domjenick Opublikowano 21 Lipca 2008 Opublikowano 21 Lipca 2008 poprobuj tego AndyN,najlepiej ,to sobie skopiuj i wklej gdzies * +00001 = GB-Alarm (not USA) * +00002 = Confirmation Anti-Theft Warning System (Blink) * +00004 = Selective Central Locking (SCL) * +00008 = Anti-Theft Warning System * +00016 = Rear Lid Release Locking at 5 km/h * +00032 = Central Locking at 15 km/h (or 10 mph) * +00064 = Comfort Function via Remote Control (not USA) * +00128 = Right Hand Drive (RHD) * +00256 = Avant * +00512 = Confirmation Close via Remote (1x Blink) * +01024 = Confirmation Anti-Theft Warning Sytem Horn Activation * +02048 = Door-/Window Regulator Logic * +04096 = Thatcham Anti-Theft Warning (not USA) * +08192 = No Safe-Function * +16384 = Side Windows with Insulated Glass Note: Coding is the sum of the individual options. Not all options apply for all control moduls! Adaptation Channel 021: Remote Control Matching [select] [46 - Comfort System] [Adaptation - 10] Channel 021. [Read] * Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory positon 3). [Test] * Now press any button on the remote you want to match. * The meas. block field above will change from Not Recogn. to Recognized. [save] [Done, Go Back] [Close Controller, Go Back - 06] Note: You can check the current memory positions using Meas. Block 007. Channel 061: Variant Reduction * +1 = Mechanical Window Regulators in Rear (PR-4R5) * +2 = Footwell Lights (PR-QQ1) Note: Adaptation value is the sum of the individual options. Channel 062: Comfort Functions * +001 = Comfort closing via remote for window regulators (not USA) * +002 = Comfort opening via remote for window regulators (not USA) * +004 = Comfort closing via lock cylinder for window regulators * +008 = Comfort opening via lock cylinder for window regulators * +016 = Comfort closing via remote for sunroof (not USA) * +032 = Comfort opening via remote for sunroof (not realized) * +064 = Comfort closing via lock cylinder for sunroof * +128 = Comfort opening via lock cylinder for sunroof (not realized) Note: Adaptation value is the sum of the individual options. milej zabawy
kokos Opublikowano 27 Lipca 2008 Opublikowano 27 Lipca 2008 witam,ja dzisiaj u siebie przekodowalem i u mnie drzwi sie otwieraja po wyjeciu kluczyka ze stacyjki,pozdrawiam
letallec Opublikowano 27 Lipca 2008 Opublikowano 27 Lipca 2008 kokos155 napisał(a): witam,ja dzisiaj u siebie przekodowalem i u mnie drzwi sie otwieraja po wyjeciu kluczyka ze stacyjki,pozdrawiam
domjenick Opublikowano 16 Sierpnia 2008 Opublikowano 16 Sierpnia 2008 ja powroce do tematu,czy ktos wie jak w B6 zrobic to,albo jakiego kodowania uzyc do tego,aby zegary zaswiecaly sie za kazdym razem,a nie tylko ,jak zapalam swiatla,obecnie mam tylko swiecace wskazowki,aha i moze ktos wie ,jak sie ustawia ostrosc w B6,w b5 przekreca sie przycisk od resetowania dziennego przebiegu,a jak sie to robi w B6? z gory dzieki
Hugo Opublikowano 16 Sierpnia 2008 Opublikowano 16 Sierpnia 2008 domjenick napisał(a): moze ktos wie ,jak sie ustawia ostrosc w B6,w b5 przekreca sie przycisk od resetowania dziennego przebiegu,a jak sie to robi w B6? z gory dzieki Po lewej stronie w zegarach masz przyciski "+" i "-" i to nimi ściemniasz lub rozjaśniasz podświetlenie zegarów
domjenick Opublikowano 16 Sierpnia 2008 Opublikowano 16 Sierpnia 2008 dzieki Prezes,a wiesz cos o swiecacych zegarach?
Musashi Opublikowano 17 Sierpnia 2008 Opublikowano 17 Sierpnia 2008 domjenick napisał(a): aha i moze ktos wie ,jak sie ustawia ostrosc w B6,w b5 przekreca sie przycisk od resetowania dziennego przebiegu,a jak sie to robi w B6? ostrość ?
HiRide Opublikowano 17 Sierpnia 2008 Opublikowano 17 Sierpnia 2008 domjenick napisał(a): dzieki Prezes,a wiesz cos o swiecacych zegarach? Control Module Adaptation Select 17 (Instrument Cluster) Adaptation -> Function 10 -> Channel 19 (Misc) xxxx?: Remote Clock 0 - Remote Clock not active 1 - Remote Clock active xxx?x: Ambient Temperature 0 - no Display, Illumination inactive 1 - Display and Illumination active xx?xx: Driver Information System (DIS) 0 - DIS 1 1 - Highline without DIS 2 - DIS 2 x?xxx: Board Computer 0 - only Level 2 (long time memory) 1 - Level 1 and 2 ?xxxx: Illumination Option 0 - Needle and Scala only active at 'Light on" 1 - Needle already active at 'Ignition on' 2 - Scale already active at 'Ignition on' 3 - Scala (2. Map) and Needle at "ignition on" active (http://en.openobd.org/index.htm) tu gdzie masz pogrubiona czcionke zmieniasz to co cie interesuje czyli kiedy pali sie skala a kiedy wskazowki itd robilem to kiedys ale wrocilem do ustawien fabrycznych bo to co ja ustawilem jakos mnie draznilo
domjenick Opublikowano 17 Sierpnia 2008 Opublikowano 17 Sierpnia 2008 dzieki-tego szukalem [br]Dopisany: 17 Sierpień 2008, 13:52 _________________________________________________ Musashi napisał(a): domjenick napisał(a): aha i moze ktos wie ,jak sie ustawia ostrosc w B6,w b5 przekreca sie przycisk od resetowania dziennego przebiegu,a jak sie to robi w B6? ostrość ? ...mam problemy z odczytaniem predkosci podczas jazdy... [br]Dopisany: 17 Sierpień 2008, 13:53 _________________________________________________HiRide - dziala,zegarki swieca po przekreceniu stacyjki-dzieki
jabolsb Opublikowano 14 Grudnia 2008 Opublikowano 14 Grudnia 2008 przepraszam ze odświeżam, ale reasumujać co musze zrobic w b5 zeby po zapaleniu i osiągnieciu 15km/h blokowąły mi sie zamki mam sendana, prosze prostymi słowami, gdyż dopiero sie ucze.....
chudineze Opublikowano 14 Grudnia 2008 Opublikowano 14 Grudnia 2008 jabolsb napisał(a): przepraszam ze odświeżam, ale reasumujać co musze zrobic w b5 zeby po zapaleniu i osiągnieciu 15km/h blokowąły mi sie zamki mam sendana, prosze prostymi słowami, gdyż dopiero sie ucze..... Najprościej posiadać interfejs do podłączenia się do komputera swojego pojazdu i program VAG-COM a reszta jest już opisana w tym temacie.
kazimierzm Opublikowano 28 Listopada 2009 Opublikowano 28 Listopada 2009 Witam Aktywowałem sobie właśnie w swojej A4 automatyczne zamykanie drzwi po przekroczeniu 15km/h i selektywne otwieranie drzwi. Auto samo się zamyka jak przekroczę 15km/h, gdy już mam kogoś wysadzić naciskam guzik obok mojej klamki i wszystkie drzwi się otwierają bądź pasażer 2x musi pociągnąć za klamkę i ma drzwi otwarte. - to mi pasuje Ale gdy wysadzę kogoś to jego drzwi sie ponownie po przekroczeniu 15km/h juz nie zamykają, i gdy zamykam auto idę do sklepu wracam naciskam otwieranie w kluczyku auto jest zamkniete, musze 3 razy nacisnąc otwieranie w kluczyku dopiero wtedy mam odryglowane drzwi. To jest normalne ? nie da się zrobić przynajmniej tego aby drzwi otwierały się po jednokrotnym naciśnięciu pilota? jak wygląda to u was ? pozdrawiam
kokos Opublikowano 28 Listopada 2009 Opublikowano 28 Listopada 2009 u mnie drzwi zamykaja sie i otwieraja po bożemu,czyli po jednokrotnym nacisnieciu,a domykanie dziala tak jak u ciebie.pzdr
kazimierzm Opublikowano 29 Listopada 2009 Opublikowano 29 Listopada 2009 To jak to zmienić by otworzyć auto jednym naciśnięciem pilota ?
Bieniek Opublikowano 9 Grudnia 2009 Opublikowano 9 Grudnia 2009 Jesli chce sobie dodac automatyczne zamykanie drzwi i selektywne otwieranie to moge wpisac +36 czy najpierw 32 zatwierdzic a pozniej +4??I wtedy po wyjeciu kluczyka wszystkie drzwi sie beda otwieraly tez,czy do tego jest osobne kodowanie??
kazimierzm Opublikowano 9 Grudnia 2009 Opublikowano 9 Grudnia 2009 Bieniek napisał(a): Jesli chce sobie dodac automatyczne zamykanie drzwi i selektywne otwieranie to moge wpisac +36 czy najpierw 32 zatwierdzic a pozniej +4??I wtedy po wyjeciu kluczyka wszystkie drzwi sie beda otwieraly tez,czy do tego jest osobne kodowanie?? Napisz jak dodałes 36 to ile razy musisz nacisnąć otwieranie drzwi w kluczyku by otworzyć całe auto? - ja musze 2razy .
letallec Opublikowano 9 Grudnia 2009 Opublikowano 9 Grudnia 2009 Ja tez muszę 2 razy kliknąć. Po jednym kliknięciu otwierają się tylko drzwi kierowcy.[br]Dopisany: 09 Grudzień 2009, 21:34_________________________________________________ kazimierzm napisał(a): Ale gdy wysadzę kogoś to jego drzwi sie ponownie po przekroczeniu 15km/h juz nie zamykają, i gdy zamykam auto idę do sklepu wracam naciskam otwieranie w kluczyku auto jest zamkniete, musze 3 razy nacisnąc otwieranie w kluczyku dopiero wtedy mam odryglowane drzwi. To jest normalne ? nie da się zrobić przynajmniej tego aby drzwi otwierały się po jednokrotnym naciśnięciu pilota? To nie jest normalne działanie. U mnie zamykają się po ponownym przekroczeniu 15km/h. Możesz podać jakie masz kodowanie?
Bieniek Opublikowano 9 Grudnia 2009 Opublikowano 9 Grudnia 2009 Dodalem najpierw 32 potem 4.Wszystko dziala tak jak opisujecie.
lyku23 Opublikowano 28 Grudnia 2009 Opublikowano 28 Grudnia 2009 Mam pytanie odnośnie kodowania licznika, a dokładnie czy ktoś z was wie może za co odpowiada ta ostatnia cyfra: xxxx? U mnie początkowo było "00000" zmieniłem na "02000" i faktycznie uaktywniła się kontrolka pasów. Jednak widzę, że wiekszość z was ma swoją kombinację i 1 na końcu "xxxx1". może ktoś wie co oznacza 1, a co 0.
