B8 TrOOOOp
w Gatewayu wszystko OK , tylko Radio złe zakodowane oraz masz jakiś bład komunikacyjny :eusathink:
  • Odpowiedzi 34.7 tys.
  • wrclaguna
    2274
  • Hohe
    1845
  • Gibons
    1520
  • mumen
    995
Pojade jeszcze raz do Aso :(
Ciekawe czemu ono dziala zle zakodowane...
generalnie mam wkurzajacy blad czujnika w haku ibalagan przez to radio w logach:
VCDS Version: Release 10.6.0
Data version: 20100630
Friday,04,May,2012,20:33:57:46862
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
77
VIN: WAUZZZ8K08Axxx Mileage: 109580km
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0004
Revision: --H01---
Coding: 0104002C180F0928
Shop #: WSC 00030 259 177412
ASAM Dataset: EV_ECM30LTDIA5 A02004
ROD: EV_ECM30LTDIA5.rod
VCID: 2E580CE6864D536C
1 Fault Found
4865 - No Communication with Towing System Control Module (J345)
U1003 00 [039] - Upper Limit Exceeded
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 109589 km
Date: 2012.05.04
Time: 19:58:54
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 Q HW: 8K0 907 379 Q
Component: ESP8 quattro H04 0170
Revision: -------- Serial number: --------------
Coding: 1B8500
VCID: 4796594209F7E224
1 Fault Found
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 19:58:14
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0017
Hex Value: 0x4395
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AL HW: 8K0 907 064 AL
Component: BCM2 1.1 H71 0134
Revision: 00002001
Coding: 030100
Shop #: WSC 06325 000 00000
VCID: 7AF0F0B60A854FCC
Part No SW: 8T0 959 754 HW: 8T0 959 754
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 P HW: 8T1 820 043 P
Component: KLIMA 1 ZONE H05 0120
Revision: A1000000 Serial number: 0125.03.080994
Coding: 36000000
VCID: 3E783CA6562DA3EC
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000017889
Coding: 2600D0914014AF010001000300001D0D001C030800010101000000
VCID: 3064129E9C79459C
Part No SW: 8K1 955 119 HW: 8T1 955 119
Component: WWS 270308 H06 0060
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 941 531 C HW: 8K0 941 531 C
Component: E1 - LDS H07 0070
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109556 km
Time Indication: 0
Date: 2012.04.27
Time: 16:05:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330808906487
Coding: 010003
Shop #: WSC 19546 000 1048576
VCID: 38742ABE74099DDC
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109556 km
Time Indication: 0
Date: 2012.04.27
Time: 16:05:43
Freeze Frame:
Temperature: 35.0°C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD1452EQ
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7C36AE4031B1FC
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H11 0012
Revision: -------- Serial number: 90304HCN000GZ
Coding: 000016
VCID: 3D7A3BAA5B2BB8F4
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H15 0221
Revision: 00000000 Serial number: 7BX617W38
Coding: 0F0D090002000008010001
VCID: 2D5A0BEA8B4B2874
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0830780EA
Coding: 000303
Shop #: WSC 00030 259 82332
VCID: 468854460EFDFB2C
Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
Address 2E: Media Player 3 (R199) Labels: None
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
Shop #: WSC 06314 000 00000
VCID: F4EC5E8EA8E1B9BC
1 Fault Found
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000006963546
Coding: 011002205000410001
VCID: 3F8641A25127AAE4
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0110310586
Coding: 011A0620003900C0012001
Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 S HW: 8T0 035 223 B
Component: DSP Prem H13 0210
Revision: 00013001 Serial number: 34833000807704
Coding: 0203010301
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 19:52:59
Freeze Frame:
Voltage: 12.10 V
Temperature: 36.0°C
Temperature: 44.0°C
Bin. Bits: 00000001
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000006965953
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000101769
Shop #: WSC 00000 000 00000
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 346C1E8E686179BC
Address 56: Radio (J503) Labels: None
Part No SW: 8KD 035 195 B HW: 8KD 035 195 B
Component: Symphony3 CN H07 0353
Revision: 00000010 Serial number: AUZ5Z4J1198645
Coding: 0003008200008501D7DF770000
VCID: 4084425E2CD9D51C
Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
2 Faults Found
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 421234 km
Time Indication: 0
Date: 2011.07.06
Time: 14:17:13
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 20:20:02
Freeze Frame:
Bin. Bits: 10100000
Bin. Bits: 00000001
Bin. Bits: 00000001
Bin. Bits: 00001110
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000006957543
Coding: 010002204000210001
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000006982944
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H37 0600
Revision: 00000000 Serial number: 00000005077977
Coding: 0010320
Shop #: WSC 06335 000 00000
VCID: 3B7E35B2453FB6C4
End ---------------------------------------------------------------------
Witam,
musisz wyciagnac kratki i jak je odwrocisz, to zobaczysz jak sie sciaga. podwazasz i wychodza
jestes pewien ? oblookalem to wczoraj ale jakos mi sie nie widzi , a nie che czegos polamac......
Chassis Type: 8T0
77
Revision: --H01---
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 109589 km
Date: 2012.05.04
Time: 19:58:54
Coding: 1B8500
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 19:58:14
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0017
Hex Value: 0x4395
Hex Value: 0x00FF
Revision: 00002001
Coding: 030100
Coding: 36000000
Coding: 00FD11
Coding: 025028
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109556 km
Time Indication: 0
Date: 2012.04.27
Time: 16:05:00
Coding: 010003
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109556 km
Time Indication: 0
Date: 2012.04.27
Time: 16:05:43
Freeze Frame:
Temperature: 35.0°C
Coding: 000016
Coding: 000303
Revision: 00000000
Coding: 020202
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Time Indication: 0
Coding: 0203010301
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 19:52:59
Freeze Frame:
Voltage: 12.10 V
Temperature: 36.0°C
Temperature: 44.0°C
Bin. Bits: 00000001
Coding: 0000004
Component: Display
2 Faults Found
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 421234 km
Time Indication: 0
Date: 2011.07.06
Time: 14:17:13
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 20:20:02
Freeze Frame:
Bin. Bits: 10100000
Bin. Bits: 00000001
Bin. Bits: 00000001
Bin. Bits: 00001110
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Coding: 0010320
Cos za duzo tych błedów komunikacyjnych , sprawdz bezpieczniki po lewej stronie deski rozdzielczej .
Jak się nazywa ten niebieski lakier ?
Chassis Type: 8T0
77
Revision: --H01---
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 109589 km
Date: 2012.05.04
Time: 19:58:54
Coding: 1B8500
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 19:58:14
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0017
Hex Value: 0x4395
Hex Value: 0x00FF
Revision: 00002001
Coding: 030100
Coding: 36000000
Coding: 00FD11
Coding: 025028
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109556 km
Time Indication: 0
Date: 2012.04.27
Time: 16:05:00
Coding: 010003
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109556 km
Time Indication: 0
Date: 2012.04.27
Time: 16:05:43
Freeze Frame:
Temperature: 35.0°C
Coding: 000016
Coding: 000303
Revision: 00000000
Coding: 020202
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Time Indication: 0
Coding: 0203010301
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 19:52:59
Freeze Frame:
Voltage: 12.10 V
Temperature: 36.0°C
Temperature: 44.0°C
Bin. Bits: 00000001
Coding: 0000004
Component: Display
2 Faults Found
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 421234 km
Time Indication: 0
Date: 2011.07.06
Time: 14:17:13
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 109589 km
Time Indication: 0
Date: 2012.05.04
Time: 20:20:02
Freeze Frame:
Bin. Bits: 10100000
Bin. Bits: 00000001
Bin. Bits: 00000001
Bin. Bits: 00001110
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Coding: 0010320
Wszystkie ok. Sprawdzilem prawa i lewa strone, tyl.
Taki dziwny modul haka mam wlozony:
Hak thule, dokladany przez Aso.
---------- Post dopisany at 13:55 ---------- Poprzedni post napisany at 12:57 ----------
widzial ktos w sieci prawidlowe kodowanie haka?
łaczysz sie z Trailer Hitch 69 ? kodowanie jest w kilku Modułach w aucie .
Nie, nie moglem sie polaczyc...
Ciekawe co to za firma :eusathink:
Modul?
tak z tej fotki od ciebie :wink: poszukamy w Googlach coś :decayed:
---------- Post dopisany 09-05-2012 at 20:45 ---------- Poprzedni post napisany 08-05-2012 at 16:43 ----------
Jakby ktoś chciał Bixa zakładać :wink:
http://a4-klub.pl/showthread.php?234482-UPGRADE-przednich-zwyklych-lamp-na-Bixenon-LED
Bylem dzisiaj na poprawce w niemieckim aso. Kpina. Najpierw sie gapili w fote bledu jak sroka w ogon, a potem zaczeli mi opowiadac, ze to audi decyduje czy takie radio moze byc zalozone w tym aucie czy nie i ze oni nie moga przeprogramowac serwera audi. A jak chce jeszcze jednej proby to za kase i generalnie bym sie gonil.
Olalem ich zupelnie bo widze, ze nie maja zielonego pojecia i jedyne co potrafia to wymienic komponent na nowy i wklepac kod svn czy jak on sie tam zwal...
W kazdym razie nadal mam durny blad w tym symphony i ono nadal nie daje sie przekodowac :(
Jak bede w Lodzi to moze podjade do Aso i oni cos zdzialaja.. Innej opcji w tej chwili nie widze :(
http://www.ebay.com/itm/OEM-Audi-A5-S5-RS5-Aluminium-Sport-Pedal-and-Dead-Pedal-Set-/140706580409?pt=Motors_Car_Truck_Parts_Accessories&hash=item20c2c407b9&vxp=mtr
możliwe, że to ORI? mógłby ktoś sprawdzić w ETCE czy coś takiego występuje i jeśli tak to mogę prosić o numery części?
Tak ORI :wink: chcesz numer części :naughty: z tego co pamietam to komplet cos 500 PLN
bo szukałem na tym naszym allegro i takich rzeczy nie ma.. a w USA i w DE występują.. 500zł? ten samochód mnie zrujnuje :decayed:
Chlopaki potrzebuje malej rady.. :wink:
Koledze dzisiaj padla maglownica w S3, zalamany chlopak bo ASO krzyknelo straszne pieniadze za czesci i robote.
Chyba okolo 6000zl.
Wiec pytanie, czy ta czesc sie nadaje na cos? :) -> http://allegro.pl/przekladnia-maglownica-vw-golf-iv-skoda-audi-seat-i2320151735.html
Mechanika juz dla niego znalazlem wiec ok, szkoda mi goscia ale nie zna sie na mechanice i czesciach.
Który rok tej S3 , sprawdze po numerze w ETCE :wink:
Nie pamietam, ale nr zczytany z czesci to 1J1422105.
Dzieki.
