[ALL B5] Świece do LPG - temat inny niż wszystkie
skoro zacząłem ten wątek to może go skończę :)
napisałem do ngk, i po kilku mailach, miła Pani przekierowała mnie do inżynierów w japonii :)
dostałem taką odpowiedź :
Hi Olivia,
With LPG fuel we generally recommend to start by dropping one heat colder than the original plug and to also reduce the gap by .2mm (.008). This is because LPG is much harder to ignite than gasoline (petrol) making it much tougher on the ignition system. Also because LPG converts to a gas more easily than gasoline it doesn't remove as much heat from the combustion chamber causing the plug's electrode temperature to increase and to possibly become overheated. This is why it's important to start with a colder plug to prevent any overheating.
Standard nickel plugs will also erode very quickly in LPG applications so the customer may want to try and use a precious metal plug like platinum or iridium which will help extend the plugs life. In Europe NGK actually offers LPG specific precious metal spark plugs. You'll want to have him contact NGK Europe to see if these type of plugs are available for his application. Hope this helps, thank you.
Hello Brandon, thanks a lot for your answer, it confirms me in my thoughts,
so for example, if for my car Audi A4 1.8 ARG (2000) recommended (and originally assembled by Audi) spark-plugs are BKUR6ET-10 , what kind of replacement spark-plugs you recommend to use with LPG fuel ? this will be more than important knowledge for me (us).
Also if you can tell me the difference between 3 and 1 electrode spark-plugs and which is best for LPG fuel.
i understand than 3 electrodes will increase lifetime of the spark-plug but 1 electrode models has now platinum or iridium "covers" so also should have similar lifetime, so whats best for LPG ?
many thanks from Poland
best regards
Hello,
I would suggest trying the NGK BKR7EIX stock# 2667 which is one heat range colder, is a fine wire precious metal plug, and comes with a gap of .8mm (.032”) new. You may need to check with NGK Europe to see if this plug is available there.
Multi-ground plugs can help increase longevity and can help to reduce low speed fouling. Switching to a single wire precious metal plug also does these same things but it also increases the ignitability of the spark plug. So for LPG I’d recommend trying a single ground precious metal plug like iridium or platinum for better performance. Hope this helps, thank you.
Regards,
Jak widzicie, koleś do gazu poleca jednoelektrodowe, jeden stopień zimniejsze i wyjaśnia dlaczego, oczywiście kto "nie chce poprawiać fabryki" niech sobie zakłada jakie chce, rzeczywistość jest taka że my już zakładając gaz zmieniamy na tyle charakterystyke pracy silnika że NALEŻY pewne podzespoły dopasować do realiów panujących podczas pracy
tyle z mojej strony
pozdrawiam
Miike :good: Jesteś gość.
W tej odpowiedzi potwierdziły się wnioski do jakich już sam doszedłem :wink4: 3....4 elektrodowe to odpust i tyle.
czyli przy LPG warto rowniez zastanowic sie nad tym stopien zimniejszymi. skoro warto wyrzucic kata w celu zmniejszenia temperatury to swiece tez beda rozsadnym rozwiazaniem.
Co do wyższej temp. spalania LPG przy poprawnie wystrojonej instalacji to też bym polemizował... :gwizdanie: Każdy tylko gada i gada o tej temp. spalin na gazie, a ja jeżdżę już prawie dwa lata ze wskaźnikiem EGT i zarówno na LPG jak i na PB temp. spalin jest identyczna. Problemy zaczynają się kiedy kat się zapycha i dusi wszystko, albo/i jak gazownik nie potrafi dobrze instalacji wystroić :gwizdanie: Wtedy można przeczytać posty typu: " czerwona turbina pomocy! "
sorki za O.T. ale jaka masz turbine przy LPG :blink:
GT2X :kox:
GT2X :kox:
:shocked::zemdlal: napisz mi PW dokladnie co tam masz
Według mnie temperatura w komorze spalania musi być wyższa przy LPG bo fizyki się nie zmieni, tak po prostu jest i koniec, natomiast jeżeli chodzi o spaliny czy one maja wyższą temp na końcu to najwiecej zapchany kat ma do tego
Ogólnie wracając do świec to myśle ze zmiana na jednoelektrodowe i zimniejsze o jeden stopień nie zmniejszy spalania czy nie zwiększy osiagow ani nie spowoduje powodzi na saharze,
ale silnik powinien równo pracować i zywotnosc kabli cewek no i świec powinna się wydłużyć co przy 7-10 latkach z przebiegiem ponad 200k do ktorych najczęściej zakładamy gazy powinno mieć duże znaczenie , szczególnie dla naszych portfeli
Mozesz napotkać na problem po uruchomieniu silnika. Kiedy jest nierozgrzany i pracuje jeszcze na benzynie.
to np dla mojego silnika NGK przewiduje świecę o nr BKR6EKUB (1 elektrodowa) to jak znaleźć świecę zimniejszą o 1 stopień, która będzie pasowała do mojego silnika?
Temp. spalin gazowych LPG jest taka sama jak temp. spalin benzynowych przy poprawnie wystrojonej instalacji, a więc i w komorze spalania panuje prawdopodobnie taka sama temp. Problem polega na tym, że niewiele ludzi potrafi sukcesywnie stroić mieszankę LPG, tak aby nie było za ubogo.
Gaz się spala w wyższej temp niż benzyna to spaliny bedą tez cieplejsze
Zapewniam cię, że nie są :wink4:
Ja dzisiaj zmieniłem świece na ISKRĘ jednoelektrodową o odstępie 0,8mm . Takie zaleca katalog iskry do mojego auta .
NGK z trzema elektrodami na których wcześniej jeździłem nie mają żadnego polotu z ISKRĄ
:hi:
Przeczytałem cały temat i sam już nie wiem... Miike jakie więc Twoim zdaniem powinienem założyć świece do mojego ADR na liczniku 215k? Do tej pory jeździłem na NGK katalogowo przypisanych do tego silnika i wymieniałem co 15000km. Jak wybrać te świece o niższym stopniu?? :mysli:
Ale co sie dokładnie zmieniło??
Bo mój wozik faluje na biegu jałowym ;/
Gdyby tak było, to silnik na LPG teoretycznie powinien mieć większą moc (wyższa temperatura, to wyższe ciśnienie w cylindrze), a jest wręcz na odwrót.
Bez obrazy, ale wydaje mi się, że cały ten temat, to szukanie dziury w całym.
Zrobiłem swoim autem (nie A4) 110 tys. na LPG. Świece zawsze zakładałem takie jak mówi instrukcja - wymiana co 30tys.. Kable i cewki od początku auta oryginalne (auto ma 205 tys. przebiegu) W tym czasie, żadnych poważniejszych awarii (tłumiki, wahacze... normalka). Spalanie i moc silnika cały czas bez zmian (przynajmniej zauważalnych...) Co to za auto? Śmiech na sali - Fiat CC900 na wtrysku :decayed:
W A4 też mam świece takie jak mówi instrukcja i nie wydziwiam.
Tu chyba chodzi o to że gaz jest suchy a co za tym idzie jest większe tarcie w komorze i z tąd te wyższe temperatury :naughty:
Świece dobiera się do silnika!!! Chociaż znam rodzynki które na gazie zamiast zwykłych świec mają platynowe NGK PFR6Q :decayed:
