Efekt wymiany licznika na FIS
Witam.Znalazlem rozpiske która pasuje do moich zegarów :) post na 477st
32-Pin Connector for Basic Functions, Blue
1 - Terminal 15
2 - Turn signal, right
3 - Speedometer output 1
4 - Open
5 - Sender for fuel gauge
6 - Airbag
7 - Terminal 31 sensor Ground (GND)
8 - Coolant temperature
9 - Terminal 31 load Ground (GND)
10 - Oil pressure switch
11 - Engine speed (RPM) signal
12 - Terminal 61
13 - CAT
14 - Self leveling suspension
15 - Terminal 58d
16 - Malfunction Indicator Lamp (MIL)
17 - High beam
18 - Turn signal, left
19 - ABS
20 - Terminal 58s
21 - Door contact (driver's door)
22 - Engine coolant low
23 - Terminal 30
24 - Terminal 31 load Ground (GND)
25 - K-wire
26 - Parking light, right
27 - Parking light, left
28 - Speedometer (input)
29 - Brake fluid level/pressure
30 - S-contact
31 - Seat belt buckle
32 - Electronic Stability Program (ESP)
32-Pin Connector for Additional Functions, Green
1 - Open
2 - Open
3 - Open
4 - Open
5 - W-wire
6 - Tailgate (Lowline model only)
7 - Brake pad (Highline model only)
8 - Input for outside buzzer control (currently not assigned)
9 - Input for outside chime control (currently not assigned)
10 - Low fuel level warning-output signal for Engine Control Module (ECM)
11 - Standing time output
12 - Air conditioning cutout
13 - Parking brake
14 - Electronic throttle
15 - Side marker light
16 - Open
17 - Open
18 - Open
19 - Open
20 - Open
21 - Oil temperature
22 - Open
23 - Open
24 - Open
25 - Open
26 - Open
27 - Open
28 - Open
29 - Open
30 - Speedometer output 2
31 - Open
32 - Open
20-Pin Connector for Multi-Function Display, Red
1 - Fuel consumption signal
2 - Open
3 - Open
4 - Open
5 - Outside air temperature
6 - Selector lever display
7 - Open
8 - Open
9 - Washer fluid
10 - Hydraulic pressure
11 - Trip computer reset
12 - Clock signal for radio frequency display
13 - Data signal for radio frequency display
14 - Trip computer (forward sequence)
15 - Enable signal for radio frequency display
16 - Tail lights/headlight low beam (indicator lights)
17 - Open
18 - Trip computer (reverse sequence)
19 - Brake lights
20 - Open
I mam pytako do Was co to jest i gdzie to podłaczyc lub co podłaczyc do tego:)
1 - Terminal 15
12 - Terminal 61
15 - Terminal 58d
23 - Terminal 30
O co w tym chodzi i co to jest??
Które piny z wtyczki czerwonej 20 pin odpowiadaja za sterowanie fisem z manetki góra,reset itp.
  • Odpowiedzi 14.2 tys.
Co do manetki masz napisane Trip computer .... (Piny11, 14,18)
Wie ktoś może czy rozpiska wyżej wrzucona przez DJ EDI będzie pasowała w pełni także do licznika A6 4B0 919 881x ?
Panowie mam problem z poducha.Podlaczylej wszystko według rozpiski wyżej czyli z 26 pinowej kostki niebieskiej pin nr 9 pod 32 pinowa kostke niebieska pin nr 6 i teraz tak nie ma zadnego bledu ale pali się lampa od poduszki na zegarach i nic nie mogę skasować cos jest nie tak.Gdzies wyczytałem ze trzeba pin 9 z niebieskiej kostki podpiac pod pin 12 32 pinowej kpostki i tak zrobiłem.Efekty takie ze kontrolka się nie pali:) he ale jest ale na vagu jest błąd 1025 Tigger for On Boadr Diagnostic Lamp.Malfunction.
