PMW S4 B6 Avant 03
po s14a szukałem m5 ale nie było w pl egzemplarza godnego uwagi
a zupelnie przypadkiem podejchałem do komisu niedaleko mnie, karnalem się i miłość od pierwszego wejrzenia - dzień póżniej stała pod domem :).
S4 B6 Avant 03' 4,2 V8 BBK
no special edition
CD changer
airbag f. driver a. front seat passenger
outer rear view mirrors: powered, heated
outer left rear view mirror: non-spherical
outer right rear view mirror: non-spherical, large viewing field
disc brakes, rear
battery 450 A (95 Ah)
disc brakes, front
suspension/shock absorption for special sports design
electric sliding/pop-up solar sunroof with automatic pre-selection
decorative carbonado fabric inserts
ultrasonic park distance control
power windows with comfort operation andcircuit breaker
no special purpose vehicle, standard equipment
alternator 190A
gearshift lever
weight category rear axle weight range 12
weight category front axle weight range 11
components for base engine, unit 079.C (aluminum)
rear seat bench unsplit, backrest split folding
bi-functional headlight with gas discharge lamp, for driving on the right
instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
national sales program Germany
speed-related variable steering assist (Servotronic)
leather trimmed sports steering wheel for airbag system with "S" badge
automatic headlight-range adjustment dynamic (self-adjusting while driving)
multi-function indicator/on-board computer with check control
engine cooling system, type 1
8-cyl. gasoline engine 4.2 L/253 kW 40V multi-point injection base engine is T79
navigation system with color screen
alloy wheels 8J x 18 "Avus III", offset 45
without tire pressure warning light
side airbag front with curtain airbag
reinforced bumpers
leather gearshift boot
electric seat adjustment for both front seats
side and rear windows tinted
without roll-up sun screen
radio remote controlled central locking operated from inside and separate trunk release
arrier frequency 433.92 MHz
without additional engine guard
emissions concept EU 4
RECARO sports seats, front
windshield tinted with windshield sunshield
foty:
Wóz jest w niemal doskonałym stanie jak na 11 letnie auto.
Od razu przeswietlilismy go bardzo szczegółowo u Darka Grabskiego (Roda).
Co trzeba powymieniane.
Wóz ma wydech z kwasa na 3 tłumikach, katy out, wygląda na produkcję elteca więc jest bardzo kulturalnie.
w planach:
- gwint z regulacja twardosci i wysokości,
- profi odizolowany i zabezpieczony termicznie dolot,
- zaciski 6p z prosia
- jakieś fajne 19'
Prezentuje się godnie :slina:
super auto-daj opis auto w PL jak możesz :decayed::decayed:
dziura w dachu i recaro z v8 pod maską BAJKA
Przymierzałem się do niej.
Witamy w gronie posiadaczy BBK:wink:
witamy ;-)
Ładny egzemplarz szkoda tylko że avant :wink: bezawaryjności życzę :thumbup:
I jak tam, dzieje się coś w temacie?
dzisiaj dostałem na mejla foto gotowych prototypów ... lada dzień będą u mnie
10455427_751978368158706_5388888961967512192_n.jpg?oh=275f867bef5281af902a7237c7826b8b&oe=542328FB
pozatym zrobiłem już ponad 2000 km i japa non stop się cieszy... nawet złapałem się chwilę za kolegą w czarnym rs4b5 na a2 :)
piekna jest :slina:
Autko mistrzostwo ! :wink: i jak tam sie ten meeting z rs4 b5 zakończył ? była jakaś dłuższa kreska ? :naughty:
chwile się złapałem za kolegą tak do 22 zł nie było kreski ... zresztą patrząc na jego tablice z ramką Sportmile i zestaw budzików na desce obstawiam 500+ więc nie miało to sensu :) zrównaliśmy się wymieniliśmy uśmiechy raz poszedłem ja raz on to tyle... nie było ścigania
wydeszek
i kilka fajnych detali
jakie miał blachy?
:roll: tak wyglądała stara poduszka i przy okazji wleciały nowe świeczki ngk - odżył zdecydowanie
Jesteś może ze Starej Miłosnej?
o witam sąsiada! :D
przy okazji wrzucam kilka fotek
Slepo wierze ze kiedys zycie ulozy mi sie tak, ze bede mogl pozwolic sobie na v8
Super auto! :naughty:
Rozumiem, że to ta sztuka z autoauto z Ostrobramskiej? :) Można by sie jakoś zgadać i spotkać na eSkowego spota :wink:
dokładnie ta sama... oględziny na miejscu + testy u Darka Grabskiego (Roda) trwały ponad 8h ... udany zakup :) ... bardzo chętnie zapraszam w niedzielę na spocik: https://www.facebook.com/events/269443009928959/?fref=ts
jeśli to auto z Ostrobramskiej to oglądałem je przez płot :) myślę o takiej esce ale kurde strasznie się boję kłopotów z rozrządem :kwasny:
auto mega, wrzuć jakieś 19 potem obniż i jest kosior ;)
