Kontrolka zużytych klocków hamulcowych na fisie
Witam mam problem z zapalającą się kontrolką zużytych klocków hamulcowych na fisie . Jednego dnia świeci cały dzień czasem przez tydzień wcale .Klocki sprawdzone wyglądają na nowe . Po teście vagiem mam nst. błędy VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 5934
Coding: 00002
Shop #: WSC 63251
WAUZZZ8E05A047786 AUZ6Z0D0316177
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AB
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63251
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63251
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 00042
Shop #: WSC 63251
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 TX
Component: KOMBI+WEGFAHRS. RB8 D42
Coding: 00001
Shop #: WSC 00006
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNO 0050
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AS
Component: Komfortgerát T01 1412
Coding: 06976
Shop #: WSC 63251
1 Fault Found:
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01011
Shop #: WSC 63251
End -------------------------------------------------------
wie ktoś jak można to naprawić pozdrawiam
Po skasowaniu co powraca? Sprawdź czy przewody od klocków nie są uszkodzone.
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
Coding: 00001
Shop #: WSC 00006
1 Fault Found:
Wracają te dwa błędy z nawigacją to wiem nie ma płyty ten drugi nie wiem czy ma ma coś wspólnego z klockami
przewody sprawdzone kostki spryskane wd40 i dalej się zapala nie wiem o co chodzi może klocki są uszkodzone ????
Vag nie pokarze żadnych błędów związanych z klockami, musisz szukać gdzieś przerwy w obwodzie kontroli klocków
u mnie wyglądały na dość duże a te po stronie silnika czyli za tarcza krzywo brały tak ze skosa i to wystarczyło żeby przetrzeć do czujnika, więc może wydaje ci się że jest ich jeszcze dużo, zdejmij koło włóż głowę i skontroluj , choć wątpię skoro raz świeci raz nie .
Koła były ściągane jak zmieniałem na zimówki wydaje mi się że poprzedni właściciel Niemiec wymienił klocki na nowe właśnie z tego powodu .
Sprawdź wiązkę kabli do klocków.
Może gdzieś się przetarły stąd info na Fisie.
Miałem tak w motocyklu z błędem ABS.
Niby otulina kabla w całości a wewnątrz 2 przewody zwierały.
kolego rozepnij wtyczkę od klocków i dobrze tam wyczysc w srodku zapsikaj jakims srodkiem moze tez wtyczka byc dobrze nie docisnieta
Zdecydowanie jakieś połączenie... możesz wziąć miernik i sprawdzać czy z poruszeniem kablem nie bedzie sie zmieniał opór.....
Też tak miałem.... Ale ja robiłem przegląd i czyściłem rdzę z wahacza(drążków itp)... Po tym nagle "awaria klocków na kompie" ... patrzże a tam jeszcze 50%... Po jakimś czasie się uspokoiło samo, więc doszedłem do wniosku że coś musiało wpaść w czujnik klocka... prawdopodobnie robi zwarcie do masy i komputer myśli że klocek się skończył... co prawda nie rozbierałem tego,ale pewnie tak to działa, więc można pokusić się o przeczyszczenie tego ;-)))
Błąd pokazuje się wtedy, kiedy robi się otwarty obwód, czyli jak mamy dziurę (brak przejścia) w obwodzie.
Kontrola klocków działa tak, że od licznika idzie przewód do pierwszego koła (prawego) przechodzi przez klocek i dalej do drugiego koła i później do masy.
Przetarcie czujnika klocka powoduje rozwarcie obwodu licznik (komputer) --> 1klocek --> 2klocek --> masa i zaświecenie kontrolki.
Zwarcie przewodu idącego z licznika na czujnik wyłączy kontrolkę.
Kolega edekxp wrzucił fajny schemat jak to wygląda:
Jak was wkurza kontrolka możecie zrobić zworkę we wtyczce prawego i lewego koła w zależności gdzie przetarło styk w klocku. Jeśli to nie pomoże, bo jest gdzieś dziura dalej w instalacji to zwieramy pin 32 zielonej kostki licznika z masą.
Witam Panowie. Z racji że mam podobny problem, a temat zakończył się na propozycji rozwiązania go poprzez wyłączenie kontroli, to mam pytanko. Mianowicie chodzi o wyłączenie tej kontrolki przez VCDS. Wszędzie pojawiają się opisy, w których zmieniamy kodowanie w 17-Instruments. Jednak w moim przypadku nie ma tam żadnych informacji o klockach. Tylko to: http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Instrument_Cluster_(8EC/8ED/8HE)
Czy powinienem szukać gdzie indziej?
PS. Pacjent to B7 1.8T BFB 2005
Edytowane przez Krausie
Wyłączyć VCDS się da ale w B5, możesz między innymi zrobić yo co napisał wyżej kolega kamil-vag
Kurcze, dziwne, że w B7 tego nie umożliwili. Myślałem, że da się to zrobić bez grzebania w aucie.
Dzięki za info.
Witam
Sprawdź wiązkę kabli ewentualnie wtyczke bo ja miałem ten sam problem i jak zmieniałem buty na letnie to wtyczka była nie dopięta.
W pin 32 wystarczy zrobić wcinke i do masy ? Czy zniknie komunikat tylko klocków ? Czy jest ryzyko ze inne np. Płynu tez ?
Tylko od klocków
Wystarczy wcinke w kabel ? Czy wyciągać pin ?
Widzę że masz b7 więc można to programowo wyłączyć ,w b6 nie ma takiej opcji.Jakie masz obecne kodowanie zegarów ?
Sprawdzałem , nie mam opcji klocków :(