31-00- Open of Short to Ground
Jak z tego wybrnąć proszę o pomoc.Pisze z garażu i proszę o szybka odpowiec bo nie wiem co mam zrobić.Prosba o pomoc.
:hi:
Panowie, na które piny dać prądu na licznik z A6 4B0 920 933G żeby zobaczyć w jakim stanie jest FIS?
Wpadł mi przez przypadek taki licznik i się zastanawiam jak i czy da się go sprawdzić?
Jak jest ze skalowaniem prędkości? tzn. mam u siebie 260 i 130 na środku, w tym zegarku jest 260 i seta na środku i nie ukrywam, że wolał bym takie zegary, bo to zdecydowanie lepiej przyśpiesza :decayed:
Czy mogę podłączać pod swoje kostki ten licznik i nie dostać z jaśka buzię?:decayed: IMO się nie rozjedzie?
ogólnie strasznie jestem zielony w tym temacie, a jedyny temat z licznikiem to chyba ten i prawie 500 stron :naughty:
jak by mógł ktoś coś podpowiedzieć to byłbym wdzięczny:hi:
:hi:
933G to już gruby licznik. Jeśli masz 130 na środku, to albo masz anglika, albo tarczke prędkościomierza fake EU, czyli taka, żeby się wsad licznika zgadzał... W prawidłowym liczniku EU jest właśnie na środku 100. Z jaśka w pysk nie dostaniesz, immo idzie ogarnąć.
Panowie poradzcie cos.Kurcze nie moge tego ogarnac
:hi:
no a jak:decayed:
czyli odepne swój, zapinam tego z A6, lookam czy si, podpinam swój stary i nie ma kwaitków?
933g to co w nim jest takiego srogiego?
Masz pełny lift? Teraz masz jaki zegarek, cyfrowy czy analogowy?
tak pełny lift, zegarek analog i brak ramek na gajgerkach, tym się różnią z wyglądu, w sumie dla tych ramek go wziąłem :decayed:
no i ja mam całe czerwone podświetlenie, a tu raczej jest biało- czerwone plus u mnie nie ma info o otwarciu drzwi, tylko o klapie bagażnika, a tu pewnie będzie
ale musze na niego jakoś podać napięcie żeby zobaczyć jak fis wygląda
Widze ze nikt nie pomoze.Panowie nie wieze ze nikt nie mial takiego problemu jak Ja.Zegary sa fajne wszystko jest prawie oki tylko jest problem z tym begiem.Poradzcie cos Pany
Pulpit, nie pokaże Ci ani otwartych drzwi ani bagażnika i będzie odwrotnie wskazywał paliwo (do ogarnięcia we wsadzie) - to jest licznik z A6. Info o drzwiach idzie po module komfortu, u siebie możesz zapomnieć o tej opcji. Żeby ruszył jak należy to czeka Cie przekładka kilku pinów, bo się nie zgadza rozpiska. Immo oczywiście jest w zegarach, ale masz niepełny lift, auto Twoje pochodzi z pierwszej połowy 99 roku, stąd masz czerwone podświetlenie i analogowy zegarek.
DJ EDI przechodziłeś z zegarów przedliftowych na poliftowe, tak? Przedliftowe zegary świecą na żarówkach, a poliftowe na diodach - prawdopodobnie dlatego świeci Ci AB.
Panowie czujniki zużycia klocków są tylko z przodu, czy z tyłu też?
tylko przód.
Thx
ale jezeli istnieja do zalozenia na tył z czujnikami to mozesz sobie podlaczyc tez tylne :decayed:
Interesuje mnie jak jest ori, bo wyskoczyła mi kontrolka :wink:
Czas na inwestycje...
warto sprawdzic czy instalacja dziala najpierw bo czesto gesto padala wiazka ta co idzie z nadkola do klocka
duzo ludzi wymienialo klocki a kontrolka dalej kula
dziura w podłodze i jak Fred Flintston :banan:
nie lepiej wyrzucac z okna dekiel od studzienki na lancuchu ??
:dziura::dziura:
