panowie co możecie powiedzieć po tych logach 1.8T ?
Group A: '002
RPM Load Inj. On Time Mass Flow
TIME
Marker STAMP /min % ms g/s
7.78 1280 63.2 9.36 16.86
8.00 1280 65.4 9.36 17.17
8.24 1320 66.9 9.36 18.14
8.49 1360 68.4 9.36 18.81
8.73 1400 69.2 9.88 19.47
8.97 1440 70.7 9.88 20.56
9.22 1520 71.4 9.88 21.08
9.46 1560 72.2 9.88 22.28
9.70 1600 72.9 10.40 22.97
9.91 1640 72.2 10.40 23.14
10.14 1680 72.9 10.40 23.67
10.37 1720 73.7 10.40 24.44
10.61 1760 74.4 10.40 25.92
10.84 1840 75.9 10.92 27.56
11.08 1880 77.4 10.92 28.72
11.31 1920 78.2 10.92 30.08
11.56 2000 79.7 11.44 31.06
11.77 2040 80.5 11.44 32.75
12.02 2080 82.0 11.44 33.22
12.27 2160 83.5 11.96 35.06
12.51 2200 84.2 11.96 37.06
12.74 2240 85.7 12.48 38.14
12.98 2320 87.2 12.48 39.83
13.22 2400 88.7 12.48 41.28
13.47 2440 91.0 13.00 43.33
13.70 2520 94.7 13.52 46.06
13.93 2560 98.5 14.56 50.75
14.17 2640 102.3 14.56 52.92
14.39 2680 106.0 15.60 56.28
14.63 2760 109.8 16.12 58.17
14.87 2840 115.0 17.16 65.50
15.11 2920 116.5 17.16 64.78
15.36 3000 117.3 17.16 65.61
15.57 3080 118.0 17.16 69.94
15.81 3120 118.0 17.16 71.28
16.05 3200 120.3 17.68 74.39
16.29 3280 122.6 18.20 78.42
16.53 3360 123.3 18.72 80.75
16.77 3440 127.1 19.24 86.69
17.01 3520 127.8 19.24 87.22
17.24 3600 130.1 19.76 90.69
17.47 3720 133.1 19.76 93.69
17.71 3800 135.3 20.28 98.47
17.96 3880 134.6 19.76 99.47
18.21 3960 133.8 19.76 103.33
18.46 4040 133.8 19.76 103.58
18.70 4120 134.6 19.76 106.75
18.94 4200 135.3 19.76 108.50
19.18 4280 134.6 19.76 110.03
19.43 4360 134.6 19.76 114.11
19.65 4440 136.8 20.28 115.36
19.89 4520 135.3 19.76 116.50
20.12 4600 133.8 19.24 119.47
20.36 4680 135.3 19.24 121.81
20.58 4760 137.6 19.76 126.69
20.82 4800 137.6 19.76 127.06
21.06 4880 140.6 20.80 130.69
21.30 4960 139.8 22.36 133.64
21.54 5040 140.6 23.40 134.94
21.78 5120 139.8 23.92 136.08
22.02 5160 139.8 23.92 139.50
22.26 5240 140.6 24.44 144.78
22.49 5280 143.6 25.48 143.36
22.73 5360 142.1 24.96 144.06
22.98 5440 139.8 24.96 143.78
23.22 5480 139.8 24.96 146.78
23.45 5560 137.6 24.44 145.47
23.68 5600 136.1 24.44 144.19
23.92 5640 133.1 23.40 146.36
24.17 5720 134.6 23.92 144.56
24.42 5760 131.6 22.88 145.03
24.66 5840 129.3 22.88 146.22
24.90 5880 130.8 23.40 145.75
25.15 5960 128.6 22.88 148.39
25.40 6000 129.3 22.88 148.14
25.63 6040 129.3 22.88 145.75
25.86 6080 127.1 22.36 146.44
26.11 6160 124.1 21.84 148.61
26.33 6200 122.6 21.32 144.28
26.56 6240 116.5 20.28 137.56
26.80 6280 112.8 19.24 131.92
27.04 6320 109.8 18.72 134.36
27.29 6360 108.3 18.20 133.22
27.53 6360 109.0 18.72 133.22
27.78 6400 109.8 18.72 132.81
28.02 6440 109.8 18.72 137.11
28.26 6480 108.3 18.72 135.22
28.50 6520 109.0 18.72 133.69
28.71 6560 109.8 19.24 135.72
28.91 6560 109.0 19.24 135.72
29.15 6600 108.3 19.24 137.78
29.39 6640 108.3 19.24 138.22
29.62 6680 107.5 19.24 137.78
29.86 6680 106.8 19.24 137.56
30.10 6720 105.3 18.72 136.92
30.31 6720 54.1 7.28 62.03
30.55 6640 12.0 2.08 0.00
auto po programie na ok 180+ koni:wink:
148g ? Ile powinno być przy 200KM?
masz serię, AMB
200kM to jakieś 170g/s
Tylko seria, 170km? Ale dol... :(
jeśli seria-to zdrowa, bo z przepływki pokazuje więcej niż 170 koni:wink:
ale on ma niby program... na 190KM.... chyba stał obok 190KM... albo przejezdzał...Dlaczego moj vag pokazuje na kanale 6 temperatuje zamist na 7 jak pisząc na forum? na 7 nic nie pokazuje. Po 2 startach żony od zera do 160km\h, a laska cisnęła do odcięcia wszystkie 3 biegu to IAT skoczył z 36C na 60C. Temperatura otoczenia w tym czasie wynosiła 27C. To normalne przy 1 smicu?
przy smic-u to normalne,u mnie przy trzecim hamowaniu odpadło ok.20 rumaków,program masz 180+ w chłodne wieczory.
seryjne graty, to tak około 20* więcej niż otaczające powietrze, przy normalnej jeździe, bez piłowania do odcinki :wink:
dzwoniłem dzisiaj do PNEUMATIC COMPLEX
nie mają teraz na stanie 36A-AAA-JDBA-1BA
bo jakis tuner wykupił cały zapas 20szt
teraz trzeba czekac 6-8 tygodni :facepalm:
mają jeszcze 35A-ACA-DDBJ-2JB
ale on ma jebitnie duze gniazdo na wtyczkę
Jak zamawiałem taki zawór to dostałem informację że aktualnie nie mają na stanie i trzeba czekać około miesiąca a po tygodniu zawór miałem w domu :decayed: ( ile teraz kosztuje u nich zawór 36A.... ?? )
32.24 ojro netto sztuka
Co trzeba przerobić w 1.8T AEB ( seryjne wtryski 0280150447 ) żeby założyć wtryski 0280155968 ??
440ccm, trzeba zapodac przejscówki
jak sie nie mylę ...
ok sprawdzone, za ickiem jest wolna przestzen, teraz powraca pytanie: jest sens w ogole robienia tej kratki? ile to da?
To jest dokładnie to samo o czym pisałem musisz się tylko dowiedzieć jaki to jest model bo widać na zdjęciu że numer wersji został celowo zamazany :wink:
Dev jak będziesz zamawiać z PNEUMATIC COMPLEX to się podpinam :naughty:
już zamówiłem :whistling:
tutaj masz mail do gościa:
[email protected]
